ESP32 Breakout Kit
This is the breakout kit specially designed for ESP32, it contains a breakout board and pin headers. The dimension is 53mmx38mmx1.2mm. The breakout board with 2.54mm-gap female headers allows you to connect the pin of ESP32 to it easily. We also provided 2 grove connectors in this kit to enrich the expansibility of ESP32.
note
The parts of the kit is non-soldered.
| Part Name | Qty |
| 4Pin Grove Connector | 2 |
| 4Pin 2.54 Header Male | 2 |
| 10Pin 2.54 Header Male | 4 |
| 10Pin 2.54 Header Female | 4 |
| PCB | 1 |
Pin map
Click to view larger image.
Getting Started
- First, you need to purchase ESP-32S Wifi Bluetooth Combo Module.
- Second,Solder the ESP32 module onto breakout kit.
- The assembled kit will provide ultra high performance and ultra low-power consumption Wi-Fi and Bluetooth combo wireless solution.
Schematic Online Viewer
- ESP32 Breakout Kit Schematics and PCB in EAGLE format
- ESP32 Breakout Kit Schematics in PDF format
- ESP32 Breakout Kit PCB in PDF format
