Basic Fastener Kit
Basic Fastener Kit contains many standard components, including Screws,nuts,rivers,cableties etc. The parts can be used in fastening different pieces in mechanical designs(such as building robots), isolating or fastening PCB, connecting shells etc. This box can help makers get rid of the annoyance of searching for Standard parts. It is compact ,light in weight and portable, providing convenience to makers.
| Part Name | Specification | Description | Image | Quantity |
| Rivet | R2056 | White nylon | ![]() | 20 |
| R2064 | Black nylon | ![]() | 20 | |
| R3075 | ![]() | 20 | ||
| R3100 | ![]() | 20 | ||
| Screw | M2X8 | Hardware & Cross head | ![]() | 40 |
| M3X6 | ![]() | 20 | ||
| M3X8 | ![]() | 20 | ||
| M3X12 | ![]() | 20 | ||
| M3X16 | ![]() | 20 | ||
| Nut | M2X1.7 | Hardware & | ![]() | 40 |
| M3X2.5 | ![]() | 50 | ||
| Copper Column | M3X6+6 | single head | ![]() | 12 |
| M3X12+6 | Double pass | ![]() | 12 | |
| M3X20+6 | ![]() | 12 | ||
| Hollow Column | ø3X3 | ABS | ![]() | 12 |
| ø3X8 | ![]() | 12 | ||
| ø4X12 | ![]() | 12 | ||
| Plastic Column | M3X12+6 | Nylon (A single head) | ![]() | 12 |
| Cable Tie | 3X60mm | Nylon | ![]() | 20 |
| Shim | ø3X1.2 | Nylon | ![]() | 50 |
| Rubber Pad | ø8X2.5 | Transparent silicone | ![]() | 20 |
Usage
Here is an example that used some parts of this Basic Fastener Kit. If you have similar projects, the Basic Fastener Kit is necessary.
