Eagleye 530s
enter image description here
Seeed is an experienced designer of development kits for IoT technology platforms. Our latest development kit—the Eagleye 530s,--is designed to help you get started developing products and services for the Samsung ARTIK™ IoT platform.
The Eagleye 530s is a high-performance, pre-tested, cost-effective and production-ready development kit which incorporates the Samsung ARTIK™ 530s--a 1GB system-on-module (SoM)-- on a custom credit card size board. For more information about ARTIK™ 530s, please click here.
What is Samsung ARTIK™? Samsung ARTIK™ is a pre-integrated IoT platform consisting of enterprise-grade system-on-modules (SoMs), cloud services, and end-to-end security for the design and development of robust IoT solutions. Developers frequently downplay the importance of security when designing and building IoT products. ARTIK integrated security services for SoMs and cloud make it easier for you to make your products secure.
As mentioned above, the Eagleye530s is based on the ARTIK 530s 1GB SoM, which is a Quad Core Cortex® A9 running @ 1.2 GHz with 4 B Flash memory, hardware-based security features, and Linux OS (Ubuntu). The Eagleye 530s also provides a 40 pin GPIO and accessory interface for Micro SD, Ethernet 10/100/1000, Wi-Fi 802.11 a/b/g/n, Bluetooth BLE 4.2 802.15.4, and ZigBee/Thread. It also supports full HDMI, MIPI camera interfaces, video, and audio media.
Since the Eagleye 530s is pin-compatible with many "maker" hardware accessories, it allows Samsung ARTIK™ developers to easily tap into the extensive "maker" accessories marketplace and prototype and build with off-the-shelf sensors (eg. GrovePi+,Grove sensors), voice recognition (eg. ReSpeaker 2-mic array and ReSpeaker 4-mic array), relays, GPS, cellular connectivity, and more, providing many options for enterprise developers creating feature-rich proof-of-concepts (PoC) or production-ready products.
Version​
Product VersionChangesReleased Date
Eagleye 530s Rev1.0InitialFeb 28 2018
Features​
  • Powered by the Samsung ARTIK™ IoT platform.
  • Incorporates ARTIK 530s 1GB SoM, a Quad Core Cortex® A9 running @ 1.2 GHz.
  • Includes 40 pin GPIO and accessory interface.
  • Support for Micro SD, Ethernet 10/100/1000, Wi-Fi 802.11 a/b/g/n, Bluetooth BLE 4.2 802.15.4, and ZigBee/Thread.
  • Supports full HDMI, MIPI camera interface, video, and audio media.
Specification​
ParameterValue/Range
Processor
CPUQuad core ARM® Cortex®-A9@1.2GHz
GPU3D graphics accelerator
Media
Camera I/F4-lane MIPI CSI up to 5M (1920x1080@30fps)
Display4-lane MIPI DSI and HDMI1.4a (1920x1080p@60fps) or LVDS (1280x720p@60fps)
AudioTwo I2S audio input/output
Memory
DRAM512MB/1GB DDR3
FLASH4GB eMMC v4.5
Security
Secure ElementSecure point to point authentication and data transfer
Radio
WLANIEEE 802.11a/b/g/n, dual band SISO
Bluetooth®4.2 (BLE+Classic)
802.15.4ZigBee®/Thread
Power Management
PMICProvides all power of the ARTIK 530 Module using on board bucks and LDO's
Interfaces
Ethernet10/100/1000Base-T MAC (External PHY required)
Analog and Digital I/OGPIO, UART, I2C, SPI, USB Host, USB OTG, HSIC, ADC, PWM, I2S, JTAG
Hardware Overview​
Block Diagram
Interfaces
Below figures show the overall preview of the Eagleye 530s' TOP and BOTTOM.
  • ⓐ DC Power: 5V DC power supply.
  • ⓑ USB Host 2.0 Interface: has two USB 2.0 Interface.
  • ⓒ Ethernet: The Ethernet Interface is based on 802.3az-2010 complying to the Energy Efficient Ethernet (EEE) standard. The maximum theoretical speed of the interface is 1000Mbps.
  • ⓓ Ear Jack: has one 4 pin ear jack interface supporting stereo audio
  • ⓔ Boot Switch: When 'eMMc 1st Boot' is selected as a booting option, the system will first try to boot from eMMc, if this fails the system will search for an SD Card to boot from. If booting from the SD-Card also fails the system tries to boot from USB. When choosing the SD-Card booting option, the system starts with booting from SD, and if this fails will continue to try a USB boot. When USB is selected as the booting mechanism of choice, only a USB boot will be attempted.
