Grove - 3-Axis Digital Gyro
Grove - 3-Axis Digital Gyro module based on ITG 3200. It is the world’s first single-chip, digital-output, 3-axis MEMS motion processing gyro optimised for gaming, 3D mice, and motion-based remote control applications for Internet connected Digital TVs and Set Top Boxes. The ITG-3200 features three 16-bit analog-to-digital converters (ADCs) for digitising the gyro outputs, a user-selectable internal low-pass filter bandwidth, and a Fast-Mode I2C (400kHz) interface.
- Supply Voltage: 3.3V, 5V
- Operation Current: 6.5mA
- Standby current: 5μA
- Sensitivity: 14 LSBs per °/sec
- Full scale range: ±2000°/sec
- Acceleration: 10,000g for 0.3ms
- I2C Interface
- ±2000°/s full scale range and 14.375 LSBs per °/s sensitivity
- Three integrated 16-bit ADCs
- On-chip temperature sensor
- Integrated amplifiers and low-pass filters
- Hermetically sealed for temp and humidity resistance
- RoHS and Green compliant
Platforms Supported
| Arduino | Raspberry Pi |
Demonstration
This demo will show you how to get data from this digital gyro, the data is in the unit of rad/s.
Here we need a Grove - 3-Axis Digital Gyro and a Seeeduino V3.0.
Hardware Installation
Hardware installation is very easy, because there's an I2C Grove in Seeeduino,
So, what we need to do is connect it to I2C Grove via a Grove cable.
Download Code and Upload
You can download the library in github, click here, then extract it to libraries folder of Arduino.
Then open File -> examples -> Grove_3_Digital_Gyro -> ITG3200_gyro, you can open the demo code.
Check the result
Now, you can open the serial monitor to check the result.
Reference
The diagram below shows the orientations of the 3 axes. You can use it to understand the physical meanings of the result.
Schematic Online Viewer
