Bluetooth Bee
Save that extra Arduino you have lying around for another project, this two-for-one device has the Arduino built-in. Bluetooth Bee with Arduino is an enhanced version of the Bluetooth Bee. We added an onboard ATMEGA168 to it to make it a full-featured Arduino while maintaining the same footprint and instruction set as the Bluetooth Bee. Plus, it still allows you to stack it on XBee Carrier, XBee® Shield, and UartSBee for expansion or reprogramming.
- Small footprint
- Identical settings and pairing methods as the Bluetooth Bee
- Software serial port adopted between the Bluetooth module and ATMEGA168
- Remains compatibile with XBee Carrier, XBee® Shield, and UartsBee for expansion
Hardware Features
- Typical -80dBm sensitivity.
- Up to +4dBm RF transmit power.
- Fully Qualified Bluetooth V2.0+EDR 3Mbps Modulation.
- 3.3v Power
- Integrated PCB antenna.
- Disconnect and monitor the Bluetooth via Software.
- xBee compatible headers.
Software Features
- Use the SoftSerial program to communication.
- Default Baud rate: 38400, Data bits:8, Stop bit:1,Parity:No parity, Data control: has.
- Supported baud rate: 9600,19200,38400,57600,115200,230400,460800.
- Use CTS and RTS to control the data stream.
- Disconnecte the Bluetooth via a rising edge on PC2
- Status instruction port PB2: low-disconnected, high-connected;
- PIO10 is connected to red led, PIO11 is connected to blue led. When master and slave are paired, red and blue led blinks 1time / 2s in interval, while disconnected only blue led blinks 2 times/ s.
- Auto-connect the last device on power as default.
- Permit matched device connect by default.
- Default PINCODE:”0000”.
- Auto-reconnect in 30 min when disconnected as a result of beyond the range of connection.
Application Ideas
- Arduino compatilbe module with Bluetooth communication.
*3.3 V power needed.
- While using with UartSBee, set the operation voltage to 3.3V
- Command to change baud rate is persistent even after reset. Hence remember the baud rate for next use.
Pin definition and Rating
Bottom-view:
PD4 - PD7 = Arduino IDE digital pins 4 - 7 (5,6 PWM)
PB0 , PB1 = Arduino IDE digital pins 8 , 9 (9 PWM)
PC0 - PC3 = Arduino IDE analog pins 0 - 3 (Note PC2 Disconnects the Bluetooth via a rising edge)
Usage
- Step 1
Connect Grove-Red_LED and Bluetooth Bee-Standalone module to XBee carrier like this.
- Step 2
Write a program by Arduino-IDE to read informations from the Bluetooth Softserial port and identify to shut or turn on the LED.
BluetoothBee Demo Code - Flowcontrol Based Implementation
2010,2011 Copyright (c) Seeed Technology Inc. All right reserved.
Author: Visweswara R Modify:Joinj
This demo code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
For more details about the product please check https://www.seeedstudio.com/depot/
/* Upload this sketch to Seeeduino and press reset*/
#include <NewSoftSerial.h> //Software Serial Port
#define RxD 2
#define TxD 3
#define DEBUG_ENABLED 1
NewSoftSerial blueToothSerial(RxD,TxD);
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
pinMode(5,OUTPUT);
setupBlueToothConnection();
unsigned char control;
unsigned char temp;
while(temp!='4') {
temp=blueToothSerial.read();
Serial.println("You are connected");
blueToothSerial.print("You are connected"); //You can write you BT communication logic here
while(1) {
switch(temp) {
case 'O':{while(temp!='N') {temp=blueToothSerial.read();} digitalWrite(5,HIGH);break;}
case 'S':{while(temp!='H') {temp=blueToothSerial.read();} digitalWrite(5,LOW);break;}
default:break;
void setupBlueToothConnection()
blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
sendBlueToothCommand("\r\n+STWMOD=0\r\n");
sendBlueToothCommand("\r\n+STNA=SeeedBluetooth-st\r\n");
sendBlueToothCommand("\r\n+STAUTO=0\r\n");
sendBlueToothCommand("\r\n+STOAUT=1\r\n");
sendBlueToothCommand("\r\n +STPIN=0000\r\n");
delay(2000); // This delay is required.
sendBlueToothCommand("\r\n+INQ=1\r\n");
//Checks if the response "OK" is received
void CheckOK()
char a,b;
while(1)
if(blueToothSerial.available())
a = blueToothSerial.read();
if('O' == a)
// Wait for next character K. available() is required in some cases, as K is not immediately available.
while(blueToothSerial.available())
b = blueToothSerial.read();
break;
if('K' == b)
break;
while( (a = blueToothSerial.read()) != -1)
//Wait until all other response chars are received
void sendBlueToothCommand(char command[])
blueToothSerial.print(command);
CheckOK();
- Step 3
Connect the XBee carrier to computer with USB-cable and uploading the program to ATMEGA168 on the Bluetooth Bee-Standalone.
- Step 4
Remove the USB-cable form XBee carrier and connect the 3.7-Voltage battery to XBee carrier like this.
- Step 5
Additional ideas
Schematic Online Viewer
Information on how to setup connections between Bluetooth Bees is available in Seeedstudio Forum.
Information on PC connecting Bluetooth Bee in Seeedstudio Forum