SW402eMMc 1st BootSD Card 1st BootUSB 1st Boot
1OffOffOn
2OffOffOn
3XXX
4OffOnX
  • ⓕ HDMI: has one HDMI 1.4a connector. The following video formats are supported:
    • 480p/480i @59.94Hz/60Hz, 576p/576i@50Hz
    • 720p/720i @50Hz/59.94Hz/60Hz
    • 1080p/1080i @50Hz/59.94Hz/60Hz
  • ⓖ USB OTG: has one USB OTG.
  • ⓗ USB UART: has one USB UART.
  • ⓘ User Button S4: switch named as S4, mapped to GPIO 54.
  • ⓚ Power On LED: Led will be turned on when board power on.
  • ⓛ Power in LED: Led will be turned on when board get power supply in.
  • ⓜ SD Card in LED: Led will be turned on when SD is pluged into board.
  • ⓝ User Button S3: switch named as S3, mapped to GPIO 50.
  • ⓞ MIPI CSI: The MIPI CSI interface can have a static resolution of 5M pixels or a dynamic resolution for video capturing of 1080P.
  • ⓟ ANT(802.11): If 802.11 or Bluetooth® functionality is required, the antenna which is enclosed as part of the Eagleye 530s has to be attached.
  • ⓠ Reset: board resest.
  • ⓡ Power: Once the power switch is turned on, push the power button (S1), for about 1 second.
  • ⓢ ANT(802.11): If 802.11 or Bluetooth® functionality is required, the antenna which is enclosed as part of the Eagleye 530s has to be attached.
  • ⓣ User Pins: To make them versatile control and monitoring devices, Eagleye 530s provides many programmable signal pins. These pins directly handle tasks like controlling relays, generating analog voltages, and monitoring analog sensors, as well as complex tasks involving parallel and serial communication with more sophisticated control and sensor devices.
  • ⓤ ANT(Zigbee): If Zigbee functionality is required, the antenna which is enclosed as part of the Eagleye 530s has to be attached.
  • ⓥ Power Switch: Through selection of the Jumpers JP1and JP2, the power source can be selected. When power is provided from a DC-5V Adapter , jumpers JP2 will be placed and 3-4 position will be connected. When the jumpers JP1 are in the 1-2 position, the power is provided from the usb-uart. When the Eagleye 530s is used with an external power adapter make certain that you use a 5V-2.5A adapter with a 2.1x5.5mm plug.
warning
NEVER connect both at the same time!
  • ⓦ SD card slot: has one SD-CARD interface supporting SD3.0.
  • ⓧ JTAG: has one JTAG interface.
Mechanical Drawing
note
Mechanical Drawing all dimensions are in [mm].
Application Ideas​
  • DIY
  • IoT and Smart Home
  • Robot
Getting Started​
Unboxing Demo
This section will describe how to start working with your Eagleye 530s Development Environment by setting up a serial connection on your development PC and booting up the Eagleye 530s Development Environment.
Hardware
  • Step 1. Set the power switch(named as number 21 on hardware overview) to USB.
  • Step 2. Connect USB cable from PC to USB UART(named as number 8 on hardware overview).
  • Step 3. Press the Power button for more than 1 second and we will see the Green/Red LEDs(refer to Number 10/11 on hardware overview) are turned on.
Software
Setting up a connection with the Eagleye 530s Module can be done in a wired or wireless manner. Here we choose to install PuTTY a free serial console. The software can be downloaded from http://www.putty.org/. Once downloaded go through the following steps:
  • Step 4. Set the PuTTY configuration as follows:
    • Set the "Serial line" as the COM port number found in step 3.
    • Set the COM speed to "115200".
    • Set the connection type to "Serial".
    • Save the session under Eagleye 530s.
  • Step 5. Select your saved session and click the "Open" button.
  • Step 6. The username and password are root.
  • Step 7. We will see the terminal as below.
Play with onboard LEDs
  • Step 1. Download blink_led.py or copy below code and paste to blink_led.py.
