Getting Started with Allxon on NVIDIA® Jetson Devices
Allxon is an essential edge device management solution that simplifies and optimizes business operations management by bonding together the AI/IoT ecosystem: hardware (IHV), software (ISV), and service providers (SI/MSP). As an ecosystem bonder, Allxon is the spark that ignites fast, seamless connectivity to keep all systems ON.
You can securely manage NVIDIA® JetPack 4.6 onward versions with Cyber Security at the Edge protecting all networks and hardware. Allxon integrates exclusive threat intelligence by Trend Micro IoT Security™ (TMIS) to ensure you receive multi-layered protection.
Allxon brings in-band and out-of-band remote device management services to all edge devices to help businesses save on time and cut out exponential labor costs. By simply navigating on an easy-to-use single cloud portal, businesses can effortlessly optimize and streamline their services.
Hardware Supported
Prerequisites
- Any of the above Jetson Devices
- Latest Jetson OS already installed on the Jetson Device
- Monitor, keyboard, mouse (optional)
Getting Started
Getting started with Allxon only takes a couple of minutes!
- Hardware Wiring Introduction
- Sign Up for Allxon Account
- Install Allxon DMS Agent on Jetson Device
- Get Device Pairing Code
- Add Jetson Device to Allxon DMS Portal
Pin Define for OOB Enabler main board and the corresponding color of the cable.
Here, we will use the wiring diagram of OBB and Jetson Orin Nano as an example. The following information provides wiring examples for the NVIDIA® Jetson™ Orin Nano Dev Kit.
We have also provided a schematic diagram of the wiring.
Step 1. Visit this page to sign up for an Allxon account
Step 2. Enter your email address and proceed
Step 3. Verify the account from the activation email you receive and create a password
Installing Allxon DMS Agent is a very easy process. You only need to execute one command!
- Step 1. Access the Jetson Device, open terminal and execute the following
sudo wget -qO - "https://get.allxon.net/linux/standard" | sudo bash -s
Note: The above command will install Allxon DMS Agent and the related packages
- Step 2. At the end of the installation, it will ask whether you want to install Trend Micro IoT Security™ as an add-on edge security services and agree to the TMIS EULA. You can enter Y to proceed with this installation
Note: Trend Micro IoT Security™ will be installed as a 3-month free trial
After installation, The Allxon DMS Agent will start automatically.
Note: If you have connected the Jetson Device to a display, you will see Allxon DMS Agent window pop up. If it does not show up, press Ctrl + Shift + B to start the agent.
First we need to get a device pairting code from our Jetson Device. You can either obtain this code from the GUI or command-line
Using GUI
Step 1. Open Allxon DMS Agent by pressing Ctrl + Shift + B on the Jetson Device
Step 2. Click Get device pairing code to obtain the code
Using Command-line
- Step 1. Execute the following to obtain the code
dms-get-pairing-code
Step 1. Login to Allxon DMS Portal with the previosly used credentials
Step 2. Click Devices from the left navigation panel and click on + Add Device
- Step 3. Click Next, enter previously obtained device pairing code and click Next
- Step 4. You will see the following window if the pairing is successful
Note: If you have a promotion code, you can click Next and redeem it. Otherwise, you can press Skip to finish the setup.
Allxon DMS Portal
After that Jetson Device is paired with Allxon DMS Portal, you will see the connected device under Devices page
If you click on the device, you will see more information for your device. Now you can remotely monitor and manage your device with Allxon DMS Portal!
[Web Page] Allxon Resource Center
[Web Page] NVIDIA Learn
