Develop in Microsoft Azure IoT Central
Add a Rule to Send an Email
Rules in IoT Central serve as a customizable response tool that trigger on actively monitored events from connected devices. For example, in this demo, we can set IoT Central to send an email when the light intensity level is below 50.
STEP 1: Click on Rules from the left navigation menu in Azure IoT Central.
STEP 2: Click on +New or Create a rule
STEP 3: Enter a name for the rule
STEP 4: Under Device template, select Seeed Wio Terminal
- STEP 5: Under Conditions, turn on time aggregation and select a time window of your choosing. Here we will set it as 5 minutes
Note: Every xx minutes, the rule evaluates once on the last xx minutes of data
STEP 6: Under Telemetry, select the telemetry of your chossing. Here we will set it as Light intensity
STEP 7: Under Aggregation, select Average. This will take the average value during the set time window before
STEP 8: Under Operator, select a condition of your choosing. Here we will use is less than condition
STEP 9: Under Value, type a value. Here we will type 50
STEP 10: Under Actions, click on Email
STEP 11: Type a Display name, To address and Note for the email
Note: Please note that the email address here should be added to this Azure IoT Central Application and also have signed-in at lease once.
- Navigate to
Administration > Users,click Assign user, fill in the Email, assign a Role and click Save
STEP 12: Click on Done
STEP 13: Finally, click Save
Now we have successfully created a rule to send an email
Control Hardware from Microsoft Azure IoT Central
You can not only view the telemetry data on Azure IoT Central, but also use it to control hardware as well. In this demo, we will be able to control the built-in buzzer on the Wio Terminal and specify a time duration in which the buzzer will beep
STEP 1: Click on the Command tab
STEP 2: Enter a value inside the column under Duration
Note: values are in milliseconds unit. ex: 1000 = 1000ms = 1s
- STEP 3: When you click Run, you will be able to hear a beeping sound from the buzzer for the time duration specified above
How to Add Other Sensors?
You can add any sensor to the Wio Terminal and send telemetry data from the connected sensor to Azure IoT Central. We will connect a Grove - Temperature & Humidity Sensor (DHT11) to the Wio Terminal and send temperature and humidity data to Azure IoT Central to visualize on dashboards!
Microsoft Visual Studio Code Set Up
Download, Install and Configure Visual Studio Code
If we want to add more sensors to the Wio Terminal in order to send telemetry data to Azure IoT Central, we cannot easily use the .uf2 file as we did before. Because the codes are already compiled inside that .uf2 file. So, if we want to add more codes to the demo, we need to use an IDE called Microsoft Visual Studio Code, add the necessary codes and finally upload them to the Wio Terminal.
So now, let's move on to installing Microsoft Visual Studio Code on the computer
- STEP 1: Visit code.visualstudio.com and click Download
Note: Choose the installer according to your operating system
STEP 2: Go through the installation wizard and complete the installation
STEP 3: Open Visual Studio Code
STEP 4: Click on Extensions from the left navigation menu and type platformIO in the search box
- STEP 5: Click install
Code for the Demo on Visual Studio Code
STEP 1: Visit this link to find the available releases inside the SeeedJP/wioterminal-aziot-example repo
STEP 2: Navigate to the Latest release and under Assets, click on Source code (zip). This will download the source code as a .zip file
STEP 3: Extract the .zip file
STEP 4: Go back to Visual Studio Code and navigate to
File > Open Folder... -
STEP 5: Choose the folder that we extracted before and click Select Folder
STEP 6: Navigate to
wioterminal-aziot-example-0.10 > include > config.hfrom the left navigation menu -
STEP 7: Once config.h is open, look for "dtmi:seeedkk:wioterminal:wioterminal_aziot_example;5" and change it to "dtmi:local:wioterminal_aziot_example;5"
Note: dtmi:local:wioterminal_aziot_example;5 is the Model ID
STEP 8: Navigate to
wioterminal-aziot-example-0.10 > seeedkk-wioterminal-wioterminal_aziot_example.jsonfrom the left navigation menu -
STEP 9: Once seeedkk-wioterminal-wioterminal_aziot_example.json is open, look for "dtmi:seeedkk:wioterminal:wioterminal_aziot_example;5" and change it to "dtmi:local:wioterminal_aziot_example;5" as well
Note: seeedkk-wioterminal-wioterminal_aziot_example.json is the DTDL model that we have mentioned before
Currently the model is defined for acceleration, light intensity and button count data. We will go ahead to add temperature and humidity to this DTDL model.
