Connect Wio Terminal to Microsoft Azure IoT Central
Introduction
In this tutorial, we will walk you through the process of connecting the Wio Terminal to Microsoft Azure IoT Central and send telemetry data from the onboard sensors/ hardware on the Wio Terminal such as the 3-axis accelerometer, light sensor, 3 buttons to Microsoft Azure IoT Central. Then you will be able to visualize the sensor data on interactive dashboards. Also you will be able to use Azure IoT Central to control hardware such as beeping the onboard buzzer on the Wio Terminal. Microsoft Azure IoT Central supports HTTP, MQTT and AMQP protocols for communication, but, however we will be using the MQTT protocol in this tutorial.
What is Microsoft Azure?
Microsoft Azure is Microsoft's public cloud computing platform. You can use Microsoft Azure to build, test, deploy, and manage applications and services through Microsoft-managed data centers.
Also, it provides a range of cloud services, including compute, analytics, storage and networking. Microsoft Azure provides software as a service (SaaS), platform as a service (PaaS), Infrastructure as a service (IaaS) and serverless. Finally, it supports many different programming languages, tools and frameworks.
What is Microsoft Azure IoT?
Microsoft Azure IoT is a collection of Microsoft-managed cloud services that connect, monitor, and control billions of IoT assets. It includes security and operating systems for devices and equipment, along with data and analytics that help businesses to build, deploy and manage IoT applications.
What is Microsoft Azure IoT Central?
Microsoft Azure IoT Central is a fully managed global IoT SaaS (software as a service) solution that makes it easy to connect, monitor and manage your IoT assets at scale. It is highly secure, scales with your business as it grows, ensures that your investments are repeatable and integrates with your existing business apps. It also bridges the gap between your business applications and IoT data. Finally it offers centralized management to reconfigure and update your devices.
What is IoT Plug and Play?
IoT Plug and Play enables solutions builders to integrate smart devices with their solutions without any manual configuration. At the core of IoT Plug and Play, is a device model that a device uses to advertise its capabilities to an IoT Plug and Play-enabled application. It contains:
- Properties: represents the read-only or writable state of a device or other entity
- Telemetry: data sent by a device
- Commands: describes a function or operation that can be done on a device
IoT Plug and Play certified devices eliminate the hassle of configuring devices in Azure IoT Central, such as creating templates and adding features and interfaces.
IoT Plug and Play Certified Devices
IoT Plug and Play Certified Devices are devices listed in the Azure Certified Device Catalog with the IoT Plug and Play badge.
Wio Terminal is an IoT Plug and Play Certified Device.
To be IoT Plug and Play Certified, you will need to clear a few criteria, one of which is to publish a DTDL (Digital Twins Definition Language) model that defines the capabilities of the device to Azure/ iot-plugandplay-models (DMR) on GitHub.
This allows cloud services that use IoT Plug and Play Certified Devices to learn about device capabilities from this repository.
Connecting Wio Terminal to Microsoft Azure IoT Central via MQTT
As explained before, we will be using MQTT for the communication between the Wio Terminal and Microsoft Azure IoT Central. However, you may use the HTTP bridge as well, if that is your requirement.
Microsoft Azure IoT Central Set Up
First, you need to visit Microsoft Azure IoT Central, log in to your Microsoft account and create a new application for your project.
STEP 1: Visit here to create a new application
STEP 2: Click Build from the navigation menu on the left, and click Custom apps
Note: Log in to your Microsoft account if prompted
- STEP 3: Fill in Application name and choose Free under the Pricing plan.
Note: Application URL will be created automatically when you fill in application name
- STEP 4: Click Create to create the new application
Now you have successfully set up Azure IoT Central!
Set Up Wio Terminal
Update RTL8720 Firmware
We need to update the firmware for the Realtek RTL8720 wireless core on the Wio Terminal. Follow this wiki to update the RTL8720 firmware.
Note: Make sure to update the firmware according to the specified version under the description of the release.
Download and Upload Demo Code to Wio Terminal
We will first use a demo code that sends telemetry data from the onboard sensors on the Wio Terminal to Microsoft Azure IoT Central.
Download the Demo Code
- STEP 1: Navigate to this repo on GitHub
- STEP 2: Click on Releases
- STEP 3: Under the Latest release, click on wioterminal-aziot-example.uf2 to download the .uf2 file
Upload the Demo Code to Wio Terminal
- STEP 1: Connect the Wio Terminal to PC and turn in ON
- STEP 2: Enter Bootloader Mode by sliding down the power switch further away from "ON" position, release, slide again and release
Note: Once Wio Terminal is in the Bootloader mode, the blue LED will start to breathe in a way that is different from blinking
STEP 3: Open File Explorer on your PC and you will see a new external drive, named Arduino
STEP 4: Drag the previously downloaded .uf2 file into this Arduino drive.
