Grove - Magnetic Switch
This is a Grove interface compatible Magnetic switch module. It is based on encapsulated dry reed switch CT10. CT10 is single-pole, single throw (SPST) type, having normally open ruthenium contacts. The sensor is a double-ended type and may be actuated with an electromagnet, a permanent magnet or a combination of both. The magnetic switch is a wonderful tool for designers who would like to turn a circuit on and off based on proximity.
  • Grove compatible interface
  • 2.0cm x 2.0cm Grove module
  • Minimum external parts
  • 10W rating
  • Rugged encapsulation
Application Ideas
  • Proximity Sensor
  • Security Alarm Sensor
  • Level Sensor
  • Flow Sensor
  • Pulse Counter
Specifications
Items
Min
Norm
Max
Unit
Working Voltage
3.3
5.0
5.25
V
Switched Power
10
W
Switched Voltage AC,RMS value(max)
< 140
V
Switched Current DC
< 500
mA
Carry Current DC
< 0.5
A
Contact Resistance
<200
Insulation Resistance
>106
Operating Temperature
-40
125
Operate Range
10
40
AT
Platforms Supported
ArduinoRaspberry Pi
caution
Getting Started
note
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Play With Arduino
Demonstration
The SIG pin of the module output LOW normally. When a magnet approaches the switch, the magnetic switch close and the SIG pin output HIGH.
Hardware
  • Step 1. Prepare the below stuffs:
Seeeduino V4.2Base ShieldGrove - Magnetic Switch
Get One NowGet One NowGet One Now
  • Step 2. Connect Grove - Magnetic Switch to port D2 of Grove-Base Shield.
  • Step 3. Plug Grove - Base Shield into Seeeduino.
  • Step 4. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove-Magnetic-Switch to Seeeduino as below.
SeeeduinoGrove-Magnetic_Switch
5V/3.3VRed
GNDBlack
NCWhite
D2Yellow
Software
  • Step 1. Copy the code into Arduino IDE and upload. If you do not know how to upload the code, please check how to upload code.
/*macro definitions of magnetic pin and LED pin*/
#define MAGNECTIC_SWITCH 2
#define LED 13//the on board LED of the Arduino or Seeeduino
pinsInit();
if(isNearMagnet())//if the magnetic switch is near the magnet?
turnOnLED();
else
turnOffLED();
void pinsInit()
pinMode(MAGNECTIC_SWITCH, INPUT);
pinMode(LED,OUTPUT);
/*If the magnetic switch is near the magnet, it will return ture, */
/*otherwise it will return false */
boolean isNearMagnet()
int sensorValue = digitalRead(MAGNECTIC_SWITCH);
if(sensorValue == HIGH)//if the sensor value is HIGH?
return true;//yes,return ture
else
return false;//no,return false
void turnOnLED()
digitalWrite(LED,HIGH);
void turnOffLED()
digitalWrite(LED,LOW);
  • Step 2. Then the LED turns on when there is Magnetic approaches the switch. Have a try!
Play with Codecraft
Hardware
Step 1. Connect a Grove - Magnetic Switch to port D2 of a Base Shield.
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
note
If this is your first time using Codecraft, see also Guide for Codecraft using Arduino.
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
cc
Upload the program to your Arduino/Seeeduino.
When the code finishes uploaded, move the magnet close to the magnetic switch and you will see the LED on the Arduino 13 pin turns on.
Play With Raspberry Pi
Hardware
Raspberry piGrovePi_PlusGrove - Magnetic Switch
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove-Magnetic-Switch ranger to D2 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC through USB cable.
Software
caution
If you are using Raspberry Pi with Raspberrypi OS >= Bullseye, you have to use this command line only with Python3.
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Navigate to the demos' directory:
  • Step 3. To see the code (this demo has the same usage with tilt switch)
nano grovepi_tilt_switch.py   # "Ctrl+x" to exit #
import time
import grovepi
# Connect the Grove Tilt Switch to digital port D2
# SIG,NC,VCC,GND
tilt_switch = 2
grovepi.pinMode(tilt_switch,"INPUT")
while True:
try:
print grovepi.digitalRead(tilt_switch)
time.sleep(.5)
except IOError:
print "Error"
  • Step 4. Run the demo.
sudo python grovepi_tilt_switch.py
  • Step 5. Result
Put a magnet upon the sensor, the SIG pin will output HIGH.
Grove-Magnetic Switch v0.9
Grove-Magnetic Switch v1.3
