Grove - Turbidity Sensor Meter for Arduino V1.0
The Grove turbidity sensor can measure the turbidity of the water (the number of suspended particles).
The optical sensor of this module can measure the density of turbid water and the concentration of extraneous matter using the refraction of wavelength between photo transistor and diode. By using an optical transistor and optical diodes, an optical sensor measures the amount of light coming from the source of the light to the light receiver, in order to calculate turbidity of water.
The output mode can be selected by adjusting the switch on the board. Supports analog and digital output. The sensitivity can be adjusted by the on-board knob.
Features​
  • Low power consumption
  • Small size: 2.0cm x 4.0cm Grove module
  • Only 3 pins needed, save I/O resources
  • Easy to use: Grove connector, plug and play
  • Output mode optional, support analog output and digital output
Specification​
ParameterValue/Range
Operating Voltage3.3V/5V DC
Output InterfaceAnalog / Digital
Connector1 Grove / 1 Power interface
Size20*40mm
Typical applications​
  • Measure the water pollution degree of washing machines such as dishwashers to determine the optimal washing time and rinsing times.
  • Industrial site control.
  • Environmental wastewater treatment.
Hardware Overview​
  • Digital to Analog Switch
  • "D" is the digital output, the threshold of high and low level can be adjusted by on-board knob.
  • "A" is the analog output, the output value will decrease with the increase of liquid turbidity.
Platforms Supported​
ArduinoRaspberry PiBeagleBoneWioLinkIt ONE
caution
Getting Started​
Play With Arduino​
note
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Materials required
Seeeduino V4.2Grove - Turbidity SensorBase Shield
Get One NowGet One NowGet One Now
note
1 Please plug the USB cable gently, otherwise you may damage the port. Please use the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not sure about the wire you have, you can click here to buy.
2 Each Grove module comes with a Grove cable when you buy. In case you lose the Grove cable, you can click here to buy.
Analog Output​
Hardware Connection​
  • Step 1. The switch on the sensor selects A.
  • Step 1. Connect Grove - Turbidity Sensor to port A0 of Grove-Base Shield.
  • Step 2. Plug Grove - Base Shield into Seeeduino.
  • Step 3. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove - Turbidity Sensor to Seeeduino as below.
SeeeduinoGrove - Turbidity Sensor
5VRed
GNDBlack
Not ConenctedWhite
A0Yellow
Software​
  • Step 1. Copy the code below into Arduino IDE and upload. If you do not know how to upload the code, please check how to upload code.
Serial.begin(9600); //Baud rate: 9600
int sensorValue = analogRead(A0);// read the input on analog pin 0:
float voltage = sensorValue * (5.0 / 1024.0); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
Serial.println(voltage); // print out the value you read:
delay(500);
  • Step 2. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor or tap the Ctrl+Shift+M key at the same time. Set the baud rate to 9600.
  • Step 3. Now you can use this sensor, and the output will be like this:
Digital Output​
  • Step 1. The switch on the sensor selects D.
  • Step 1. Connect Grove - Turbidity Sensor to port D2 of Grove-Base Shield.
note
5VRed
GNDBlack
Not ConenctedWhite
D2Yellow
Software​
int ledPin = 3;
int sensor_in = 2; // Turbidity sensor on Digital Pin 2
void setup(){
Serial.begin(9600);
pinMode(ledPin, OUTPUT); // Set ledPin as output mode
pinMode(sensor_in, INPUT); //Set Turbidity sensor pin to input mode
void loop(){
int sensorValue = digitalRead(sensor_in);
Serial.println(sensorValue);
if(sensorValue==HIGH){ //Read sensor signal
digitalWrite(ledPin, HIGH); // if sensor is LOW, then turn on
}else{
digitalWrite(ledPin, LOW); // if sensor is HIGH, then turn off the led
delay(500);
  • Step 2. We use digital output and raise or lower the trigger by adjusting the potentiometer to make the LED turn on and off.
Schematic Online Viewer​
Resources​
Upgradable to Industrial Sensors​