#!/usr/bin/python
import time
import sys
print "Blink an LED"
ledpin = 159 # Blink the blue led, please change to 43 for red led
#export GPIO pin by opening file and writing the pin number to it
pinctl = open("/sys/class/gpio/export", "wb", 0)
try:
pinctl.write( str(ledpin))
print "Exported pin", str(ledpin)
except:
print "Pin ", str(ledpin), " has been exported"
pinctl.close()
#set GPIO pin to be digital output
filename = '/sys/class/gpio/gpio%d/direction' % ledpin
pinctldir = open(filename, "wb", 0)
try:
pinctldir.write("out")
print "Set pin ", str(ledpin), " as digital output"
except:
print "Failed to set pin direction"
pinctldir.close()
#unexport GPIO pin when we are done
def exit_gpio():
pinctl = open("/sys/class/gpio/unexport", "wb", 0)
try:
print "Unexported pin", str(ledpin)
except:
print "Pin ", str(ledpin), " has been unexported"
pinctl.close()
#change GPIO pin value every 10 seconds
filename = '/sys/class/gpio/gpio%d/value' % ledpin
while True:
try:
pin = open(filename, "wb", 0)
pin.write( str(1) )
time.sleep(1)
pin.write( str(0) )
time.sleep(1)
pin.close()
except:
exit_gpio()
sys.exit(0)
  • Step 2. Run 'python blink_led.py'
  • Step 3. We will see the led blink.
Play with onboard Buttons
  • Step 1. Download read_button.py or copy below code to read_button.py.
#!/usr/bin/python
import time
import sys
print "Toggle a button"
buttonpin = 54 # Read S4 button, please change to 50 for S3 button
#export pin 8 by opening file and writing the pin number to it
try:
pinctl.write( str(buttonpin))
print "Exported pin", str(buttonpin)
except:
print "Pin ", str(buttonpin), " has been exported"
pinctl.close()
#set pin to be digital input
filename = '/sys/class/gpio/gpio%d/direction' % buttonpin
try:
pinctldir.write("in")
print "Set pin ", str(buttonpin), " as digital input"
except:
pinctldir.close()
def exit_gpio():
#unexport pin
try:
print "Unexported pin", str(buttonpin)
except:
print "Pin ", str(buttonpin), " has been unexported"
pinctl.close()
#pin value changes when the button is pressed
filename = '/sys/class/gpio/gpio%d/value' % buttonpin
while True:
try:
pin = open(filename, "rb", 0)
print pin.read()
time.sleep(1)
pin.close()
except KeyboardInterrupt:
exit_gpio()
sys.exit(0)
  • Step 2. Run 'python read_button.py'
  • Step 3. We will see the terminal info as below.
[root@artik ~]# python read_button.py
Toggle a button
Pin 54 has been exported
Set pin 54 as digital input
1
1
0
0
Ethernet and Wi-Fi Networks
The below instructions discuss setting up a wired or wireless local area network (LAN). The Ethernet LAN (hard-wired) port is always available. A wireless LAN (WLAN) circuit is separately available, and can be configured by Connection Manager.
  • Step 1. Scan for wireless access points. Enter commands as follows. connmanctl to get the > prompt.
  • Step 2. scan wifi to scan for available access points (wait until finished).
  • Step 3. services to list them.
  • Step 4. Select an access point. Still within the > prompt, enter commands as follows.
  • Step 5. agent on if you want Connection Manager to prompt you for a password.
  • Step 6. connect wifi_xxxx to pick the desired access point (you can use the tab key to start, and to auto-complete, your entry).
  • Step 7. Respond to the agent query for a password if needed.
  • Step 8. quit when finished.
  • Step 9. We won't need to repeat this process in the future: Connection happens automatically from now on.
Here is the terminal information.
[root@artik ~]# connmanctl
Error getting VPN connections: The name net.connman.vpn was not provided by any connmanctl> scan wifi
Scan completed for wifi
connmanctl> services
*AO Wired ethernet_000000000000_cable
seeed wifi_722c1f37ca11_XXXXXXXX_managed_psk
ReSpeaker1DD346 wifi_722c1f37ca11_XXXXXXXX_managed_none
connmanctl> agent on
Agent registered
connmanctl> connect wifi_722c1f37ca11_XXXXXXXX_managed_psk
Agent RequestInput wifi_722c1f37ca11_XXXXXXXX_managed_psk
Passphrase = [ Type=psk, Requirement=mandatory ]
Passphrase? 2018seeed
connmanctl> quit
[root@artik ~]#
Firmware Update
  • Step 1. Download the firmware, the files for the "ARTIK 530s 1G".
  • Step 2. Use Etcher tool to burn the firmware to SD card.
  • Step 3. Plug the SD card to Eagleye 530s SD slot.
  • Step 4. Change boot switch(named as number 21 on hardware overview) Pin4 to on.
  • Step 5. Connect the USB cable from PC to USB UART(named as number 8 on hardware overview).
