Grove - NFC Tag is a highly integrated Near Field Communication Tag module,this module is I2C interface,which base on M24LR64E-R,M24LR64E-R have a 64-bit unique identifier and 64 -Kbit EEPROM.Grove - NFC Tag attach an independent PCB antenna which can easily stretch out of any enclosure you use, leaving more room for you to design the exterior of your project.
Specifications
- Working Voltage:5V or 3V3
- Working Current<1mA
- Effective range<2cm
- Serve for contactless communication at 13.56MHz
- ISO 15693 and ISO 18000-3 mode 1 compatible
- 64-bit unique identifier (UID)
- Read Block & Write (32-bit blocks)
- Grove I2C Interface
Platforms Supported
Arduino | Raspberry Pi | |||
Usage
Read/Write from Mobile
- Download NfcV-reader for Android and install it
- We can Read/Write it from Mobile
Control LED
- Hardware Installation
- Download NFC Tag Lib, rename it to NFC_Tag_M24LR6E and put it into Arduino's library .
- Open Arduino IDE. If Arduino IDE is already opened, restart it.
- In Arduino IDE, click menus: File -> Example -> NFC_Tag_M24LR6E -> ledControl
- Now, you can control LED from your phone.
#include "NfcTag.h"
#include <Wire.h>
NfcTag nfcTag;
int led = 5;
bool flag = false;
bool preFlag = false;
void setup(){
Serial.begin(9600);
pinMode(led,OUTPUT);
nfcTag.init();
void loop(){
flag = nfcTag.readByte(EEPROM_I2C_LENGTH-1) == 0xff?true:false;
if(flag != preFlag){
Serial.println("get remote NFC control signal!");
if(flag == true){
Serial.println("led will light up!");
digitalWrite(led,HIGH);
}else{
Serial.println("led will turn dark!");
digitalWrite(led,LOW);
preFlag = flag;
delay(5*1000);
Schematic Online Viewer
- Grove - NFC Tag.PDF
- Grove - NFC Tag Eagle file
- M24LR64E-R datasheet.pdf
- NfcV-reader for Android
- NFC Tag M24LR6E Lib