STEP 5: Turn OFF the Wio Terminal
Now we have successfully uploaded the demo code into the Wio Terminal
Wi-Fi and Azure IoT Configuration
Next, let's move on to configuring Wi-Fi and Azure IoT connection
- STEP 1: Hold down on the 3 buttons and turn ON the Wio Terminal to enter the configuration mode
STEP 2: Open a serial console application such as PUTTY
STEP 3: Type the correct serial COM Port, set 9600 as the baud rate and enter the Wio Terminal
STEP 4: Press ENTER on the keyboard and type help in the serial terminal to view the configuration usage
STEP 5: Set Wi-Fi SSID by typing set_wifissid
your_WI-Fi_network_name
Note: Make sure to add a single space between the fields
- STEP 6: Set Wi-Fi Password by typing set_wifipwd
your_WI-Fi_network_password
STEP 7: Set connection information of Azure IoT by visiting the previously created application on Azure IoT Central
STEP 8: Navigate to
Administration > Device Connectionfrom the left navigation menu, and copy the ID scope into notepad -
STEP 9: Click on SAS-IoT-Devices and copy the primary key into notepad
STEP 10: Visit previously opened serial terminal and type set_az_iotc
your_ID_scopeyour_primary_keyyour_device_name
Note: Make sure to add a single space between each field and you can decide on a device name of your choice.
- STEP 11: Reset the Wio Terminal by sliding down the switch further away from the ON position and releasing
Now you will be able to see the Wio Terminal LCD displaying that it's connecting to Wi-Fi and then Azure IoT Hub. After that it will show the telemetry data being sent to Azure IoT Central.
Display Telemetry Data on Microsoft Azure IoT Central
We will move on to displaying the incoming telemetry data from the 3-axis accelerometer, light sensor and 3 buttons of the Wio Terminal on Azure IoT Central Dashboard.
STEP 1: Open Azure IoT Central Dashboard that you visited before
STEP 2: Click on Devices from the left navigation menu
STEP 3: You will see Seeed Wio Terminal appear under Devices. Click on it
STEP 4: Click on the entry with the device name that you configured before.
Now you will be able to visualize the data from the onboard 3-axis accelerometer on an interactive dashboard.
This is the default view and we need to make some changes to display the other telemetry data as well.
- STEP 5: Click on Device templates from the left navigation menu and click Seeed Wio Terminal to configure the template
- STEP 6: Click on Overview on the left navigation menu
- STEP 7: Collapse select a telemetry drop-down menu and select the telemetry that you want to visualize.
- STEP 8: Click Add tile and you will see the tile added into the Azure IoT Central Dashboard
Note: You can resize or change the visualization of the tiles according to your preference
- STEP 9: Repeat the same for the 3 buttons (left, center, right)
Note: Here we have configured the following:
| Tile Name | Tile Size | Tile Visualization |
| Light Intensity | 2 x 2 | Line chart |
| Left button | 1 x 1 | KPI |
| Right button | 1 x 1 | KPI |
| Center button | 2 x 2 | KPI |
- STEP 10: Click Save and Publish
- STEP 11: Go back to Azure IoT Central dashboard and you will be able to visualize all the data coming in from the Wio Terminal.
- STEP 12: You can also click on the Raw data tab to view all the telemetry data in real-time.
Add a Rule to Send an Email
Rules in IoT Central serve as a customizable response tool that trigger on actively monitored events from connected devices. For example, in this demo, we can set IoT Central to send an email when the light intensity level is below 50.
STEP 1: Click on Rules from the left navigation menu in Azure IoT Central.
STEP 2: Click on +New or Create a rule
STEP 3: Enter a name for the rule
STEP 4: Under Device template, select Seeed Wio Terminal
- STEP 5: Under Conditions, turn on time aggregation and select a time window of your choosing. Here we will set it as 5 minutes
Note: Every xx minutes, the rule evaluates once on the last xx minutes of data
STEP 6: Under Telemetry, select the telemetry of your chossing. Here we will set it as Light intensity
STEP 7: Under Aggregation, select Average. This will take the average value during the set time window before
STEP 8: Under Operator, select a condition of your choosing. Here we will use is less than condition
STEP 9: Under Value, type a value. Here we will type 50
STEP 10: Under Actions, click on Email
STEP 11: Type a Display name, To address and Note for the email
Note: Please note that the email address here should be added to this Azure IoT Central Application and also have signed-in at lease once.
- Navigate to
Administration > Users,click Assign user, fill in the Email, assign a Role and click Save
STEP 12: Click on Done
STEP 13: Finally, click Save
Now we have successfully created a rule to send an email
Control Hardware from Microsoft Azure IoT Central
You can not only view the telemetry data on Azure IoT Central, but also use it to control hardware as well. In this demo, we will be able to control the built-in buzzer on the Wio Terminal and specify a time duration in which the buzzer will beep
STEP 1: Click on the Command tab
STEP 2: Enter a value inside the column under Duration
Note: values are in milliseconds unit. ex: 1000 = 1000ms = 1s
- STEP 3: When you click Run, you will be able to hear a beeping sound from the buzzer for the time duration specified above
How to Add Other Sensors?
