Grove - 315MHz RF Kit
This kit is used for one way wireless communication at a frequency of 315MHz and includes a transmitter module and a receiver module. The twig configuration of this kit allows for around 40 meters of transmitting distance indoors, or around 100 meters outside. The 315 MHz frequency is suitable for use without a license in the United States. For use in Europe, please see the 433 MHz version of this product.
- GROVE compatible interface.
- Uses ASK (Amplitude Shift Keying) Modulation.
- One way communication.
Application Ideas
- Remote control
- Remote automation
- Alarm
Mechanical Dimensions
- Receiver: 24mm by 42mm
- Transmitter: 20mm by 24mm
Platforms Supported
Usage
The transmitter and receiver modules both rely on a single wire for communication. Though using the UART supplied by the arduino platform can work, it is recommended, instead, to use the VirtualWire library which uses Amplitude Shift Keying for modulation which provides better communication.
Both the transmitter and receiver modules require three wires: Vcc, Ground, and signal. Pin 2 of both parts of the kit are not connected.
Hardware Installation
Connect the Transmitter module to Digital I/O 2 of the Grove-Base Shield V2 on the arduino being used for transmission.
Connect the Transmitter module to Digital I/O 2 of the Grove-Base Shield V2 on the receiving arduino.
Programming
Sample code for Transmitter:
#include <VirtualWire.h>
int RF_TX_PIN = 2;
vw_set_tx_pin(RF_TX_PIN); // Setup transmit pin
vw_setup(2000); // Transmission speed in bits per second.
const char *msg = "hello";
vw_send((uint8_t *)msg, strlen(msg)); // Send 'hello' every 400ms.
delay(400);
Sample code for Receiver:
int RF_RX_PIN = 2;
Serial.begin(9600);
Serial.println("setup");
vw_set_rx_pin(RF_RX_PIN); // Setup receive pin.
vw_rx_start(); // Start the PLL receiver.
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if(vw_get_message(buf, &buflen)) // non-blocking I/O
int i;
// Message with a good checksum received, dump HEX
Serial.print("Got: ");
for(i = 0; i < buflen; ++i)
Serial.print(buf[i], HEX);
Serial.print(" ");
Serial.println("");
