edit
Rainbow Cube Kit Acrylic Harness
Rainbow Cube Kit Acrylic Harness is an exquisite, Transparent and easy-to-assembled acrylic case which custom made for Rainbow_Cube_Kit_Acrylic_Harness Kit, it is designed by Riley Porter @Synthetos. This Harness is made of six piece of acrylic board, two bags of keys, four 16mm high plastic column and several screw nuts.
Pay Attention: when disassemble the box, please pay attention and follow the disassembling note:
The keys are not strong enough to withstand hard stretching. To disassemble the box, you should use your left hand to push the two legs and at the same time use your right hand to pull the key out. This is illustrated in the image below:
Tech Support
Please submit any technical issue into our forum or drop mail to techsupport@seeed.cc.
