Arduino Software I2C User Guide
The standard I2C library for the Arduino is the Wire library. While this library is sufficient most of the time, there are situations when it cannot be used:
- the I2C pins A4/A5 (or SDA/SCL) are in use already for other purposes
- same I2C addresses devices are used
So we write the SoftwareI2C library to use digit port and analog port to enable multiple same I2C addresses devices work on Arduino.
I2C Scanner for Arduino
I2C Scanner is a simple sketch that scans the I2C-Bus for devices. You can upload the code to your Arduino to find out the I2C address of the modules. Upload the below sketch and open the Serial Monitor to view results:
#include <Wire.h>
Wire.begin();
Serial.begin(9600);
while (!Serial); // Wait for serial monitor
Serial.println("---I2C Scanner---");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
Wire.beginTransmission(address);
error = Wire.endTransmission();
Wire.beginTransmission(address+1);
if (error == 0 && Wire.endTransmission() != 0 ) // Special flag for SAMD Series
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println("!");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
Install SoftwareI2C Library
- Please follow how to install an arduino library procedures to install library.
- We provide an Arduino Library for SoftwareI2C, click on here to download it.
Example#1: Scan I2C device address
Connection
Here we will show you how this works via a simple demo. First of all, you need to prepare the below stuffs:
| Seeeduino V4.2 | Grove - OLED Display 1.12" | Base Shield |
| Get ONE Now | Get ONE Now | Get ONE Now |
This is an easy-to-use module, what you need to do is connect the module to D2 port of a Base Shield.
If you don't have the base shield, please follow below connection.
| Arduino Pin | OLED Pin |
| Digit 3 | SDA |
| Digit 2 | SCL |
| VCC | VCC |
| GND | GND |
Software
- Open the code directly by the path: File -> Example ->Arduino_Software_I2C-master->SoftwareI2C_Scan.
#include "SoftwareI2C.h"
SoftwareI2C softwarei2c;
softwarei2c.begin(3, 2); // sda, scl
Serial.println("begin to scan...");
for(unsigned char i=1; i<=127; i++)
if(softwarei2c.beginTransmission(i))
Serial.print("0x");
Serial.println(i, HEX);
while(1);
softwarei2c.endTransmission();
Serial.println("find nothing");
while(1);
- Upload the code to arduino.
- Please configure serial port baud rate as 115200.
- We can see I2C address from the serial monitor.
Example#2: Display different information on 2 Grove - OLED Display 1.12
Connection
| Seeeduino V4 | Grove - OLED Display 1.12`` | Base Shield |
- Connect one Grove - OLED Display 1.12 to D2 port and other to D4 port.
Software
Click on here to download Grove-OLED-Display-1.12 library.
Copy SeeedGrayOLED.cpp and SeeedGrayOLED.h to Arduino_Software_I2C-master folder
Edit SeeedGrayOLED.cpp
- Step1: Change the library from Wire.h to SoftwareI2C.h
From
#include "Wire.h"
To
#include <SoftwareI2C.h>
- Step2: Add initSoftwareI2C function, we have to change the class name for different products.
void SeeedGrayOLED::initSoftwareI2C(SoftwareI2C *w, int __sda, int __scl)
Wire = w;
Wire->begin(__sda, __scl);
- Step3: Replace all
Wire.toWire->For example, changeWire.endTransmission()toWire->endTransmission().
From
To
Wire->endTransmission();
Edit SeeedGrayOLED.h
Wire.htoSoftwareI2C.h
From
#include "Wire.h"
To
- Step2: Add initSoftwareI2C function into public class
void initSoftwareI2C(SoftwareI2C *w, int __sda, int __scl);
- Step3: Add SoftwareI2C *Wire into private class
SoftwareI2C *Wire;
- Open the code directly by the path: File -> Example ->Arduino_Software_I2C-master->OLED_Display.
- We have to define SoftwareI2C objects as well as SeeedGrayOLED objects.
//define 2 SoftwareI2C objects
SoftwareI2C WireS1;
SoftwareI2C WireS2;
//define 2 SeeedGrayOLED objects
#include "SeeedGrayOLED.h"
#include <avr/pgmspace.h>
SeeedGrayOLED SeeedGrayOled1;
SeeedGrayOLED SeeedGrayOled2;
- We use initSoftwareI2C instead of Wire.begin during setup.
SeeedGrayOled1.initSoftwareI2C(&WireS1, 3, 2); // initSoftwareI2C, sda, scl
SoftwareI2C WireS1;
SoftwareI2C WireS2;
SeeedGrayOled1.init(SSD1327);
SeeedGrayOled1.clearDisplay(); //Clear Display.
SeeedGrayOled1.setNormalDisplay(); //Set Normal Display Mode
SeeedGrayOled1.setVerticalMode(); // Set to vertical mode for displaying text
for(char i=0; i < 12 ; i++)
SeeedGrayOled1.setTextXY(i,0); //set Cursor to ith line, 0th column
SeeedGrayOled1.setGrayLevel(i); //Set Grayscale level. Any number between 0 - 15.
SeeedGrayOled1.putString("11111111"); //Print 11111111
SeeedGrayOled2.initSoftwareI2C(&WireS2, 5, 4); // initSoftwareI2C, sda, scl
SeeedGrayOled2.init(SSD1327); //initialize SEEED OLED display
SeeedGrayOled2.clearDisplay(); //Clear Display.
SeeedGrayOled2.setNormalDisplay(); //Set Normal Display Mode
SeeedGrayOled2.setVerticalMode(); // Set to vertical mode for displaying text
SeeedGrayOled2.setTextXY(i,0); //set Cursor to ith line, 0th column
SeeedGrayOled2.setGrayLevel(i); //Set Grayscale level. Any number between 0 - 15.
SeeedGrayOled2.putString("00000000"); //Print 00000000
- Upload to Sketch.
- We will see 11111111 display on one screen while 00000000 is on other.
APIs of the library
- begin() function: SoftwareI2C.begin() must first be called to start any software I2C communication using the SoftwareI2C library.
SoftwareI2C::begin(int Sda, int Scl)
- beginTransmission function: Used when the ATmega is acting as an I2C master. Sets internal variables in the SoftwareI2C library in preparation for transmitting to the given address.
SoftwareI2C.beginTransmission(uchar addr)
- endTransmission() function: end for transmitting to the given address.
SoftwareI2C.endTransmission()
- write function: Populate the send data buffer with the data found in the argument list. there are 2 functions. One is sending a byte and other is array.
SoftwareI2C.write(uchar dta)
SoftwareI2C::write(uchar len, uchar *dta)
- read function: Returns the byte in receive buffer.
SoftwareI2C.read()
References
- [Library]Arduino SoftwareI2C Library