  • Step 6. Press the Power button for more than 1 second and we will see the Green/Red/Blue LEDs(refer to Number 10/11/12 on hardware overview) are turned on.
  • Step 7. We will see below message and the firmware is downloaded successfuly.
  • Step 8. Please shutdown the board, remove SD card and switch boot switch Pin4 back to off.
Play with Pin Programming​
Eagleye boards provide many programmable signal pins. Some of these are General-Purpose Input/Output (GPIO) pins, while others are fixed-purpose pins for analog input, pulse-width-modulated output, and serialized communication.
  • Digital Input (GPIO) – sensing a DC signal level at low (GND) or high (Vcc)
  • Digital Output (GPIO) – driving a DC level (GND or Vcc) that can be controlled dynamically
  • Waveform Output (PWM) – switching DC levels by a Pulse Width Modulation circuit with frequency and duty cycle that can be programmed dynamically.
  • Serial Ports (I2C and UART) – sending and receiving data according to industry-standard protocols.
  • Analog Input (ADC) – reading a varying signal level and processing through an analog-to-digital converter
The sysfs functionality of the Linux kernel provides libraries to control and monitor programmable pins. Details are available at the reference.
Here is pinout of the connectors with its meaning.
DescriptionPin NamePin NumberPin NumberPin NameDescription
3.3V3.3V125V5V
I2CXI2C0_SDA345V5V
I2CXI2C0_SCL56GNDGND
GPIO_161XAGPIO078XUART0_TXUART
GNDGND910XUART0_RXUART
GPIO_128XGPIO01112I2SBCK1I2S
GPIO_129XGPIO11314GNDGND
PWMPWM21516XGPIO2GPIO_130
3.3V3.3V1718XGPIO3GPIO_46
SPIXSPIO_MOSI1920GNDGND
SPIXSPIO_MISO2122PWM0PWM
SPIXSPIO_CLK2324XSPIO0_CSSPI
GNDGND2526XGPIO4GPIO_14
NCNC2728NCNC
GPIO_27XGPIO92930GNDGND
GPIO_25XGPIO63132XGPIO7GPIO_0
GPIO_26XGPIO83334GNDGND
I2SI2SLRCLK13536XADC0ADC
ADCXADC13738I2SDIN1I2S
GNDGND3940I2SDOUT1I2S
GPIO Control through Sysfs
For example, pin 11 is GPIO and can be used as digital input or output. To use a particular GPIO, we would first set its direction (mode) as either input or output, and then read from or write to it as needed.
The Play with onboard LEDs and Play with onboard buttons tutorials provided examples of the necessary programming for digital I/O pins.
caution
Please change the specific GPIO pin number in the led/button python program.
PWM Control through Sysfs
For example, pin 22 is PWM. We can connect PWM of LED to PWM of 40 Pins and GND as well. We can set period and duty_cycle(Maximum limit is 1,000,000,000 (expressed in ns).) Duty_cycle should always be less than period.
The following exercise demonstrates use of a PWM pin, setting a fixed blink rate.
  • Step 1. Export PWM0
    echo 0 > /sys/class/pwm/pwmchip0/export
A pwm0 subdirectory is created. (We can use echo 0 to create pwm0, echo 2 to create pwm2.)
  • Step 2. Set attributes
    • a) Set period (Unit: ns) to 1 sec
      echo 1000000000 > /sys/class/pwm/pwmchip0/pwm0/period
    • b) Set duty_cycle (Unit: ns) to 500 msec
      echo 500000000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
    • c) Enable PWM0
      echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
    • d) Disable PWM0
      echo 0 > /sys/class/pwm/pwmchip0/pwm0/enable
  • Step 3. Unexport PWM0
    echo 0 > /sys/class/pwm/pwmchip0/unexport
Here is the terminal information for pwm0.
[root@artik pwmchip0]# echo 0 > /sys/class/pwm/pwmchip0/export    # please change to echo 2 for pwm2
[root@artik pwmchip0]# echo 1000000000 > /sys/class/pwm/pwmchip0/pwm0/period # please change to pwm2 from pwm0 for pwm2
[root@artik pwmchip0]# echo 500000000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle # please change to pwm2 from pwm0 for pwm2
[root@artik pwmchip0]# echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable # please change to pwm2 from pwm0 for pwm2
[root@artik pwmchip0]# echo 0 > /sys/class/pwm/pwmchip0/pwm0/enable # please change to pwm2 from pwm0 for pwm2
ADC Control through Sysfs
For example, pin 36 is ADC0. The following command line examples demonstrate how to read the current value of ADC0.
