Deploy YOLOv8 object detection model
This wiki will introduce how to train the official YOLOv8 target detection model and deploy the trained model to the Grove Vision AI (V2) device or XIAO ESP32S3 devices..
Dataset preparation
It is recommended to use the roboflow platform for datasets. This platform can perform data set annotation and some data enhancement strategies, and supports the export of multiple data set formats.
Install YOLOv8 command line tool
- By default, you already have the
pythonenvironment andpippackage management tool, and python>=3.8.
- pip
- conda
- Git
Install the ultralytics package, or by running pip install -U ultralytics. Please visit the Python Package Index (PyPI) to learn more about the ultralytics package at https://pypi.org/project/ultralytics/.
# Install using pip
pip install ultralytics
# Chinese users can use mirror acceleration
# pip install ultralytics -i https://pypi.tuna.tsinghua.edu.cn/simple
Conda is an alternative package manager to pip and can also be used for installation. Visit Anaconda for more details: https://anaconda.org/conda-forge/ultralytics . The Ultralytics feedstock repository for updating conda packages is located at https://github.com/conda-forge/ultralytics-feedstock/.
# Install using conda
conda install -c conda-forge ultralytics
Clone ultralytics If you are interested in participating in development, or wish to experiment with the latest source code, please visit the repository. After cloning, navigate to the directory and install the package in developer mode using the -e parameter.
# Clone the official repository
git clone https://github.com/ultralytics/ultralytics
# Go into the cloned folder
cd ultralytics
# Install in developer mode
pip install -e .
Tips: If you are not familiar with the YOLOv8 code, it is recommended that you use pip or conda to install it.
- You can use the version query command to test whether the
yolocommand line tool is successfully installed.
# version query
yolo -v
Train
First, go to the downloaded data set folder
Execute the following command to start training the model
yolo train detect model=yolov8n.pt data=./data.yaml imgsz=192
Export model to tflite
- After training, the model will be in the
runs/train/exp*/weights/folder. Make sure that the evaluation indicators of your model meet your needs. - Use the following command to export the
tflitemodel
yolo export model=${your model path} format=tflite imgsz=192 int8
- You will then see a
yolov8n_saved_modelfolder under the current folder, which contains theyolov8n_full_integer_quant.tflitemodel file,This model file can be deployed toGrove Vision AI(V2)orXIAO ESP32S3devices.
Model graph optimization
- Grove Vision AI (V2) supports vela-optimized models and can also accelerate model inference. First, execute the following command to install the vela command line tool (
XIAO ESP32S3device is not supported yet)
pip3 install ethos-u-vela
- After that, you need to download
velarelated configuration file, or copy the following content into a file, which can be namedvela_config.ini
; file: my_vela_cfg.ini ; -----------------------------------------------------------------------------
; Vela configuration file ; -----------------------------------------------------------------------------
; System Configuration
; My_Sys_Cfg
[System_Config.My_Sys_Cfg]
core_clock=400e6
axi0_port=Sram
axi1_port=OffChipFlash
Sram_clock_scale=1.0
Sram_burst_length=32
Sram_read_latency=16
Sram_write_latency=16
Dram_clock_scale=0.75
Dram_burst_length=128
Dram_read_latency=500
Dram_write_latency=250
OnChipFlash_clock_scale=0.25
OffChipFlash_clock_scale=0.015625
OffChipFlash_burst_length=32
OffChipFlash_read_latency=64
OffChipFlash_write_latency=64
; Memory Mode
; My_Mem_Mode_Parent
[Memory_Mode.My_Mem_Mode_Parent]
const_mem_area=Axi1
arena_mem_area=Axi0
cache_mem_area=Axi0
- Finally, use the following command to optimize the graph
vela --accelerator-config ethos-u55-64 \
--config vela_config.ini \
--system-config My_Sys_Cfg \
--memory-mode My_Mem_Mode_Parent \
--output-dir ${Save path of the optimized model} \
${The path of the tflite model that needs to be optimized}
After execution, a graph-optimized tflite model will be generated in the path specified by --output-dir.
Deploy
The model file that needs to be deployed is the
tflitefile exported above. You can burn the model file to the target device according to the following tutorial. -
We strongly recommend using our web tool to burn the trained tflite model into the device. Detailed operations are provided in the Deployment Tutorial
Note: Since the ESP32S3 device does not support model deployment after vela graph optimization, you do not need to perform tflite model graph optimization if you want to deploy the model to the XIAO ESP32S3 device.
