Edison 4WD Auto Robotic Platform 2.0
Edison 4WD Auto Robotic Platform 2.0 is fundamental development platform which is based on Intel Edison and features powerful scalability. It can helps inventors, entrepreneurs, and consumer product designers develop more practical and various robots easily. Right in this page, we will show you a simple and cool application.
Parts List Check
For your sake, please do parts list checking.
Product Assembly Guide
This section cover the content of assembling fundamental development platform quickly. Completed view:
Main steps required required to complete assembly.
Getting started: Installation of aluminum frame
Completed aluminum frame like following figure shows.
Parts required for this step: Bracket4, long aluminum bar2, short aluminum bar2, M4 flat head socket cap screw16, hex key *1
Specific assembly steps are as follows:
Pick a bracket, a short aluminum bar and join them.
Note the grooved side of bracket ought to be close to short aluminum bar.
After joining, put screw into screw hole from outer side to inner side and fixed it with hex key.
Pick a long aluminum bar and make grooved side of bracket close to it.
Repeat last two steps for another aluminum bar to complete aluminum frame installation.
Assemble bottom board
Results show as follows after completion of this step:
Parts required for this step: PMMA fixing board1, cross recessed pan washer head screw1, cross recessed flat head screw4, hexagon nut4, bottom board4, plate spanner1
Place PMMA fixing bar on the side with more screw hole, then align fixing board with long aluminum bar by screw hole. Then place cross recessed pan washer head screw into remote screw hole and fix them as following image shows.
Place nylon hinge on the side with more screw hole of bottom board and align them. Then use hexagon nut, plate spanner and cross recessed flat head screw to fix nylon hinge.
Place nylon hinge on PMMA fixing bar and align screw hole for both item. Then put cross recessed flat head screws into hole and fix them.as the picture shows. -
Note that do not fix them too tight and keep loose for later operations.
Fix nylon hinge to fixing bar with cross recessed flat head screw.
Fix bottom board with three thumb screws.
Assemble motors
Parts required:Motor4, m3 cross recessed pan head screw12, shaft coupling*.
Place motor's axle up and through bigger hole on long aluminum bar. Then fix motor with M3 cross recessed pan head screw from outer side to inner side.
Repeat last three steps to install all four motor to aluminum frame. Place M3 cross recessed pan head screws into shaft couplings' hole but don't make it through.
Put shaft coupling(screw installed) onto motors' axles and align screw to the hole on axles.
Note the screws must be screwed onto the small pit on motor axles.
Assemble wheels
Parts required:wheel4,M3 cross recessed pan head screw4, screw cap washer*4,switch(connected with power cable)
Put on screw cap washers on M3 cross recessed pan head screw.
Place and push wheel into shaft coupling (from both side of wheel will be okay). Then fix wheel from outside with m3 cross recessed pan head screw.
Loose screw cap washer as following figure shows.
Lead switch through centered two hole on long aluminum bar(left), which have more screw hole on bottom, from inside to outside.
Fix switch as order showed by following figure with plate spanner.
Install PCA board on PMMA upper board
Parts required:PMMA upper board1, M3 hexagon nut4, long distance spacer4, short distance spacer4, cross recessed pan washer head screw4, heat sink4.
Place distance spacer into the holes which is marked by red circle on PMMA board.
Fixed long distance spacers with M3 hexagon nut.
Assemble heat sink on PCB Assembly board and the location of heat sink is marked with white rectangle mark.
Tear off light blue film on heat sink and stick it on PCB Assembly board.
Put micro nut in red circle marked on PCB Assembly board and fix short distance spacer which is locate on other side.
Place PCB Assembly board assembled before on PMMA upper board and align short distance spacer into red circle marked.
Use M3 cross recessed pan washer head screw to fix PCA board on PMMA upper board.
Integrate PCB Assembly board with aluminum frame
Parts required:Aluminum upper board1, M4 cross recessed pan washer head screw8, Velcro tape1, aluminum upper board1.
Take power cable out of aluminum frame.
Place assembled PCB Assembly board on aluminum frame and align both through screw holes marked.
Note power connector should be place on the same side with switch.
Fix four screw into screw hole marked as follows.
Detach thumb screw on PMMA bottom board and lead groove wire through holes marked.
Assemble Velcro tape like following figure shows.
Lead motor-connecting wire out of aluminum frame through hole marked.
Re-fix thumb screw on PMMA bottom board.
Install aluminum upper board. Place aluminum upper board on long distance spacer, and fix it with cross recessed pan washer head screw according to arrow indicates. Now your get robotic platform.
IDE installation (On windows)
Assemble your first Edison board
Thumb of rule: We recommend you don't have to prepare a 7-15 DC power supply for this step, USB cables will meet power-supply demand.
Driver and development tool installation
Thumb of rule: We recommend you only select drivers and flash tool to be installed for the first if you connection speed to Intel server is not fast enough. Downloading other tool separately will be much quicker.
Flash latest firmware on windows
Preliminary application
This section completed a simple application to show its powerful features. You can re-implement quickly by following steps below.
Preparations
Make sure you have completed preparation works mentioned above.
Get micro SD card with storage bigger 4 GB.
Download compressed file required to drive this application.
Tools required: USB OTG cables 1, few cable ties, Intel Edison chip 1, USB webcam*1.
Burn downloaded image files into Edison
Decompress download file and get image file named wifi_car_20150804.img.
Copy image file to SD card.
Insert your SD card to Arduino expansion board. Note you need to format your SD card before do copying operations.
Use following command to flash image file to Edison.
$: mount /dev/mmcblk1p1
Note that the device displayed may be different. A simple way to find SD card descriptions is plug-in and plug-out to see differences of command ls.
$: cd /media/sdcard
$: dd if=wifi_car_20150804.img of=/dev/mmcblk0 bs=1M
- After flashing process completed, now play it!
Detach Intel Edison from Arduino expansion board and then install Intel Edison on PCB Assembly board.
Install DC Power supply. and switch on power.
Take out your cellphone(in this case we use iPhone) and connect to Wi-Fi named EDISON-E9-BB, default Wi-Fi password is 11111111.
Launch a browser on your phone and input edison.local in address bar.
Note you need to input edison.local in address bar on iPhone. On windows phone, Android phone and other wireless devices you can only input 192.168.42.1.
Now you can control you robot movement by virtual joystick on your phone.
More development sources
