edit
How to Make File System, Compile u-boot and Linux Kernel
attention icon
Disclaimer
Please note that this guide is for the use of the pre-production beta version of BeagleV™ - StarLight
Hardware Needed
  • BeagleV™ - Starlight
  • Micro-SD Card (16GB or more)
  • PC with Linux OS or Mac
  • USB to Serial Converter
  • Ethernet Cable
  • Power Adapter
  • USB Type-C Cable
Note: In this guide, Ubuntu 20.04 LTS is installed on the host PC
Set Up Compilation Environment
First we need to set up the compilation environment. There are 3 ways to do this. You can use any method of your choice. Please note the following, according to the method you use.
  • Method 1: Use pre-compiled cross-compile. To compile using this method, use CROSS_COMPILE=riscv64-unknown-linux-gnu-
  • Method 2: Set up your own cross-compile. To compile using this method, use CROSS_COMPILE=riscv64-linux-gnu-
  • Method 3: Use Docker Fedora cross-compile. To compile using this method, use CROSS_COMPILE=riscv64-linux-gnu-
In this guide, method 2 is used, where CROSS_COMPILE=riscv64-linux-gnu-
Method 1: Use Pre-Compiled Cross-Compile (riscv64-unknown-linux-gnu-gcc)
  • Step 1. Click this link to download a pre-compiled compiler (riscv64-unknown-linux-gnu-gcc)
  • Step 2. Extract the file to a directory of your choice
  • Step 3. Open a terminal window and add the compiler to your PATH
export PATH=/home/user/gcc10.2.0/gcc/bin:$PATH
Note: Point to the directory that you extracted the file before
  • Step 4. Check the version of the riscv64-unknown-linux-gnu-gcc
riscv64-unknown-linux-gnu-gcc -v
Method 2: Set Up Your Own Cross-Compile (riscv64-linux-gnu-gcc)
  • Step 1. Install the riscv64-linux-gnu-gcc compiler from Ubuntu packages
sudo apt update
sudo apt upgrade
sudo apt install gcc-riscv64-linux-gnu
  • Step 2. Check the version of the riscv64-linux-gnu-gcc
riscv64-linux-gnu-gcc -v
The output will be as follows:
Now we need to add elfutils and zlib libraries into cross-compile
  • Step 3. Visit this link and download the latest .tar.gz of zlib
  • Step 4. Extract the file and navigate to the extracted directory
tar -zxvf zlib-1.2.11.tar.gz
cd zlib-1.2.11
  • Step 5. Install vim text editor if you have not installed before. You can skip this step if you have it already
sudo apt install vim
  • Step 6. Create a script inside the directory and open using vim text editor
vim zlib-build.sh
  • Step 7. Copy the following and paste inside the script
#!/bin/bash
mkdir build
CHOST=riscv CC=riscv64-linux-gnu-gcc \
AR=riscv64-linux-gnu-ar \
RANLIB=riscv64-linux-gnu-ranlib \
./configure
make && make install
  • Step 8. Press ESC and type :x to save and exit from the file
  • Step 9. Modify the permissions of zlib-build.sh
chmod +x zlib-build.sh
  • Step 10. Run the script
sudo ./zlib-build.sh
The final lines of the output will be as follows:
  • Step 11. Visit this link and download the latest .tar.bz2 of ulfutils
  • Step 12. Extract the file and navigate to the extracted directory
tar -jxvf elfutils-latest.tar.bz2
cd elfutils-0.183
  • Step 13. Create a script inside the directory and open using vim text editor
vim elfutil-build.sh
  • Step 14. Copy the following, paste inside the script and save the file
#!/bin/bash
mkdir build
#export LDFLAGS=-L
#export CPPFLAGS=-I
#export LIBS=-lz
./configure --host=riscv64-linux-gnu --enable-libdebuginfod=dummy --disable-debuginfod --prefix=/usr --libdir=/lib
  • Step 15. Modify the permissions of elfutil-build.sh
chmod +x elfutil-build.sh
  • Step 16. Run the script
sudo ./elfutil-build.sh
Method 3: Use Docker Fedora Cross-Compile (riscv64-linux-gnu-gcc)
Let's start by installing Docker. If you have installed Docker already, you can start from step xx
  • Step 1. Update your existing pckages list
sudo apt update
  • Step 2. Install a few prerequisite packages which let apt use packages over HTTPS
sudo apt install apt-transport-https ca-certificates curl software-properties-common
  • Step 3. Add the GPG key for the official Docker repository to your system
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
  • Step 4. Add the Docker repository to APT sources
sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu focal stable"
  • Step 5. Update the package database with the Docker packages from the newly added repo
sudo apt update
