Galileo Case
When you have a Galileo PCB, do you want to select a suitable case for improving whole felling and protecting it? There is a case that we customize for the PCB. The Case is used to wrap the Galileo PCB, It's constructed from military grade alminum and hardwearing acrylic, Providing the ultimate protection from physical and corrosion!Because we use blue acrylic, So it looks very neatly and beautiful
Feature
Easy to assemble
Solid and stable material
Usage
Assembly diagram is as follows:
| Part | Package | Qty |
| Bracket | 1.5mm aluminum plate stamping molding, black sand anodized | 2 |
| Bottom Acrylic Cover | 2.5mm Thickness | 1 |
| Top Acrylic Cover | 2.5mm Thickness | 1 |
| Rivet(black) | R2056 | 8 |
| Screw | M3X5 | 8 |
| double-screw bolt | M3X8 | 4 |