You can add any sensor to the Wio Terminal and send telemetry data from the connected sensor to Azure IoT Central. We will connect a Grove - Temperature & Humidity Sensor (DHT11) to the Wio Terminal and send temperature and humidity data to Azure IoT Central to visualize on dashboards!
Microsoft Visual Studio Code Set Up
Download, Install and Configure Visual Studio Code
If we want to add more sensors to the Wio Terminal in order to send telemetry data to Azure IoT Central, we cannot easily use the .uf2 file as we did before. Because the codes are already compiled inside that .uf2 file. So, if we want to add more codes to the demo, we need to use an IDE called Microsoft Visual Studio Code, add the necessary codes and finally upload them to the Wio Terminal.
So now, let's move on to installing Microsoft Visual Studio Code on the computer
- STEP 1: Visit code.visualstudio.com and click Download
Note: Choose the installer according to your operating system
STEP 2: Go through the installation wizard and complete the installation
STEP 3: Open Visual Studio Code
STEP 4: Click on Extensions from the left navigation menu and type platformIO in the search box
- STEP 5: Click install
Code for the Demo on Visual Studio Code
STEP 1: Visit this link to find the available releases inside the SeeedJP/wioterminal-aziot-example repo
STEP 2: Navigate to the Latest release and under Assets, click on Source code (zip). This will download the source code as a .zip file
STEP 3: Extract the .zip file
STEP 4: Go back to Visual Studio Code and navigate to
File > Open Folder... -
STEP 5: Choose the folder that we extracted before and click Select Folder
STEP 6: Navigate to
wioterminal-aziot-example-0.10 > include > config.hfrom the left navigation menu -
STEP 7: Once config.h is open, look for "dtmi:seeedkk:wioterminal:wioterminal_aziot_example;5" and change it to "dtmi:local:wioterminal_aziot_example;5"
Note: dtmi:local:wioterminal_aziot_example;5 is the Model ID
STEP 8: Navigate to
wioterminal-aziot-example-0.10 > seeedkk-wioterminal-wioterminal_aziot_example.jsonfrom the left navigation menu -
STEP 9: Once seeedkk-wioterminal-wioterminal_aziot_example.json is open, look for "dtmi:seeedkk:wioterminal:wioterminal_aziot_example;5" and change it to "dtmi:local:wioterminal_aziot_example;5" as well
Note: seeedkk-wioterminal-wioterminal_aziot_example.json is the DTDL model that we have mentioned before
Currently the model is defined for acceleration, light intensity and button count data. We will go ahead to add temperature and humidity to this DTDL model.
- STEP 10: Add the following codes below "contents": [:
"contents": [
"@type": [
"Telemetry",
"Temperature"
"name": "temp",
"unit": "degreeCelsius",
"displayName": {
"en": "Temperature (C)",
"ja": "温度"
"schema": "integer"
"@type": "Telemetry",
"name": "humi",
"displayName": {
"en": "Humidity (%RH)",
"ja": "湿度"
"schema": "integer"
Note: Here, name is what we will use to identify specific telemetry data later in the codes, unit is the unit corresponding to the data, displayName is the name which displays on Azure IoT Central ("en" for English/ "ja" for Japanese) and schema is the data type
STEP 11: Navigate to
wioterminal-aziot-example-0.10 > platformio.inifrom the left navigation menu -
STEP 12: Once platformio.ini is open, under lib_deps, add https://github.com/Seeed-Studio/Grove_Temperature_And_Humidity_Sensor
lib_deps =
Note: This is the library for Grove - Temperature and Humidity Sensor (DHT11)
STEP 13: Navigate to
wioterminal-aziot-example-0.10 > src > main.cppfrom the left navigation menu -
STEP 14: Once main.cpp is open, add the DHT11 library after the line #include "CliMode.h"
#include "DHT.h"
- STEP 15: Add the DHT11 definitions and the initializations after the line LIS3DHTR AccelSensor;
LIS3DHTR<TwoWire> AccelSensor;
#define DHTPIN 0 //Define signal pin of DHT sensor
// #define DHTPIN PIN_WIRE_SCL //Use I2C port as Digital Port */
#define DHTTYPE DHT11 //Define DHT sensor type
DHT dht(DHTPIN, DHTTYPE); //Initializing DHT sensor
Note: The DHT11 sensor can be connected to both the Grove Ports on the Wio Terminal. If Digital Port is used, pin can be defined as 0 and if I2C port is used, pin can be defined as PIN_WIRE_SCL. The port diagram will be shown later in this document
- STEP 16: Add the following codes under the SendTelemetry() function to parse the json file along with the telemetry data
static az_result SendTelemetry()