  • Step 6. Make sure you are about to install from the Docker repo instead of the default Ubuntu repo
apt-cache policy docker-ce
  • Step 7. Install Docker
sudo apt install docker-ce
  • Step 8. Docker should now be installed, the daemon started, and the process enabled to start on boot. Check that it’s running
sudo systemctl status docker
  • Step 9. Install Fedora container
sudo docker pull fedora:33
  • Step 10. Start the Fedora container
sudo docker run -v $(dirname $PWD):/workspace -w /workspace -it fedora:33
  • Step 11. Install the necessary dependencies inside the container
dnf update
dnf install make ncurses-devel gcc-riscv64-linux-gnu findutils bc perl xz openssl openssl-devel git flex bison elfutils-libelf-devel cpio
  • Step 12. Check the version of the riscv64-linux-gnu-gcc
Compile u-boot
Now we need to compile the u-boot for BeagleV™ - Starlight. Follow the steps below
  • Step 1. Move into your desired directory to store the uboot files
Example:
cd ~ # home directory
  • Step 2. Download the source code for uboot compilation
git clone https://github.com/starfive-tech/u-boot
  • Step 3. Inside the u-boot directory, type the following to compile u-boot
cd u-boot
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv starfive_vic7100_beagle_v_smode_defconfig
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv u-boot.bin u-boot.dtb
There will be these 2 files generated after compilation inside the u-boot directory: u-boot.bin and u-boot.dtb
Note: The u-boot.dtb file will be used later in this guide when we try to move rootfs, uboot and kernel to BeagleV, whereas both u-boot.dtb and u-boot.bin will be used next for OpenSBI compilation
Compile OpenSBI
OpenSBI stands for Open-Source Supervisor Binary Interface and it is an open-source implementation of the RISC-V Supervisor Binary Interface. It is a RISC-V specific runtime service provider and it is typically used in boot stage following ROM and LOADER. A typical boot flow is as follows:
Now we need to compile OpenSBI for BeagleV™ - Starlight. Follow the steps below
  • Step 1. Move into your desired directory to store the OpenSBI files
Example:
  • Step 2. Download the source code for OpenSBI compilation
git clone https://github.com/starfive-tech/opensbi
  • Step 3. Inside opensbi directory, type the following to compile openSBI
cd opensbi
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv PLATFORM=starfive/vic7100 FW_PAYLOAD_PATH={U-BOOT_PATH}/u-boot.bin FW_PAYLOAD_FDT_PATH={U-BOOT_PATH}/u-boot.dtb
Note: Modify the path to the path of u-boot from before
The file will be generated in the directory opensbi/build/platform/starfive/vic7100/firmware as fw_payload.bin after compilation and the size is about 700+K
  • Step 4. Navigate to the directory containing fw_payload.bin
cd opensbi/build/platform/starfive/vic7100/firmware
  • Step 5 Copy the file fw_payload.bin to a different location
cp fw_payload.bin /home/user/Desktop
  • Step 6. Navigate to the copied location and execute the following to install an image conversion tool
cd /home/user/Desktop
sudo apt install subversion
svn export https://github.com/starfive-tech/freelight-u-sdk.git/branches/starfive/fsz.sh
Note: Here is the source code
  • Step 7. Change the user rights of the tool
chmod 777 fsz.sh
  • Step 8. Convert the file from fw_payload.bin to fw_payload.bin.out
./fsz.sh fw_payload.bin fw_payload.bin.out
Note: You will see a new file named fw_payload.bin.out generated
Flash uboot
Let's move on to flash the fw_payload.bin.out file generated before to BeagleV™ - StarLight. This fw_payload file is the result of OpenSBI and uboot both compiled together
  • Step 1. Connect one end of the USB Type-C cable to the USB Type-C port on the BeagleV™ - StarLight and connect the other end of the cable to the power adapter
  • Step 2. Connect the jumper wires from the USB to Serial Converter to the 40-Pin GPIO header of the BeagleV™ - StarLight as follows
  • Step 3. Connect power adapter to wall power socket
  • Step 4. Open a terminal window on host PC
  • Step 5. Type the following to update the packages list
sudo apt-get update
  • Step 6. Install minicom, which is a serial communication software that helps to establish a serial communcation between your host PC and BeagleV™ - StarLight
sudo apt-get install minicom
  • Step 7. Connect the USB To Serial Converter to the PC
