DC framework solenoid HCNE1-0520
This 12-Volt DC framework solenoid is great for projects! These types of solenoid are often used for automatic door locks,vending machines,robot etc. However, they work great for almost any project requiring a DC solenoid.
**The solenoid operating temperature should not exceed 80 ℃, or continuous working time less than 1 minute. **
Features​
  • Voltage: 12V DC
  • Stroke: 10mm
  • Suction: 4N
  • Outline size(mm): 13×15×20
  • Movable core: 3(g)
  • Loss efficiency: 6(W)
  • Gravitation: 0mm:400(g), 2mm:65g, 4mm:20g
  • Easily fixed and connected
  • Temperature stability, long product life and ensure good performance
  • E ring and rubber gasket make the operation of the solenoid valve mute
  • Low friction to ensure high efficiency and extend the life of
  • Simple and reliable design
Application Ideas​
  • Vending machines, ticket vending machines,money exchange machine
  • Office equipment: fax machines, punch card machines, copiers, typewriters, cash registers, plotters
  • Transport equipment: automatic door locks, safety belt lock, automotive solenoid valve, parking facilities
  • Appliances: tape recorder, video recorder, keyboard, automatic knitting machine, karaoke machine
  • Other: packaging machine, robot, farming equipment, stamping equipment, alarm, water solenoid valve
Specifications​
Operating conditions:
  • Operation temperature: -5 ℃ to 40 ℃, the solenoid valve will not solidification.
  • Operating humidity: 45% to 85%, the solenoid valve will not solidification.
  • Storage temperature: -40 ℃ to 75 ℃ in between, the solenoid valve will not solidification.
  • Storage Humidity: 0% to 95%, the solenoid valve will not solidification.
Performance to show:
  • Temperature: 65 ℃ or less, can be used for more than a million times.
  • Maximum working temperature shall not exceed 80 ℃.
No.Name
1 Fixed framework
2 Cover
3 Movable core
4 Fixed core
5 Solenoid axis
6 Solenoid
7 Conduit
Test temperature​
  • Environment temperature23±2
  • Realative humidity50±10%
  • Air pressure1013MPa
  • Insulation resistanceneed 100MΩ insulating resistance when 500VDC insulator testing.
  • Insulation strengththe strength should be 600VAC/1 min DC standard product table.
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