[root@artik dev]# cat /sys/devices/platform/c0000000.soc/c0053000.adc/iio:device0/in_voltage0_raw
0
1211
2027
3017
4095
note
Please change the in_voltage0_raw to in_voltage1_raw if we use pin37 (ADC1).
UART Control
cd /sys/kernel/config/device-tree/overlays/
mkdir ttyAMA4
cd /boot/overlays
cat s5p4418-artik533-compy-serial4.dtbo > /sys/kernel/config/device-tree/overlays/ttyAMA4/dtbo
cd /dev
ls tty*
  • Step 2. Connect the UART0 TX/RX to USB2Serial adaptor.
Pin NumberPin NameUSB2Serial Adaptor
6GNDGND
8XUART0_TXRX
10XUART0_RXTX
  • Step 3. Send "hello" to UART0
stty -F /dev/ttyAMA4
echo "hello .." > /dev/ttyAMA4
  • Step 4. We can see the serial monitor as below.
hello ..
hello ..
hello ..
Play with ReSpeakers Mics​
Play with 2 Mics Pi HAT
Hardware
Install 2 Mics Driver
  • Step 1. Download the Seeed-Voicecard driver.
[root@artik ~]# apt update
[root@artik ~]# apt install git
[root@artik ~]# git clone https://github.com/respeaker/seeed-voicecard
[root@artik ~]# cd seeed-voicecard
[root@artik seeed-voicecard]# git checkout remotes/origin/artikpi -b artiki
  • Step 2. Install Seeed-Voicecard driver.
[root@artik ~]# cd seeed-voicecard/
[root@artik seeed-voicecard]# mount -o remount,rw /lib/modules
[root@artik seeed-voicecard]# sudo mkdir -p /lib/modules/4.4.113-0533GS0F-44U-01Q5/kernel/sound/soc/codecs/
[root@artik seeed-voicecard]# sudo cp snd-soc-ac108.ko.0533GS0F-44U-01Q5 /lib/modules/4.4.113-0533GS0F-44U-01Q5/kernel/sound/soc/codecs/snd-soc-ac108.ko
[root@artik seeed-voicecard]# sudo cp snd-soc-wm8960.ko.0533GS0F-44U-01Q5 /lib/modules/4.4.113-0533GS0F-44U-01Q5/kernel/sound/soc/codecs/snd-soc-wm8960.ko
[root@artik seeed-voicecard]# sudo depmod -a
  • Step 3. Enable 2 Mics.
[root@artik seeed-voicecard]# su root
[root@artik seeed-voicecard]# mkdir /sys/kernel/config/device-tree/overlays/seeed-voicecard
[root@artik seeed-voicecard]# cat seeed-2mic-voicecard-artik.dtbo > /sys/kernel/config/device-tree/overlays/seeed-voicecard/dtbo
[root@artik seeed-voicecard]# cp wm8960_asound.state /var/lib/alsa/asound.state
[root@artik seeed-voicecard]# alsactl --file=wm8960_asound.state restore
warning
Please run Step 3 again after the rebooting, or else it can't detect the seeed voicecard.
  • Step 4. Use the arecord to list the record devices.
[root@artik seeed-voicecard]# arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default
Playback/recording through the PulseAudio sound server
playback
dmixed
ac108
sysdefault:CARD=Audio
Artik530 raptor Audio,
Default Audio Device
dmix:CARD=Audio,DEV=0
Direct sample mixing device
dsnoop:CARD=Audio,DEV=0
Direct sample snooping device
hw:CARD=Audio,DEV=0
Direct hardware device without any conversions
plughw:CARD=Audio,DEV=0
Hardware device with all software conversions
sysdefault:CARD=seeed2micvoicec
seeed-2mic-voicecard,
dmix:CARD=seeed2micvoicec,DEV=0
dsnoop:CARD=seeed2micvoicec,DEV=0
hw:CARD=seeed2micvoicec,DEV=0
plughw:CARD=seeed2micvoicec,DEV=0
Capture/Playback Audio
  • Start recording using the Command Line
arecord -f cd -Dplughw:1,0 /tmp/test.wav
aplay -Dplughw:1,0 /tmp/test.wav
Here is the hardware setup. We can hear the playback from the 2 Mics audio jack.
