Grove - 125KHz RFID Reader
This Grove-125KHz RFID Reader is a module used to read uem4100 RFID card information with two output formats: Uart and Wiegand. It has a sensitivity with maximum 7cm sensing distance. There is also the electronic brick version of this module. It can help you with project like internet of thing and access control system.
And you should use the module below while using RFID reader:
Version
| Product Version | Changes | Released Date |
| Grove - 125KHz RFID Reader V1.0 | Initial | Oct 2015 |
Specifications
| Parameter | Value/Range |
| Voltage | 4.75-5.25V |
| Working Frequency | 125 KHz |
| Sensing Distance(Max) | 70mm |
| TTL Output | 9600 baudrate, 8 data bits, 1 stop bit, and no verify bit |
| Wiegand Output | 26 bits Wiegand format, 1 even verify bit, 24 data bits, and 1 odd verify bit |
Platforms Supported
Getting Started
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Play With Arduino
Hardware
- Step 1. Prepare the below stuffs:
| Seeeduino V4.2 | Base Shield | Grove - 125KHz RFID Reader |
| Get One Now | Get One Now | Get One Now |
- Step 2. Connect Grove - 125KHz RFID Reader to port D2 of Grove-Base Shield.
- Step 3. Plug Grove - Base Shield into Seeeduino.
- Step 4. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect Grove_Ultrasonic_Ranger to Seeeduino as below.
| Seeeduino | Grove - 125KHz RFID Reader |
| 5V | Red |
| GND | Black |
| D3 | White |
| D2 | Yellow |
Software
- Step 1. Copy the code into Arduino IDE and upload. If you do not know how to upload the code, please check how to upload code.
link between the computer and the SoftSerial Shield
at 9600 bps 8-N-1
Computer is connected to Hardware UART
SoftSerial Shield is connected to the Software UART:D2&D3
#include <SoftwareSerial.h>
SoftwareSerial SoftSerial(2, 3);
unsigned char buffer[64]; // buffer array for data receive over serial port
int count = 0; // counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
Serial.begin(9600); // the Serial port of Arduino baud rate.
// if date is coming from software serial port ==> data is coming from SoftSerial shield
if (SoftSerial.available())
while(SoftSerial.available()) // reading data into char array
buffer[count++] = SoftSerial.read(); // writing data into array
if(count == 64)break;
Serial.write(buffer, count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the stored data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardware serial port ==> data is coming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
// clear all index of array with command NULL
for (int i=0; i<count; i++)
buffer[i]=NULL;
- Step 2. Open the Serial Monitor, the card information can be displayed as shown below:
Wiegand Mode
(Jumper Set to the Right two Pins) You would need to select the jumper to "W" to enter this mode. The Wiegand demo code for Seeeduino is designed to read Wiegand data in interrupt mode.
In Wiegand Mode, output data is formatted with 26bits including 24bits card info and 2 bits parity.
bit | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 |
PE | D | P0 | ||||||||||||||||||||||||
E | 0 | |||||||||||||||||||||||||
D2[7..0] | D1[7..0] | D0[7..0] | ||||||||||||||||||||||||
- PE is even bit, PO is odd bit;
- E is the data bit which was involved in even, O is the data bit which was involved in odd;
- DX[7..0] is the data bit which correspond to Mifare@ Standard & Light card read only ID;
FAQs
Q1: How to convert the output to Card Number?
A1: Please follow below steps.
- Take ID: 0009776930 for example:
- Card Number ID: 0009776930 ------- Decimalism [Start Bit(00) + Card Number(8 numbers)]
- Output: 0700952F229F ------------- Hex [[Start Bit(07h) + Card Number(8 numbers) + Checksum]
- The calculator for decimal and hex numbers is available online.
Q2: How to read tags continuously?
A2: The RFID reader can read tags continuously without any setting. Keep the tag 2.5-4 cm from the antenna, and the reader can read data continuously. And if the distance is below 2.5cm, the reader reads data once if not moving tags away.
- [Demo] Grove - 125KHz RFID Reader Demo
- [PDF] Declaration of conformity
- [PDF] Test Report
Projects
Arduino Based Security Project Using Cayenne: Arduino based Home Security Project. SMS/email alerts when intruder detected. Personalized messages for authorized personnel.
