125Khz RFID module - UART
RDM 125KHz card mini-module is designed for reading code from 125KHz card compatible read-only tags and read/write card . It can be applied in office/home security, personal identification, access control, anti-forgery, interactive toy and production control systems etc.
Note: Module will notify whenever 125khz tag approaches, tag serial number will be send via TX pin. Easy way for a RFID module on MCU projects or PC connnection via UartSB.
- Support external antenna
- Maximum effective distance up to 50mm
- Less than 100ms decoding time
- UART TTL interface
- Support EM4100 compatible read only or read/write tags
- Built-in external bi-color LED and buzzer driver
- Small outline design
May include key specification and other specifications.
Key Specification
| Frequency | 125KHz |
| Baud Rate | 9600 (TTL Electricity Level RS232 format) |
| interface | Weigang26 Or TTL Electricity Level RS232 format |
| Power supply | DC 5V(±5%) |
| Current | <50Ma |
| Operating range | >50mm(Depend on Card/Tag shape, manufacturer) |
| Expand I/O port | N/A |
| Indication light | N/A |
| Working temperature | -10℃~ +70℃ |
| Storage temperature | -20℃~ +80℃ |
| Max. humidity | Relative humidity 0 ~ 95% |
| Size | 38.5mm ×19mm×9mm |
Pin definition and Rating
Look the image below(Mechanic Dimensions), and check the pin definition list here:
Pin Definition : P1: PIN1 TX PIN2 RX PIN3 PIN4 GND PIN5 +5V(DC) P2: PIN1 ANT1 PIN2 ANT2 P3: PIN1 LED PIN2 +5V(DC) PIN3 GND
Mechanic Dimensions
Usage
TTL Interface RS232 Data output format
- 9600bps,N,8,1
- CHECKSUM: card 10byte DATA entire do XOR operation
| 02 | 10ASCII Data Characters | Chechsum | 03 |
Example: card number: 62E3086CED
- Output data:36H、32H、45H、33H、30H、38H、36H、43H、45H、44H
- CHECKSUM: (62H) XOR (E3H) XOR (08H) XOR (6CH) XOR (EDH)=08H
Time sequence chart
Exampel
Output date(HEX): 02 | 30 31 30 30 30 37 33 34 45 30 | 44 32 | 03 ->Change to Decimal CardNumber Decimal: 48 49 48 48 48 55 51 52 69 48 CheckSum Decimal: 68 50 ->Refer to ASCII table,get Ascill value CardNumber Ascill: 0 1 0 0 0 7 3 4 E 0 CheckSum Ascill : D 2 (01H) xor (00H) xor (07H) xor (34H) xor (E0H) = D2H
Programming
Connect RX/TX to Arduino UART port , Uart demo code :
Serial.begin(9600);
if(Serial.available())
while(Serial.available())
Serial.write(Serial.read());
Datasheet: RDM630-Spec.pdf
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