float accelX;
float accelY;
float accelZ;
AccelSensor.getAcceleration(&accelX, &accelY, &accelZ);
int light;
light = analogRead(WIO_LIGHT) * 100 / 1023;
int temp; //assign variable to store temperature
int humi; //assign variable to store humidity
temp = dht.readTemperature(); //read temperature
humi = dht.readHumidity(); //read humidity
char telemetry_topic[128];
if (az_result_failed(az_iot_hub_client_telemetry_get_publish_topic(&HubClient, NULL, telemetry_topic, sizeof(telemetry_topic), NULL)))
Log("Failed az_iot_hub_client_telemetry_get_publish_topic" DLM);
return AZ_ERROR_NOT_SUPPORTED;
az_json_writer json_builder;
char telemetry_payload[200];
AZ_RETURN_IF_FAILED(az_json_writer_init(&json_builder, AZ_SPAN_FROM_BUFFER(telemetry_payload), NULL));
AZ_RETURN_IF_FAILED(az_json_writer_append_begin_object(&json_builder));
AZ_RETURN_IF_FAILED(az_json_writer_append_property_name(&json_builder, AZ_SPAN_LITERAL_FROM_STR("temp")));
AZ_RETURN_IF_FAILED(az_json_writer_append_int32(&json_builder, temp));
AZ_RETURN_IF_FAILED(az_json_writer_append_property_name(&json_builder, AZ_SPAN_LITERAL_FROM_STR("humi")));
AZ_RETURN_IF_FAILED(az_json_writer_append_int32(&json_builder, humi));
- STEP 17: Add the following codes after the line ntp.begin, in order to start the DHT11 sensor
dht.begin(); //start DHT sensor
Now we have completed all the codes for this demo.
- STEP 18: Click PlatformIO icon from the left navigation menu and click Build
If you see the following message, you have successfully compiled the code:
================================== [SUCCESS] Took 30.56 seconds ==================================
Now we need to create a custom device template so that the data from the Wio Terminal can be visualized on Azure IoT Central Dashboard
Creating a New Device Template
STEP 1: Visit Azure IoT Central and click
Device templatesfrom the left navigation menu -
STEP 2: Click + New, click IoT device and click Next:Customize
STEP 3: Type a name inside Device template name box and click Next:Review
Importing a Custom Device Model
STEP 1: Click Import a model
STEP 2: Navigate to the wioterminal-aziot-example-0.10 folder that we used before, find seeedkk-wioterminal-wioterminal_aziot_example.json file and click on it
STEP 3: Click Open
STEP 4: Click Views from the left menu and click Generate default views
STEP 5: Click Generate default dashboard view(s)
STEP 6: Navigate to Overview from the left menu and customize the dashboard according to your preference.
Note: We have previously mentioned in this document, how to customize the dashboard
- STEP 7: Follow the below configuration
| Light Intensity | 1 x 1 | Last Known Value |
| Temperature (C), Humidity (%RH) | 2 x 2 | Line chart |
| Temperature (C) | 1 x 1 | Last Known Value |
| Humidity (%RH) | 1 x 1 | Last Known Value |
| Middle button | 1 x 1 | KPI |
- STEP 8: Click Save and Publish
Wio Terminal Set Up
Hardware Set Up
- Connect the Grove - Temperature and Humidity Sensor (DHT11) to Grove Digital Port on the Wio Terminal
Software Set Up
Upload Code to Wio Terminal
Now we need to upload the code to the Wio Terminal to send the telemetry data to Azure IoT Central
- STEP 1: Go back to VS Code, click PlatformIO icon and click Upload
Next, let's move on to configuring Wi-Fi and Azure IoT connection just like we did before
- STEP 4: Press ENTER on the keyboard and type help in the serial terminal to view the configuration usage
Note: Now we don't need to enter WiFi SSID and password because they are already saved from the previous configuration
STEP 5: Set connection information of Azure IoT by visiting the previously created application on Azure IoT Central
STEP 6: Navigate to
STEP 7: Click on SAS-IoT-Devices and copy the primary key into notepad
STEP 8: Visit previously opened serial terminal and type set_az_iotc
- STEP 9: Reset the Wio Terminal by sliding down the switch further away from the ON position and releasing
Now you will be able to see the Wio Terminal LCD displaying that it's connecting to Wi-Fi and then Azure IoT Hub. After that, it will show the telemetry data being sent to Azure IoT Central.
Visualize on Azure IoT Central
Go back to Azure IoT Central and from the left navigation menu, click Devices, click on your Device name
Now you will be able to visualize all the sensor data from the Wio Terminal on Microsoft Azure IoT Central Dashboard!
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