  • Step 8. Type the following in the terminal to view the connected serial devices
dmesg | grep tty
  • Step 9. Connect to the serial device by typing the following
minicom -D /dev/ttyACM0 -b 115200
Note: The baud rate is set to 115200
  • Step 10. After the hardware connections mentioned above, turn on the power from the wall power socket to power on the BeagleV™ - StarLight and you will see the startup information as follows
  • Step 11. Press any key as soon as it starts up to enter the upgrade menu. In this menu, you can update uboot
  • Step 12. Type "0" and press Enter to update uboot
  • Step 13. Press Ctrl+A and then press s to enter upload mode
  • Step 14. Select xmodem and press Enter
  • Step 15. Select Goto from the bottom tab menu and press Enter
  • Step 16. Enter the directory path and press Enter
  • Step 17. Select fw_payload.bin.out by navigating using arrow keys ,press Space and press Enter
If you see the following output, that means you have successfully transferred the fw_payload.bin.out file to BeagleV™ - Starlight.
Compile Linux Kernel
Now we need to compile Linux Kernel for BeagleV™ - Starlight. Follow the steps below
  • Step 1. Move into your desired directory to store the Linux Kernel files
Example:
  • Step 2. Download the source code for Linux Kernel
git clone https://github.com/starfive-tech/linux
  • Step 3. Type the following to set the default configuration settings for compiling Linux Kernel
cd linux
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv starfive_vic7100_evb_sd_net_fedora_defconfig
  • Step 4. Type the following to set additional configuration settings for compiling Linux Kernel. If you did step 3, this step is not necessary.
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv menuconfig
  • Step 5. Finally compile the Linux Kernel
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv -jx
Note: Here you need to change the -jx value according to the number of cores in your CPU. If your CPU has 8 cores, change this to -j8. This process will take some time and therefore please wait patiently
You will see the following output after compilation
The kernel image will be generated as Image.gz inside the linux/arch/riscv/boot directory
Make File System
Now we need to make the file system. Follow the steps below to proceed
  • Step 1. Create the directory structure
mkdir rootfs
cd rootfs
mkdir dev usr bin sbin lib etc proc tmp sys var root mnt
  • Step 2. Download the busybox source code outside the rootfs directory
git clone https://git.busybox.net/busybox
  • Step 3. Navigate to the extracted location and enter busybox configuration
cd busybox
  • Step 4. Navigate to Settings > Build Options and check Build static binary (no shared libs) by pressing y
  • Step 5. Under Build Options, select cross compiler prefix and type the following to specify the compiler
riscv64-linux-gnu-
  • Step 6. Under Installation Options > Destination path for 'make install', change the path to the path of the rootfs file directory (this is the installation location of the compiled busybox)
Example:
/home/user/rootfs
  • Step 7. Exit from the busybox configuration window and save the configuration
  • Step 8. Compile busybox
make ARCH=riscv
  • Step 9. Install busybox
make install
  • Step 10. Navigate to the rootfs/etc directory created before, create a file called inittab and open it using vim text editor
cd rootfs/etc
vim inittab
  • Step 11. Copy and paste the following content inside the inittab file
::sysinit:/etc/init.d/rcS
::respawn:-/bin/login
::restart:/sbin/init
::ctrlaltdel:/sbin/reboot
::shutdown:/bin/umount -a -r
::shutdown:/sbin/swapoff -a
  • Step 12. Create a file called profile inside rootfs/etc and open it using vim text editor
vim profile
  • Step 13. Copy and paste the following content inside the profile file
# /etc/profile: system-wide .profile file for the Bourne shells
echo
#echo -n "Processing /etc/profile... "
# no-op
# Set search library path
#echo "Set search library path in /etc/profile"
export LD_LIBRARY_PATH=/lib:/usr/lib
# Set user path
#echo "Set user path in /etc/profile"
PATH=/bin:/sbin:/usr/bin:/usr/sbin
export PATH
# Set PS1
#Note: In addition to the SHELL variable, ash supports \u, \h, \W, \$, \!, \n, \w, \nnn (octal numbers corresponding to ASCII characters)
#And \e[xx;xxm (color effects), etc.
