Breakout for LinkIt Smart 7688 v2.0
danger
Due to the closure of MediaTek Labs, all related links have become invalid. If you need to download relevant files, please search for them on the following link: https://github.com/MediaTek-Labs.
Breakout for LinkIt Smart 7688 v2.0 is a Grove port integrated expansion board for LinkItTM Smart 7688 development board. This breakout board will help beginners to get started fast because it can save a lot of work and make prototyping easier through simplified wiring. It comes with USB, Ethernet, and 3.5mm Audio ports and supports serial buses like I2C, UART.
Version Tracker
Product reversionRelease dateSupport statusNotes
Version 1.0November 2015SupportedNone
Version 2.0April 2016SupportedRefer to New Features
New features:
  • Support recording functionality.
  • For 3.5 mm phone connector (audio jack), it supports the protocol OMTP and CTIA. You can use either protocol by toggling a switch. About how to switch protocol, we will please sroll down the page to read How to switch phone connector protocol between OMTP and CTIA
enter image description here
Features​
  • Grove interface makes wiring easier and allows expansions with Grove modules.
  • USB host
  • Audio Output
  • Ethernet port
  • Cost-effective
  • Switch between OMTP and CTIA
Application ideas​
  • IoT/Gateway Device.
  • Robotics
  • Smart multimedia devices
  • Teaching and learning
Specification​
Input voltageOperating voltage
5.0V(With USB Power port)3.3V
note
Debug pins, Ethernet pins and USB type-A host pins connect with MT7688, other pins connect with ATmega32U4.
Hardware Overview​
HardwareQtyHardwareQtyHardwareQty
Debug port1Headset port1Aux Pins2
Ethernet port1Pins to switch protocol6Grove Connector3
USB type-A1Stereo Speaker driver interface1Headset port1
About Grove interface​
If you ever used Seeed's Grove products, you will fell in love with this kind of modules. With this kind of ports, you can say goodbye to jumper wire and soldering work, and you can make more powerful applications with those functional modules.
How to switch phone connector protocol between OMTP and CTIA​
If you compare V1.0 and V2.0, you can notice that there are six pins and two jumper caps on bottom-right corner. These pins are used to switch phone connector protocol. As you set tiny jumper(both) to left-four pin, protocol OMTP is used. As you set tiny jumper(both) to right-four pin (as preceded figure shows), protocol CTIA is used. As following figures show: Breakout for LinkIt Smart 7688 v2.0 CTIA OMTP Switch Manner.JPG Note that to use the recording functionality, you need to update on-board firmware to Breakout for LinkIt Smart 7688 firmware(above version v0.9.2).
note
  • Because the Write/Read speed of on-board flash memory is limited, We recommend you to use external storage device.
Get started​
In this tutorial, you are going to make a simple MP3 player with Breakout for LinkIt Smart 7688 V2.0.
Material required​
Except Breakout for Linkit Smart 7688 V2.0, here are other materials that is needed for the application. Before you start, please make sure you have every thing on hand, or you can visit Seeed Bazaar to get them.
LinkIt Smart 7688 × 1USB cable (type A to micro type-B) × 2UARTBee × 1Jumper wires × 3
Get One NowGet One NowGet One NowGet One Now
For below 2, I think you surely have them.
  • Stereo Speaker(with 3.5 mm audio cable) × 1
  • USB flash disk (with audio file of MP3 format inside) × 1
Step1: Refer here to connect your LinkIt Smart 7688 to Internet.
note
You can plug jumper wires to MT7688 UART2 port instead soldering them to Pin 8, Pin 9 and Pin GND.
note
In rare cases, you might not connect to Internet successfully, reboot the embedded OS.
Step2: Open a console with USB to Serial adapter.
Step3: Connect all parts like follows:
note
This is a figure of Breakout for LinkIt Smart 7688(v1.0).
Step4: Enter folder of USB by type cd /Media/USB-A1 in console.
Step5: Play music with utility Madplay(installed on OpenWRT) by typing madplay filename.mp3 into console.
Step6: Now you will hear the music.
Schematic Online Viewer​
Resources​
Project​
Smart Vendy Tracking vendor sales so that effectively manage what inventory needs to buy to fill machines before it gets out of stock.
