Compiling MicroPython for embedded devices
What is MicroPython
MicroPython is a software implementation of a programming language largely compatible with Python 3, written in C, that is optimized to run on a microcontroller.
MicroPython consists of a Python compiler to bytecode and a runtime interpreter of that bytecode. The user is presented with an interactive prompt (the REPL) to execute supported commands immediately. Included are a selection of core Python libraries; MicroPython includes modules which give the programmer access to low-level hardware.
How to build firmware (Let's use Xiao SAMD as an example)
Seeeduino XIAO SAMD already supports micropython development.
First: Prepare the relevant software
"arm-none-linux-gnueabi" is the toolchain that can be installed in Debian-based systems using a package manager like apt (the package is called gcc-arm-linux-gnueabi). On Ubuntu the arm-none-linux-gnueabi is included in ubertooth-firmware-source , We also need to prepare the environment by installing the necessary tools such as gcc python and git make. So we execute this command
sudo apt update
sudo apt install cmake make gcc ubertooth-firmware-source python3 git
Second: Switching workspaces Cloning source code
Clone the source code and download the code for the necessary sub-modules
Execute the following statements in sequence
cd ~
git clone https://github.com/micropython/micropython
cd ~/micropython
The information we will download is in this file, which contains the path to the download and the address of the code repository
cat ~/micropython/.gitmodules
Third: Build the mpy-cross , MicroPython cross-compiler
Most ports require the MicroPython cross-compiler to be built first. This program, called mpy-cross, is used to pre-compile Python scripts to .mpy files which can then be included (frozen) into the firmware/executable for a port. To build mpy-cross use:
cd ~/micropython/mpy-cross
make
Next : Build external dependencies
We use the Seeeduino XIAO SAMD already supports micropython development.. It is a controller based on the arm architecture samd chip. So we specify the version number and go to the corresponding directory and compile:
cd ~/micropython/ports/samd
BOARD=SEEED_XIAO make V=1
Finally :Burning firmware
we can see the generated firmware here, we copy the firmware to the device and the micro python is available on the XIAO SAMD
ls ~/micropython/ports/samd/build-SEEED_XIAO/ |grep firmware.uf2
sudo cp ~/micropython/ports/samd/build-SEEED_XIAO/firmware.uf2 /media/$USER/Arduino/
Test our firmware
Copy the code below and you will see the blue led flashing
from machine import Pin, Timer
led = Pin(19, Pin.OUT)
Counter = 0
def fun(tim):
global Counter
Counter = Counter + 1
state = Counter%2
led.value(state)
tim = Timer(-1)
tim.init(period=1000, mode=Timer.PERIODIC, callback=fun)
As you can see Seeeduino XIAO SAMD already supports micropython development.
You can also refer to this process to compile micropython firmware for other devices.
