Bracket for Infrared Proximity Sensor
This is an aluminum infrared proximity sensor bracket kit for Infrared Proximity Sensor. With this kit,one RB-421 Servo and one Infrared Proximity Sensor you can build a 2 degrees freedom servo mount assembly. This kit is professional in steering the infrared proxinity sensor on a robot for 180° of rotation side to side and front to back. These parts also have holes at 20mm spacings so they can be attached to Seeed (https://www.seeedstudio.com/depot/starter-bundle-harness-p-906.html?cPath=178_184)Starter Bundle Harness which has 20mm spacings as well.
Application Ideas
- Robot eyes
- IR self controller
Mechanic Dimensions
Usage
Hardware Installation
For holding IR sensors while you can turn it with different angles
Bill of Materials (BOM) /parts list
| Devic | Value | Manufacturer | Details(size:mm) |
| IR sensor bracket(10034R0) | 1 | ||
| angle mounting bracket(10034R0) | 1 | ||
| Plastic rivet | 2 | HKWASI | D3x5.5(diameter 3 length 5.5 ,black) |
| Plastic rivet | 10 | HKWASI | D2X4.8(diameter 2 length 4.8 ,black) |
| selflocking plastic rope | 2 | 2x56 |
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