  • Start recording using Python
    • Step 1. Install pyaudio package by below commands
      apt install python-pyaudio
    • Step 2. Use a text editor like vi to create this recorder_2Mics.py code file, which records a 10-sec audio clip called test.wav.
import pyaudio
import wave
FORMAT = pyaudio.paInt16
CHANNELS = 2
RATE = 48000
CHUNK = 1024
RECORD_SECONDS = 10
WAVE_OUTPUT_FILENAME = "test.wav"
audio = pyaudio.PyAudio()
# start Recording
stream = audio.open(format=FORMAT, channels=CHANNELS, rate=RATE, input=True, frames_per_buffer=CHUNK)
print "recording audio..."
frames = []
threshold = 800
for i in range(0, int(RATE / CHUNK * RECORD_SECONDS)):
data = stream.read(CHUNK)
frames.append(data)
print "done recording"
# stop Recording
stream.stop_stream()
stream.close()
audio.terminate()
waveFile = wave.open(WAVE_OUTPUT_FILENAME, 'wb')
waveFile.setnchannels(CHANNELS)
waveFile.setsampwidth(audio.get_sample_size(FORMAT))
waveFile.setframerate(RATE)
waveFile.writeframes(b''.join(frames))
waveFile.close()
caution
For more information, such as play with google assistant, please refer to ReSpeaker 2-Mics Pi HAT.
Play with 4 Mics Pi HAT
Hardware
Install 4 Mics Driver
  • Step 3. Enable 4 Mics.
[root@artik seeed-voicecard]# cat seeed-4mic-voicecard-artik.dtbo > /sys/kernel/config/device-tree/overlays/seeed-voicecard/dtbo
[ 574.305000] Please set data-protocol.
[ 574.310000] i2c_id number :0
[ 574.310000] ac108 codec_index :0
[ 574.315000] ac108 I2S data protocol type :1
[ 574.335000] ac108_write error->[REG-0x00,val-0x12]
[ 574.550000] AC108 PLL freq_in match:24000000, freq_out:24576000
[ 574.550000]
[ 574.640000] AC108 PLL freq_in match:24000000, freq_out:24576000
[ 574.640000]
[root@artik seeed-voicecard]# cp ac108_asound.state /var/lib/alsa/asound.state
[root@artik seeed-voicecard]# cp ac108_plugin/libasound_module_pcm_ac108.so /usr//lib/arm-linux-gnueabihf/alsa-lib/
[root@artik seeed-voicecard]# cp asound_4mic.conf /etc/asound.conf
[root@artik seeed-voicecard]# alsactl --file=ac108_asound.state restore
caution
null
pulse
default
playback
dmixed
ac108
hw:CARD=Audio,DEV=0
sysdefault:CARD=seeed4micvoicec
seeed-4mic-voicecard,
dmix:CARD=seeed4micvoicec,DEV=0
dsnoop:CARD=seeed4micvoicec,DEV=0
hw:CARD=seeed4micvoicec,DEV=0
plughw:CARD=seeed4micvoicec,DEV=0
Capture Audio
arecord -Dac108 -f S16_LE -r 48000  -c 4 /tmp/test.wav
    • Step 2. Use a text editor like vi to create this recorder_4Mics.py code file, which records a 10-sec audio clip called test.wav.
import pyaudio
import wave
CHANNELS = 4
RATE = 48000
CHUNK = 1024
RECORD_SECONDS = 10
# start Recording
frames = []
threshold = 800
frames.append(data)
# stop Recording
stream.close()
audio.terminate()
waveFile.close()
caution
For more information, such as play with Alexa/DuerOS, please refer to ReSpeaker 4-Mic Array for Raspberry Pi.
Play with Mic Array v2.0
Hardware
Capture Audio
arecord -D plughw:1,0 -f cd test.wav # record, please use the arecord -l to check the card and hardware first
aplay -D plughw:1,0 -f cd test.wav # play, please use the aplay -l to check the card and hardware first
arecord -D plughw:1,0 -f cd |aplay -D plughw:1,0 -f cd # record and play at the same time
    • Step 1, We need to run the following script to get the device index number of Mic Array:
      apt install python-pip
      pip install pyaudio
      cd ~
      nano get_index.py
    • Step 2, copy below code and paste on get_index.py.
import pyaudio
p = pyaudio.PyAudio()
info = p.get_host_api_info_by_index(0)
numdevices = info.get('deviceCount')
for i in range(0, numdevices):
if (p.get_device_info_by_host_api_device_index(0, i).get('maxInputChannels')) > 0:
print "Input Device id ", i, " - ", p.get_device_info_by_host_api_device_index(0, i).get('name')
  • Step 3, press Ctrl + X to exit and press Y to save.
