Grove - MOSFET
Grove – MOSFET enables you to control higher voltage project, say 15V DC, with low voltage, say 5V, on microcontroller. MOSFET is also a kind of switch, but its switching frequency can reach up to 5MHz, much faster than normal mechanical relay. There are two screw terminals on the board. One for outer power source and the other for device you want to control. Grove – MOSFET will pass the power from one end to another when closed. But if outer power source is absent, your device can still draw power from microcontroller via the Grove interface.
Version
Product Version | Changes | Released Date |
Grove - MOSFET V1.0 | Initial | Oct 2015 |
Parameter | Value/Range |
Working voltage | 5V |
Vin | 5 ~ 15V |
MOSFET Model | CJQ4435 |
Platforms Supported
Arduino | Raspberry Pi | |||
Getting Started
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Play With Arduino
Demonstration
Here we demonstrate how to use Grove - MOSFET to control a motor. We provide power for it with external power source, but if your controlled device needs current smaller than 300mA, Seeeduino can totally support it and no extra power source needed.、
Hardware
- Step 1. Prepare the below stuffs:
Seeeduino V4.2 | Base Shield | Grove - MOSFET |
Get One Now | Get One Now | Get One Now |
- Step 2. Connect Grove - MOSFET to port D6 of Grove-Base Shield.
- Step 3. Plug Grove - Base Shield into Seeeduino.
- Step 4. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect Grove_MOSFET to Seeeduino as below.
Seeeduino | Grove_MOSFET |
5V | Red |
GND | Black |
Not Conencted | White |
D6 | Yellow |
Vin: Accepts 5V ~ 15V power of which current is less than 2A.
Vout: Attach actuators here.
Software
- Step 1. Copy the code into Arduino IDE and upload. If you do not know how to upload the code, please check how to upload code.
// demo of Grove - MOSFET
// use pwm pin 6 to control a motor
int motorPin = 6;
Serial.begin(38400);
pinMode(motorPin, OUTPUT);
Serial.println("Grove - MOSFET Test Demo!");
motorOnThenOffWithSpeed();
motorAcceleration();
void motorOnThenOffWithSpeed()
int onSpeed = 200; // a number between 0 (stopped) and 255 (full speed)
int onTime = 2500;
int offSpeed = 50; // a number between 0 (stopped) and 255 (full speed)
int offTime = 1000;
analogWrite(motorPin, onSpeed);
delay(onTime);
analogWrite(motorPin, offSpeed);
delay(offTime);
void motorAcceleration()
int delayTime = 50;
for(int i=0; i<256; i++)
analogWrite(motorPin, i);
delay(delayTime);
for(int i=255; i>=0; i--)
delay(delayTime);
- Step 2. Observe the state of the motor
Play With Raspberry Pi
Hardware
Raspberry pi | GrovePi_Plus | Grove - MOSFET |
- Step 2. Plug the GrovePi_Plus into Raspberry.
- Step 3. Connect Grove-MOSFET ranger to D6 port of GrovePi_Plus.
- Step 4. Connect the Raspberry to PC through USB cable.
Software
- Step 1. Navigate to the demos' directory:
- Step 2. To see the code
nano grove_mosfet.py # "Ctrl+x" to exit #
import time
import grovepi
# Connect the Grove MOSFET to digital port D6
# SIG,NC,VCC,GND
mosfet = 6
grovepi.pinMode(mosfet,"OUTPUT")
time.sleep(1)
while True:
try:
# Full speed
grovepi.analogWrite(mosfet,255)
print "full speed"
time.sleep(2)
# Half speed
grovepi.analogWrite(mosfet,128)
print "half speed"
time.sleep(2)
# Off
grovepi.analogWrite(mosfet,0)
print "off"
time.sleep(2)
except KeyboardInterrupt:
break
except IOError:
print "Error"
- Step 3. Run the demo.
sudo python grove_mosfet.py
- Step 4. We will see the output display on terminal as below.
- [Eagle] Grove - MOSFET Schematic file
- [PDF] Grove - MOSFET Schematic PDF
- [Datasheet] CJQ4435 Datasheet
- [WIKI] MOSFET Wikipedia
