Get Started with Arduino
Get Started with Arduino IDE
Arduino IDE Download
For every Arduino-supported you might need Arduino IDE to upload the code, for checking whether the board is functioning well and ebabling every application.
How to install Arduino Library
We have provided a tutorial about how you install an Arduino library. You should notice that almost all of our library was stored at Github. We will provide Arduino libraries when a product need a library, like CAN-BUS Shield V2. But for some other simple products, there is no need to write a library such as Grove - Button.
How to Upload Code
Here we have another tutorial for uploading the code:
Seeeduino Boards
How to add Seeed boards to Arduino IDE
How to Install the driver for Seeeduino
More How-to Tutorials
Basic Tutorials
- How to Install Arduino Library
- How to Use and Write a Library
- How to Upload Code
- How to Use External Editor
- How to Use Demos Downloaded from Seeed's Github
Ports Usages:
- How to Use Software Serial
- How to Use Software I2C
- How to Use Software SPI
- How to Use Software Static Library
- How to Handle Arduino Common Error
The guide to Different Sensors Selection
- How to Choose A Gas Sensor
- How to Choose Different Grove Temperature Sensors
- How to Choose GPS Modules
- How to Choose Finger Touch
- How to Choose Seeed Relay
- How to Choose on Barometer Sensor
- How to Use Sketchbook
- How to Use Sketchbook of Sidekick Advanced Kit
The guide to Grove Cables Choose
More Advanced Tutorials
- Suli
- How to Use Seeed Arduino Serial
- How to Use I2C And I2C Address of Seeed Product
- How to Use ODYSSEY-X86J4105 with Firmata
- How to Debug Arduino Boards using SWD Interface
- How to Bridge Mosiquitto MQTT Broker to AWS IoT with Arduino Boards
- How to use Arduino Boards as DAPLink Device
- How to Flash Arduino Bootloader Using DAPLink
- How to Understand Xadow IO Pin Mapping
Arduino Cores
- Purpose: Arduino cores allow the Arduino IDE to communicate with different types of microcontrollers. They adapt standard Arduino commands to the specifics of the underlying hardware.
- Examples: Different cores exist for microcontrollers like RP2040, ESP32, ESP8266, and more traditional ones like AVR and SAMD. Some cores are maintained by the community, ensuring support and updates for a wide range of devices.
Arduino-supported Boards
More
More on Seeed Studio Bazaar.
Arduino Shield(extension boards)
- Grove Base V2
- CAN-BUS Shield V2.0
- Relay Shield v3
- W5500 Ethernet Shield v1.0
- Small e-Paper Shield V2
- Spartan Edge Accelerator Board
- Grove Shield for Arduino Nano
- More on Seeed Studio Bazaar.
Kit with Courses
- Grove Beginner Kit for Arduino
- Rainbow Cube kit- RGB 4X4X4 (Rainbowduino Compatible)
- Grove Creator Kit for Arduino