  • Step 4, run 'sudo python get_index.py' and we will see the device ID as below.
Input Device id  0  -  Artik530 raptor Audio: - (hw:0,0)
Input Device id 2 - ReSpeaker 4 Mic Array (UAC1.0): USB Audio (hw:1,0)
Input Device id 3 - sysdefault
Input Device id 4 - pulse
Input Device id 8 - default
  • Step 5, change RESPEAKER_INDEX = 2 to index number. Run python script record.py to record a speech.
import pyaudio
import wave
RESPEAKER_RATE = 16000
RESPEAKER_CHANNELS = 1 # change base on firmwares, default_firmware.bin as 1 or i6_firmware.bin as 6
RESPEAKER_WIDTH = 2
# run getDeviceInfo.py to get index
RESPEAKER_INDEX = 2 # refer to input device id
CHUNK = 1024
RECORD_SECONDS = 5
WAVE_OUTPUT_FILENAME = "output.wav"
stream = p.open(
rate=RESPEAKER_RATE,
format=p.get_format_from_width(RESPEAKER_WIDTH),
channels=RESPEAKER_CHANNELS,
input=True,
input_device_index=RESPEAKER_INDEX,)
print("* recording")
frames = []
for i in range(0, int(RESPEAKER_RATE / CHUNK * RECORD_SECONDS)):
frames.append(data)
print("* done recording")
stream.close()
p.terminate()
wf = wave.open(WAVE_OUTPUT_FILENAME, 'wb')
wf.setnchannels(RESPEAKER_CHANNELS)
wf.setsampwidth(p.get_sample_size(p.get_format_from_width(RESPEAKER_WIDTH)))
wf.setframerate(RESPEAKER_RATE)
wf.writeframes(b''.join(frames))
wf.close()
caution
For more information, such as play with DOA/LEDs, please refer to ReSpeaker Mic Array v2.0.
Play with GrovePi+​
Install dependencies
apt install g++ libi2c-dev
apt install python-dev
apt install python-smbus
apt install libffi-dev
pip install setuptools
pip install smbus-cffi
pip install numpy
I2C using Python with GrovePi+ Shield
  • Step 1. Download the files from github.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
  • Step 2. Modify the source code /root/GrovePi/Software/Cpp/grovepi.cpp and add one line as shown.
void GrovePi::SMBusName(char *smbus_name)
unsigned int hw_revision = gpioHardwareRevision();
unsigned int smbus_rev;
if(hw_revision < 4)
// type 1
smbus_rev = 1;
else if(hw_revision < 16)
// type 2
smbus_rev = 2;
else
// type 3
smbus_rev = 3;
if(smbus_rev == 2 || smbus_rev == 3)
strcpy(smbus_name, "/dev/i2c-1");
else
strcpy(smbus_name, "/dev/i2c-0");
strcpy(smbus_name, "/dev/i2c-1"); //add this line to enable the I2C for eagleye_530s
  • Step 3. Modify the source code /root/GrovePi/Software/Python/grovepi.py and comment as shown.
if sys.platform == 'uwp':
import winrt_smbus as smbus
bus = smbus.SMBus(1)
else:
import smbus
# import RPi.GPIO as GPIO
# rev = GPIO.RPI_REVISION
# if rev == 2 or rev == 3:
# else:
# bus = smbus.SMBus(0)
  • Step 4. Every time we reset the board, run the following two commands. Put them in a bash file to make it automatic.
mkdir /sys/kernel/config/device-tree/overlays/i2c
cat /boot/overlays/s5p4418-artik533-compy-i2c1.dtbo > /sys/kernel/config/device-tree/overlays/i2c/dtbo
caution
Please run Step 4 commands after rebooting.
  • Step 5. Please attach the Grove-Led and Grove-Rotary Angle Sensor to GrovePi as below.