#Also add an extra '\' in front of it!
#echo "Set PS1 in /etc/profile"
export PS1="\\e[00;32m[$USER@\\w\\a]\\$\\e[00;34m"
#echo "Done"
  • Step 14. Create a file called fstab inside rootfs/etc and open it using vim text editor
vim fstab
  • Step 15. Copy and paste the following content inside the fstab file
proc    /proc   proc    defaults    0   0
none    /tmp    tmpfs   defaults    0   0
mdev    /dev    tmpfs   defaults    0   0
sysfs   /sys    sysfs   defaults    0   0
  • Step 16. Create a file called passwd inside rootfs/etc and open it using vim text editor
vim passwd
  • Step 17. Copy and paste the following content inside the passwd file
root:x:0:0:root:/root:/bin/sh
  • Step 18. Create a file called group inside rootfs/etc and open it using vim text editor
vim group
  • Step 19. Copy and paste the following content inside the group file
root:x:0:root
  • Step 20. Create a file called shadow inside rootfs/etc and open it using vim text editor
vim shadow
  • Step 21. Copy and paste the following content inside the shadow file
root:BAy5qvelNWKns:1:0:99999:7:::
  • Step 22. Create a directory called init.d inside rootfs/etc and navigate inside it
mkdir init.d
cd init.d
  • Step 23. Create a file called rcS inside rootfs/etc/init.d and open it using vim text editor
vim rcS
  • Step 24. Copy and paste the following content inside the rcS file
#! /bin/sh
#echo "----------mount all"
/bin/mount -a
#echo "----------Starting mdev......"
#/bin/echo /sbin/mdev > /proc/sys/kernel/hotplug
mdev -s
echo "********************************************************"
echo " starfive mini RISC-V Rootfs"
  • Step 25. Navigate to the rootfs/dev directory created before and execute the following
cd rootfs/dev
sudo mknod -m 666 console c 5 1
sudo mknod -m 666 null c 1 3
  • Step 26. Create a soft link in the root directory of rootfs
cd rootfs/
ln -s bin/busybox init
  • Step 27. Modify the permissions of all files in the rootfs directory
sudo chmod 777 -R *
  • Step 28. Execute the following command in the rootfs directory to generate rootfs.cpio.gz (cpio file system package) in a different directory
cd rootfs
find . | cpio -o -H newc | gzip > /home/user/Desktop/rootfs.cpio.gz
Note: After you sucessfully run the above command, you will see a file named rootfs.cpio.gz on your Desktop. This directory can be any directory of your choice.
