Grove - Piezo Vibration Sensor
Grove-Piezo Vibration Sensor is suitable for measurements of flexibility, vibration, impact and touch. The module is based on PZT film sensor LDT0-028. When the sensor moves back and forth, a certain voltage will be generated by the voltage comparator inside of it. A wide dynamic range (0.001Hz~1000MHz) guarantees an excellent measuring performance. And, you can adjust its sensitivity by adjusting the on-board potentiometer with a screw.
Version
Product VersionChangesReleased Date
Grove - Piezo Vibration Sensor V1.1InitialJul 2014
  • Standard grove socket
  • Wide dynamic range:0.1Hz~180Hz
  • Adjustable sensitivity
  • High receptivity for strong impact
More details about Grove modules please refer to [Grove System](https://wiki.seeedstudio.com/Grove_System/)
Platforms Supported
ArduinoRaspberry Pi
caution
Applications
  • Vibration Sensing in Washing Machine
  • Low Power Wakeup Switch
  • Low Cost Vibration Sensing
  • Car Alarms
  • Body Movement
  • Security Systems
Getting Started
Play With Arduino
Hardware
The Grove - Piezo Vibration Sensor outputs a logic HIGH when vibration was detected. We can use any of Arduino pins to read the data. Here is an example of Piezo Vibration Sensor controlling LED. When the vibration was detected, this sensor outputs a logic high signal (the sensitivity can be changed by adjusting the potentiometer), an LED lights up.
  • Step 1. Prepare the below stuffs:
Seeeduino V4Base ShieldGrove - Piezo Vibration
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Connect the module to the D2 of base shield using the 4-pin grove cable, we use digital pin13 on board LED as output.
  • Step 3. Plug the Basic Shield into Arduino.
  • Step 4. Connect Arduino to PC by using a USB cable.
note
It may output low level even though originally output high level when you increase the threshold voltage by clockwise adjusting the potentiometer.
Software
  • Step 1. Copy and paste code below to a new Arduino sketch.
const int ledPin=13;
Serial.begin(9600);
pinMode(ledPin,OUTPUT);
int sensorState = digitalRead(2);
Serial.println(sensorState);
delay(100);
if(sensorState == HIGH)
digitalWrite(ledPin,HIGH);
else
digitalWrite(ledPin,LOW);
  • Step 2. The LED will be on when vibration is detected.
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)
Hardware
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - Piezo Vibration
  • Step 2. Plug the Grove Base Hat into Raspberry.
  • Step 3. Connect the Grove - Piezo Vibration Sensor to port 12 of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
note
For step 3 you are able to connect the piezo vibration sensor to **any GPIO Port** but make sure you change the command with the corresponding port number.
Software
note
 If you are using **Raspberry Pi with Raspberrypi OS >= Bullseye**, you have to use this command line **only with Python3**.
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Download the source file by cloning the grove.py library.
cd ~
  • Step 3. Excute below commands to run the code.
cd grove.py/grove
python3 grove_piezo_vibration_sensor.py 12
Following is the grove_piezo_vibration_sensor.py code.
import time
from grove.gpio import GPIO
class GrovePiezoVibrationSensor(GPIO):
def __init__(self, pin):
super(GrovePiezoVibrationSensor, self).__init__(pin, GPIO.IN)
self._on_detect = None
@property
def on_detect(self):
return self._on_detect
@on_detect.setter
def on_detect(self, callback):
if not callable(callback):
return
if self.on_event is None:
self.on_event = self._handle_event
self._on_detect = callback
def _handle_event(self, pin, value):
if value:
if callable(self._on_detect):
self._on_detect()
Grove = GrovePiezoVibrationSensor
def main():
import sys
if len(sys.argv) < 2:
print('Usage: {} pin'.format(sys.argv[0]))
sys.exit(1)
pir = GrovePiezoVibrationSensor(int(sys.argv[1]))
def callback():
print('Detected.')
pir.on_detect = callback
while True:
time.sleep(1)
if __name__ == '__main__':
main()
If everything goes well, you will be able to see the following result
pi@raspberrypi:~/grove.py/grove $ python3 grove_piezo_vibration_sensor.py 12
Detected.
Detected.
Detected.
Detected.
Detected.
Detected.
Detected.
Detected.
File "grove_piezo_vibration_sensor.py", line 84, in <module>
main()
File "grove_piezo_vibration_sensor.py", line 80, in main
time.sleep(1)
KeyboardInterrupt
You can quit this program by simply press ++ctrl+c++.
Play With Raspberry Pi (with GrovePi_Plus)
Hardware
Raspberry piGrovePi_PlusGrove - Piezo Vibration
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove-Piezo Vibration to A0 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC through USB cable.
Software
note
  • Step 2. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
  • Step 3. Excute below commands to detect the vibration.
cd ~/GrovePi/Software/Python
Here is the grove_piezo_vibration_sensor.py code.
import time
import grovepi
# Connect the Grove Piezo Vibration Sensor to analog port A0
# OUT,NC,VCC,GND
piezo = 0
grovepi.pinMode(piezo,"INPUT")
while True:
try:
# When vibration is detected, the sensor outputs a logic high signal
print grovepi.analogRead(piezo)
time.sleep(.5)
except IOError:
print "Error"
  • Step 4. We will see the vibration display on terminal as below.
pi@raspberrypi:~/GrovePi/Software/Python $ python3 grove_piezo_vibration_sensor.py
1023
1023
1023
1023
18
17
18
17
note
We also can use grovepi.digitalRead(2) to read the vibration status with attaching the sensor to D2 port of GrovePi.
FAQs
Q1: Is it digital or analog output?
A1: It is digital output, Low or High.
Schematic Online Viewer
Projects
Grove Starter Kit For Arduino - Piezo Vibration Sensor: Teaches you how to use the Piezo vibration sensor in the Arduino Grove starter kit.
Seat Monitor: Using ARTIK cloud to monitor cabin seat state.