  • Step 6. Run python grove_rotary_angle_sensor.py.
cd ~/GrovePi/Software/Python/
Here is the code.
import time
import grovepi
# Connect the Grove Rotary Angle Sensor to analog port A0
# SIG,NC,VCC,GND
potentiometer = 0
# Connect the LED to digital port D5
# SIG,NC,VCC,GND
led = 5
grovepi.pinMode(potentiometer,"INPUT")
grovepi.pinMode(led,"OUTPUT")
time.sleep(1)
# Reference voltage of ADC is 5v
adc_ref = 5
# Vcc of the grove interface is normally 5v
grove_vcc = 5
# Full value of the rotary angle is 300 degrees, as per it's specs (0 to 300)
full_angle = 300
while True:
try:
# Read sensor value from potentiometer
sensor_value = grovepi.analogRead(potentiometer)
# Calculate voltage
voltage = round((float)(sensor_value) * adc_ref / 1023, 2)
# Calculate rotation in degrees (0 to 300)
degrees = round((voltage * full_angle) / grove_vcc, 2)
# Calculate LED brightess (0 to 255) from degrees (0 to 300)
brightness = int(degrees / full_angle * 255)
# Give PWM output to LED
grovepi.analogWrite(led,brightness)
print("sensor_value = %d voltage = %.2f degrees = %.1f brightness = %d" %(sensor_value, voltage, degrees, brightness))
grovepi.analogWrite(led,0)
break
except IOError:
print ("Error")
  • Step 7. The Led will change the brightness while the rotary angle sensor is rotating. We also see the terminal information as below.
[root@artik Python]# python grove_rotary_angle_sensor.py
sensor_value = 246 voltage = 1.20 degrees = 72.0 brightness = 61
sensor_value = 247 voltage = 1.21 degrees = 72.6 brightness = 61
sensor_value = 258 voltage = 1.26 degrees = 75.6 brightness = 64
sensor_value = 274 voltage = 1.34 degrees = 80.4 brightness = 68
sensor_value = 296 voltage = 1.45 degrees = 87.0 brightness = 73
sensor_value = 318 voltage = 1.55 degrees = 93.0 brightness = 79
sensor_value = 340 voltage = 1.66 degrees = 99.6 brightness = 84
sensor_value = 363 voltage = 1.77 degrees = 106.2 brightness = 90
sensor_value = 387 voltage = 1.89 degrees = 113.4 brightness = 96
:::caution: For more Grove sensors, please refer to DexterInd Python Library. We do not test all the sensors' compatiblity with Eagleye 530s. Please contact techsupport if any issue.
Play with Shield​
Play with Relay Boards
Hardware
Software
  • Step 1. Run below command to enable the I2C.
caution
  • Step 2. Run i2cdetect to detect the relay shield.
[root@artik ~]# i2cdetect -y -r 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
  • Step 3. Run the below commands to run the relay_lib_seeed_test.py.
[root@artik ~]# cd ~
[root@artik ~]# git clone https://github.com/johnwargo/Seeed-Studio-Relay-Board.git
[root@artik ~]# cd Seed-Studio-Relay-Board/
[root@artik Seed-Studio-Relay-Board]# python relay_lib_seeed_test.py
Turning all relays ON
Turning all relays OFF
Turning relay 1 ON
Turning relay 1 OFF
Turning relay 2 ON
Turning relay 2 OFF
Turning relay 3 ON
Turning relay 3 OFF
Turning relay 4 ON
Turning relay 4 OFF
caution
For more information, please refer to Raspberry Pi Relay Board v1.0.
Play with RS232 Boards
Hardware
  • Step 1. Connect the USB cable to power source.
  • Step 2. Connect the RS232 cable between the RS232 sheild and PC.
Software
  • Step 1. Open putty at PC side and config as below. The COM must be set as the device manager. In our case the COM port allocated is COM9.
  • Step 2. Set the PuTTY configuration as follows:
  • Step 3. Select your saved session and click the "Open" button.
  • Step 4. The username and password are root.
  • Step 5. We will see the terminal as below.
caution
For more information, please refer to Raspberry Pi RS232 Board v1.0.
Play with Breakout Board
Raspberry Pi Breakout Board, it also provides power, state indicator light, button and universal transistor,such as NPN, PNP, N-MOS, P-MOS. It works well with Eagleye_530s.
caution
For more information, please refer to Raspberry Pi Breakout Board v1.0.
FAQs​
  • Q1: Is Eagleye 530s compatiable with Raspberry Pi enclosures?
A1: Yes. Here are the compatiable list.
SKUDescriptionComments
103010002GrovePi+Refer to Play with Grovepi+
103030030Raspberry Pi Breakout Board v1.0Refer to Play with Shield
103030029Raspberry Pi Relay Board v1.0Refer to Play with Shield
103030028Raspberry Pi RS232 Board v1.0Refer to Play with Shield
114990835Raspberry Pi HDMI LCD (7 inch)Display works well except the touch.
  • Q2: How to set the auto-boot function?
A2: Find the D401 diode as below picture, remove D401 diode by soldering, short the D401's two pins by soldering a solder dot.
Resources​