Move rootfs, kernel and uboot into BeagleV™ - Starlight
Start by moving the previously compiled rootfs file system package, kernel and uboot images into a single directory
Method 1: Using Micro-SD Card
  • Step 1. Insert a micro-sd card to the host PC
  • Step 2. Type the following to see the location of the connected micro-SD card
lsblk
For example, it's /dev/sdc
  • Step 3. Type the following to enter the partition configuration
sudo gdisk /dev/sdc
  • Step 4. Delete the original partition and then create a new partition by entering the following respectively
d--->o--->n--->w--->y
Note: Press Enter to keep some settings to default in this configuration
  • Step 5. Format the micro-sd card and create the file system
sudo mkfs.vfat /dev/sdc1
  • Step 6. Remove the micro-sd card from PC and plug again to mount it
  • Step 7. Enter the following to check whether it gets mounted
df -h
You will see an output as follows and take a note of the mount location:
  • Step 8. Navigate to the directory containing the 3 images as before
Example:
cd Desktop/compiled
  • Step 9. Copy the files to the micro-sd card by typing the following
sudo cp Image.gz /media/user/4714-3C2D/
sudo cp rootfs.cpio.gz /media/user/4714-3C2D/
sudo cp u-boot.dtb /media/user/4714-3C2D/
sync
Note: Here /media/user/4714-3C2D/ is the mount location as shown above
  • Step 10. Remove the micro-sd card from PC, insert into BeagleV™ - Starlight and turn it on
  • Step 11. Open minicom while USB to Serial Adapter is connected between BeagleV™ - Starlight and PC, and wait until the board enters uboot mode. You will see the following output when it is in uboot mode
  • Step 12. Enter the following commands
fatls mmc 0:1
fatload mmc 0:1 ${kernel_addr_r} Image.gz
fatload mmc 0:1 ${fdt_addr_r} u-boot.dtb
fatload mmc 0:1 ${ramdisk_addr_r} rootfs.cpio.gz
booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r}
  • Step 13. Log in by typing the following credentials
Username:root
Password:starfive
Method 2: Using Ethernet Cable
  • Step 1. Connect an Ethernet Cable from the RJ45 port of BeagleV™ - Starlight to a router, connect serial adapter cable and power on the board
Note: Make sure the host PC is also connected to the same router using Ethernet or Wi-Fi
  • Step 2. Open minicom and wait until board enters uboot mode. You will see the following output when it is in uboot mode
  • Step 3. Enter the following commands to set ubooot environment variables
setenv serverip 192.168.1.5;setenv ipaddr 192.168.1.33;setenv hostname starfive;setenv netdev eth0;setenv kernel_comp_addr_r 0x90000000;setenv kernel_comp_size 0x10000000; setenv bootargs console=ttyS0,115200 earlycon=sbi root=/dev/ram0 stmmaceth=chain_mode:1 loglevel=8
Note: In general the default IP of a router is 192.168.1.1. In this case, use the server IP as the IP assigned by the DHCP server of the router and use the BeagleV IP as 192.168.1.xxx. However, if your router IP is different (ex: 192.168.2.1), the server and BeagleV should follow the IP format of 192.168.2.xxx.
  • Step 4. Check the connectivity by pinging the host PC from BeagleV™ - Starlight
Example:
ping 192.168.1.5
If you see the following output, the host PC and BeagleV™ - Starlight has established a communication on the same network
  • Step 5. Install a tftp server on the Host PC
sudo apt-get update
sudo apt install tftpd-hpa
  • Step 6. Check the status of the server
sudo systemctl status tftpd-hpa
  • Step 7. Execute the following to enter the tftp server configuration
sudo nano /etc/default/tftpd-hpa
  • Step 8. Configure the tftp server as follows
# /etc/default/tftpd-hpa
TFTP_USERNAME="tftp"
TFTP_DIRECTORY="/home/user/Desktop/compiled"
TFTP_ADDRESS=":69"
TFTP_OPTIONS="--secure"
Note: The TFTP_DIRECTORY is the directory that we created before with all the 3 images (Image.gz, u-boot.dtb, rootfs.cpio.gz)
  • Step 9. Restart the tftp server
sudo systemctl restart tftpd-hpa
  • Step 10. Type the following inside the uboot mode of BeagleV™ - Starlight to download the files from the tftp server of the host PC and start the kernel
tftpboot ${fdt_addr_r}  u-boot.dtb;tftpboot ${kernel_addr_r} Image.gz;tftpboot ${ramdisk_addr_r} rootfs.cpio.gz;booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r}
  • Step 11. Log in with the following credentials
Username:root
Password:starfive