- STEP 10: Add the following codes below "contents": [:
"contents": [
"@type": [
"Telemetry",
"Temperature"
"name": "temp",
"unit": "degreeCelsius",
"displayName": {
"en": "Temperature (C)",
"ja": "温度"
"schema": "integer"
"@type": "Telemetry",
"name": "humi",
"displayName": {
"en": "Humidity (%RH)",
"ja": "湿度"
"schema": "integer"
Note: Here, name is what we will use to identify specific telemetry data later in the codes, unit is the unit corresponding to the data, displayName is the name which displays on Azure IoT Central ("en" for English/ "ja" for Japanese) and schema is the data type
STEP 11: Navigate to
wioterminal-aziot-example-0.10 > platformio.inifrom the left navigation menu -
STEP 12: Once platformio.ini is open, under lib_deps, add https://github.com/Seeed-Studio/Grove_Temperature_And_Humidity_Sensor
lib_deps =
Note: This is the library for Grove - Temperature and Humidity Sensor (DHT11)
STEP 13: Navigate to
wioterminal-aziot-example-0.10 > src > main.cppfrom the left navigation menu -
STEP 14: Once main.cpp is open, add the DHT11 library after the line #include "CliMode.h"
#include "DHT.h"
- STEP 15: Add the DHT11 definitions and the initializations after the line LIS3DHTR AccelSensor;
LIS3DHTR<TwoWire> AccelSensor;
#define DHTPIN 0 //Define signal pin of DHT sensor
// #define DHTPIN PIN_WIRE_SCL //Use I2C port as Digital Port */
#define DHTTYPE DHT11 //Define DHT sensor type
DHT dht(DHTPIN, DHTTYPE); //Initializing DHT sensor
Note: The DHT11 sensor can be connected to both the Grove Ports on the Wio Terminal. If Digital Port is used, pin can be defined as 0 and if I2C port is used, pin can be defined as PIN_WIRE_SCL. The port diagram will be shown later in this document
- STEP 16: Add the following codes under the SendTelemetry() function to parse the json file along with the telemetry data
static az_result SendTelemetry()
float accelX;
float accelY;
float accelZ;
AccelSensor.getAcceleration(&accelX, &accelY, &accelZ);
int light;
light = analogRead(WIO_LIGHT) * 100 / 1023;
int temp; //assign variable to store temperature
int humi; //assign variable to store humidity
temp = dht.readTemperature(); //read temperature
humi = dht.readHumidity(); //read humidity
char telemetry_topic[128];
if (az_result_failed(az_iot_hub_client_telemetry_get_publish_topic(&HubClient, NULL, telemetry_topic, sizeof(telemetry_topic), NULL)))
Log("Failed az_iot_hub_client_telemetry_get_publish_topic" DLM);
return AZ_ERROR_NOT_SUPPORTED;
az_json_writer json_builder;
char telemetry_payload[200];
AZ_RETURN_IF_FAILED(az_json_writer_init(&json_builder, AZ_SPAN_FROM_BUFFER(telemetry_payload), NULL));
AZ_RETURN_IF_FAILED(az_json_writer_append_begin_object(&json_builder));
AZ_RETURN_IF_FAILED(az_json_writer_append_property_name(&json_builder, AZ_SPAN_LITERAL_FROM_STR("temp")));
AZ_RETURN_IF_FAILED(az_json_writer_append_int32(&json_builder, temp));
AZ_RETURN_IF_FAILED(az_json_writer_append_property_name(&json_builder, AZ_SPAN_LITERAL_FROM_STR("humi")));
AZ_RETURN_IF_FAILED(az_json_writer_append_int32(&json_builder, humi));
- STEP 17: Add the following codes after the line ntp.begin, in order to start the DHT11 sensor
dht.begin(); //start DHT sensor
Now we have completed all the codes for this demo.
