Seeeduino V2.2 Atmega 168P
Seeeduino is Arduino compatible board. Its design is based on Diecimila scheme, 100% compatible to its existing program, shield and IDEs. On the hardware part, remarkable changes are taken to improve the flexibility and user experience.
Model:ARD130D2P
Inherits all of Arduino Diecimila's features.
Compatible to Diecimila's pin layout, screw hole and dimensions.
Evolved with SMD components
Improved on extensibility and convenience
Licensing
This documentation is licensed under the Creative Commons Attribution-Noncommercial-Share Alike License 3.0.Source code and libraries are licensed under GPL/LGPL, see source code files for details.
The Version Update history
v2.2
USB/EXT power auto select
Upgrade power capacitor
Clean up layouts
Reset easier
Real Quartz Crystal
Extern power Diode change to 1N4004(more power on Vin pin)
V2.12
Zero external power consumption when switched off
Stronger Switches
Second power supply for 5V direct input. [Caution] USE 5V ONLY!
150mA driver capacity under 3.3V
1.0mm slim PCB for lighter weighs
Extra row reserved for pin headers
V1.1
Fixed bug - unnessesary via on Pin4 wire.
Fixed bug - Lable mistakenly covered by switches.
Added I2C and sensor port.
Added an 100uF capacitor for vcc switch.
Grouped new 100mil grid pins.
Replaced reset buttons with metal ones.
Rearranged texts and lables for clearer indications.
Support
If you have questions or other better design ideas, you can go to our forum or wish to discuss.
Version Tracker
| Revision | Descriptions | Release Date |
| Seeeduino V0.9 | Initial public release | |
| Seeeduino V1.1 | - | |
| Seeeduino V2.12 | - | |
| Seeeduino V2.2 | - |
Bug Tracker
Bug Tracker is the place you can publish any bugs you think you might have found during use. Please write down what you have to say, your answers will help us improve our products.
Additional Idea
The Additional Idea is the place to write your project ideas about this product, or other usages you've found. Or you can write them on Projects page.
How to buy
Here to buy Seeeduino V2.2 Atmega 168P and Atmega 328P
