Grove - Flame Sensor
The Grove - Flame Sensor can be used to detect fire source or other light sources of the wavelength in the range of 760nm - 1100 nm. It is based on the YG1006 sensor which is a high speed and high sensitive NPN silicon phototransistor. Due to its black epoxy, the sensor is sensitive to infrared radiation. In fire fighting robot game, the sensor plays a very important role, it can be used as a robot eyes to find the fire source.
- Grove Interface
- High Photo Sensitivity
- Fast Response Time
- Easy to use
- Sensitivity is adjustable
Specifications
Item | Min | Typical | Max | Unit |
Voltage | 4.75 | 5.0 | 5.30 | VDC |
Current | / | 20 | / | mA |
Range of Spectral Bandwidth | 760 | 940 | 1100 | nm |
Detection range | 0 | ~ | 1 | m |
Response Time | 15 | μS | ||
Operating Temperature | -25 | ~ | 85 | ℃ |
Platforms Supported
Getting started
The module is mainly used to detect the infrared light. It outputs digital signal 0 and 1 through a Comparator output. The output value will be 0 when infrared light is detected. And the sensitivity is adjustable by the precision potentiometer.
Play with Arduino
Hardware
- Step 1. Prepare the below stuffs:
| Seeeduino V4.2 | Base Shield | Grove-Flame_Sensor | Grove - Red LED |
| Get One Now | Get One Now | Get One Now | Get One Now |
- Step 2. Connect Grove-Flame_Sensor to port D2 of Grove-Base Shield.
- Step 3. Connect Grove - Red LED to port D3 of Grove-Base Shield.
- Step 4. Plug Grove - Base Shield into Seeeduino.
- Step 5. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect this module to Seeeduino as below.
| Seeeduino | Grove-Flame_Sensor |
| 5V | Red |
| GND | Black |
| Not Conencted | White |
| D2 | Yellow |
| Seeeduino | Grove - Red LED |
| 5V | Red |
| GND | Black |
| D3 | Yellow |
Software
Step 1. Copy the code and flash it into the controller board.
Here is the code
#define FLAME_SENSOR 2 //connect SENSOR to digital pin2
#define LED 3 //connect Grove - LED to pin3
pinsInit();
if(isFlameDetected())
turnOnLED();
else turnOffLED();
void pinsInit()
pinMode(FLAME_SENSOR, INPUT);
pinMode(LED,OUTPUT);
digitalWrite(LED,LOW);
void turnOnLED()
digitalWrite(LED,HIGH);
void turnOffLED()
boolean isFlameDetected()
if(digitalRead(FLAME_SENSOR))
return false;
else return true;
Step 2. The LED will light up when there is infrared light.
Play with Codecraft
Hardware
Step 1. Connect a Grove - Flame Sensor to port D2, and connect a Grove - Red LED to port D3 of a Base Shield.
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
If this is your first time using Codecraft, see also Guide for Codecraft using Arduino.
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
When the code finishes uploaded, the LED will goes on when Flame Sensor detects flame.
Play With Raspberry Pi
Hardware
| Raspberry pi | GrovePi_Plus | Grove-Flame_Sensor |
- Step 2. Plug the GrovePi_Plus into Raspberry.
- Step 3. Connect Grove-Flame_Sensor to D2 port of GrovePi_Plus.
- Step 4. Connect the Raspberry to PC through USB cable.
Software
- Step 1. Follow Setting Software to configure the development environment.
- Step 2. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
- Step 3. Excute below commands to use this sensor
cd ~/GrovePi/Software/Python
python grove_flame_sensor.py
Here is the code of example:
#!/usr/bin/env python
# GrovePi Example for using the Grove Flame Sensor (https://www.seeedstudio.com/wiki/Grove_-_Flame_Sensor)
# The GrovePi connects the Raspberry Pi and Grove sensors. You can learn more about GrovePi here: http://www.dexterindustries.com/GrovePi
# Have a question about this example? Ask on the forums here: http://forum.dexterindustries.com/c/grovepi
## License
The MIT License (MIT)
GrovePi for the Raspberry Pi: an open source platform for connecting Grove Sensors to the Raspberry Pi.
Copyright (C) 2017 Dexter Industries
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
import time
import grovepi
# Connect the Grove Flame Sensor to digital port D2
# SIG,NC,VCC,GND
flame_sensor = 2
grovepi.pinMode(flame_sensor,"INPUT")
while True:
try:
print(grovepi.digitalRead(flame_sensor))
time.sleep(.5)
except IOError:
print ("Error")
Reference
The sensor can detect the light source whose wavelength is in the range of 760nm - 1100 nm. The picture below shows the spectral sensitivity.
Schematic Online Viewer
- [Eagle] Grove - Flame Sensor Eagle File
- [Library] Github repository for Grove_Flame_Sensor Library
- [Datasheet] LM293D datasheet
- [Codecraft] CDC File
