DC framework miniature solenoid VL-0063
This 14.8-Volt DC framework miniature solenoid is for instantaneous power work and great for projects! These types of solenoid are often used for small automation system,can be used as a remote control etc. However, they work great for almost any project requiring a DC solenoid.
- Voltage: 14.8V DC
- Easily fixed and connected
- Low friction to ensure high efficiency and extend the life of
- Simple and reliable design
The solenoid operating temperature should not exceed 80 ℃, or continuous working time less than 5 seconds.
Application Ideas
- Vending machines, ticket vending machines,money exchange machine
- Office equipment: fax machines, punch card machines, copiers, typewriters, cash registers, plotters
- Transport equipment: automatic door locks, safety belt lock, automotive solenoid valve, parking facilities
- Appliances: tape recorder, video recorder, keyboard, automatic knitting machine, karaoke machine
- ¸ Other: packaging machine, robot, farming equipment, stamping equipment, alarm, water solenoid valve
Specifications
Operating conditions:
Operation temperature: -5 ℃ to 40 ℃, the solenoid valve will not solidification.
Operating humidity: 45% to 85%, the solenoid valve will not solidification.
Storage temperature: -40 ℃ to 75 ℃ in between, the solenoid valve will not solidification.
Storage Humidity: 0% to 95%, the solenoid valve will not solidification.
Performance to show:
Temperature: 65 ℃ or less, can be used for more than a million times.
Maximum working temperature shall not exceed 80 ℃.
Test temperature
Environment temperature23±2
Realative humidity50±10%
Air pressure1013MPa
Insulation resistanceneed 100MΩ insulating resistance when 500VDC insulator testing.
Insulation strengththe strength should be 600VAC/1 min DC standard product table.