- STEP 18: Click PlatformIO icon from the left navigation menu and click Build
If you see the following message, you have successfully compiled the code:
================================== [SUCCESS] Took 30.56 seconds ==================================
Microsoft Azure IoT Central Set Up
Now we need to create a custom device template so that the data from the Wio Terminal can be visualized on Azure IoT Central Dashboard
Creating a New Device Template
STEP 1: Visit Azure IoT Central and click
Device templatesfrom the left navigation menu -
STEP 2: Click + New, click IoT device and click Next:Customize
STEP 3: Type a name inside Device template name box and click Next:Review
STEP 4: Click Create
Importing a Custom Device Model
STEP 1: Click Import a model
STEP 2: Navigate to the wioterminal-aziot-example-0.10 folder that we used before, find seeedkk-wioterminal-wioterminal_aziot_example.json file and click on it
STEP 3: Click Open
STEP 4: Click Views from the left menu and click Generate default views
STEP 5: Click Generate default dashboard view(s)
STEP 6: Navigate to Overview from the left menu and customize the dashboard according to your preference.
Note: We have previously mentioned in this document, how to customize the dashboard
- STEP 7: Follow the below configuration
| Tile Name | Tile Size | Tile Visualization |
| Light Intensity | 2 x 2 | Line chart |
| Light Intensity | 1 x 1 | Last Known Value |
| Temperature (C), Humidity (%RH) | 2 x 2 | Line chart |
| Temperature (C) | 1 x 1 | Last Known Value |
| Humidity (%RH) | 1 x 1 | Last Known Value |
| Left button | 1 x 1 | KPI |
| Middle button | 1 x 1 | KPI |
| Right button | 1 x 1 | KPI |
- STEP 8: Click Save and Publish
Wio Terminal Set Up
Hardware Set Up
- Connect the Grove - Temperature and Humidity Sensor (DHT11) to Grove Digital Port on the Wio Terminal
Software Set Up
Upload Code to Wio Terminal
Now we need to upload the code to the Wio Terminal to send the telemetry data to Azure IoT Central
- STEP 1: Go back to VS Code, click PlatformIO icon and click Upload
Wi-Fi and Azure IoT Configuration
Next, let's move on to configuring Wi-Fi and Azure IoT connection just like we did before
- STEP 1: Hold down on the 3 buttons and turn ON the Wio Terminal to enter the configuration mode
STEP 2: Open a serial console application such as PUTTY
STEP 3: Type the correct serial COM Port, set 9600 as the baud rate and enter the Wio Terminal
- STEP 4: Press ENTER on the keyboard and type help in the serial terminal to view the configuration usage
Note: Now we don't need to enter WiFi SSID and password because they are already saved from the previous configuration
STEP 5: Set connection information of Azure IoT by visiting the previously created application on Azure IoT Central
STEP 6: Navigate to
Administration > Device Connectionfrom the left navigation menu, and copy the ID scope into notepad -
STEP 7: Click on SAS-IoT-Devices and copy the primary key into notepad
STEP 8: Visit previously opened serial terminal and type set_az_iotc
your_ID_scopeyour_primary_keyyour_device_name
Note: Make sure to add a single space between each field and you can decide on a device name of your choice.
- STEP 9: Reset the Wio Terminal by sliding down the switch further away from the ON position and releasing
Now you will be able to see the Wio Terminal LCD displaying that it's connecting to Wi-Fi and then Azure IoT Hub. After that, it will show the telemetry data being sent to Azure IoT Central.
Visualize on Azure IoT Central
Go back to Azure IoT Central and from the left navigation menu, click Devices, click on your Device name
Now you will be able to visualize all the sensor data from the Wio Terminal on Microsoft Azure IoT Central Dashboard!
