Grove - 4-Digit Display
Grove - 4-Digit Display module is a 12-pin module. In this module, we utilise a TM1637 to scale down the number of controlling pins to 2. That is to say, it controls both the content and the luminance via only 2 digital pins of Arduino or Seeeduino. For projects that require alpha-numeric display, this can be a nice choice.
Version​
Product VersionChangesReleased Date
Grove - 4-Digit Display V1.0InitialMay 2012
Features​
  • 4 digit red alpha-numeric display
  • Grove compatible interface (3.3V/5V)
  • 8 adjustable luminance levels
Specifications​
Item
Min
Typical
Max
Unit
Voltage
3.3
5.0
5.5
VDC
Current
0.2
27
80
mA
Dimensions
42x24x14
mm
Net Weight
7±1
g
Application Ideas​
  • Time display
  • Stopwatch
  • Sensors' input display
Platforms Supported​
ArduinoRaspberry Pi
caution
Getting Started​
note
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Play With Arduino​
Hardware
  • Step 1. Prepare the below stuffs:
Seeeduino V4.2Base ShieldGrove-4-Digit Display
Get One NowGet One NowGet One Now
  • Step 2. Connect Grove-4-Digit Display to D2 port of Grove-Base Shield.
  • Step 3. Plug Grove - Base Shield into Seeeduino.
  • Step 4. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove-4-Digit Display to Seeeduino as below. We also can plug Grove-4-Digit Display to other Grove digital port.
SeeeduinoGrove-4-Digit Display
5VRed
GNDBlack
D3White (DIO)
D2Yellow(CLK)
warning
The Grove-4-Digit Display includes 4 pins, GND, VCC, DIO, CLK. We can connect DIO and CLK to any digital pin. It is not I2C protocol.
Software
  • Step 4. We will see the Grove-4-Digit Display being turned on.
Play with Codecraft​
Hardware​
Step 1. Connect Grove - 4-Digit Diaplsy to port D2 in a Base Shield
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software​
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
note
If this is your first time using Codecraft, see also Guide for Codecraft using Arduino.
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
success
When the code finishes uploaded, you will see number flowing from 0 to 9.
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)​
Hardware​
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - 4 Digit Display
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Plug the Grove Base Hat into Raspberry Pi.
  • Step 3. Connect the 4-digit display to port 12 of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
note
For step 3 you are able to connect the digit to any GPIO Port but make sure you change the command with the corresponding port number.
Software​
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Download the source file by cloning the grove.py library.
cd ~
  • Step 3. Excute below commands to run the code.
cd grove.py/grove
python grove_4_digit_display.py 12 13
Following is the grove_4_digit_display.py code.
import sys
import time
from grove.gpio import GPIO
charmap = {
'0': 0x3f,
'1': 0x06,
'2': 0x5b,
'3': 0x4f,
'4': 0x66,
'5': 0x6d,
'6': 0x7d,
'7': 0x07,
'8': 0x7f,
'9': 0x6f,
'A': 0x77,
'B': 0x7f,
'b': 0x7C,
'C': 0x39,
'c': 0x58,
'D': 0x3f,
'd': 0x5E,
'E': 0x79,
'F': 0x71,
'G': 0x7d,
'H': 0x76,
'h': 0x74,
'I': 0x06,
'J': 0x1f,
'K': 0x76,
'L': 0x38,
'l': 0x06,
'n': 0x54,
'O': 0x3f,
'o': 0x5c,
'P': 0x73,
'r': 0x50,
'S': 0x6d,
'U': 0x3e,
'V': 0x3e,
'Y': 0x66,
'Z': 0x5b,
'-': 0x40,
'_': 0x08,
' ': 0x00
ADDR_AUTO = 0x40
ADDR_FIXED = 0x44
STARTADDR = 0xC0
BRIGHT_DARKEST = 0
BRIGHT_DEFAULT = 2
BRIGHT_HIGHEST = 7
class Grove4DigitDisplay(object):
colon_index = 1
def __init__(self, clk, dio, brightness=BRIGHT_DEFAULT):
self.brightness = brightness
self.clk = GPIO(clk, direction=GPIO.OUT)
self.dio = GPIO(dio, direction=GPIO.OUT)
self.data = [0] * 4
self.show_colon = False
def clear(self):
self.data = [0] * 4
self._show()
def show(self, data):
if type(data) is str:
for i, c in enumerate(data):
if c in charmap:
self.data[i] = charmap[c]
else:
self.data[i] = 0
if i == self.colon_index and self.show_colon:
self.data[i] |= 0x80
if i == 3:
break
elif type(data) is int:
self.data = [0, 0, 0, charmap['0']]
if data < 0:
negative = True
data = -data
else:
negative = False
index = 3
while data != 0:
self.data[index] = charmap[str(data % 10)]
index -= 1
if index < 0:
break
data = int(data / 10)
if negative:
if index >= 0:
self.data[index] = charmap['-']
else:
self.data = charmap['_'] + [charmap['9']] * 3
else:
raise ValueError('Not support {}'.format(type(data)))
self._show()
def _show(self):
with self:
self._transfer(ADDR_AUTO)
with self:
self._transfer(STARTADDR)
for i in range(4):
self._transfer(self.data[i])
with self:
self._transfer(0x88 + self.brightness)
def update(self, index, value):
if index < 0 or index > 4:
return
if value in charmap:
self.data[index] = charmap[value]
else:
self.data[index] = 0
if index == self.colon_index and self.show_colon:
self.data[index] |= 0x80
with self:
self._transfer(ADDR_FIXED)
with self:
self._transfer(STARTADDR | index)
self._transfer(self.data[index])
with self:
def set_brightness(self, brightness):
if brightness > 7:
brightness = 7
self._show()
def set_colon(self, enable):
self.show_colon = enable
if self.show_colon:
self.data[self.colon_index] |= 0x80
else:
self.data[self.colon_index] &= 0x7F
self._show()
def _transfer(self, data):
for _ in range(8):
self.clk.write(0)
if data & 0x01:
self.dio.write(1)
else:
self.dio.write(0)
data >>= 1
time.sleep(0.000001)
self.clk.write(1)
self.clk.write(0)
self.dio.write(1)
self.clk.write(1)
self.dio.dir(GPIO.IN)
while self.dio.read():
time.sleep(0.001)
if self.dio.read():
self.dio.dir(GPIO.OUT)
self.dio.write(0)
def _start(self):
self.clk.write(1)
self.dio.write(1)
self.dio.write(0)
self.clk.write(0)
def _stop(self):
self.clk.write(0)
self.dio.write(0)
self.clk.write(1)
self.dio.write(1)
def __enter__(self):
self._start()
def __exit__(self, exc_type, exc_val, exc_tb):
self._stop()
Grove = Grove4DigitDisplay
def main():
if len(sys.argv) < 3:
print('Usage: {} clk dio'.format(sys.argv[0]))
sys.exit(1)
display = Grove4DigitDisplay(int(sys.argv[1]), int(sys.argv[2]))
count = 0
while True:
t = time.strftime("%H%M", time.localtime(time.time()))
display.show(t)
display.set_colon(count & 1)
count += 1
time.sleep(1)
if __name__ == '__main__':
main()
success
If everything goes well, the 4-digit display will show the current time.
You can quit this program by simply press ++ctrl+c++.
Play With Raspberry Pi (with GrovePi_Plus)​
Hardware
Raspberry piGrovePi_PlusGrove-4-Digit Display
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove-4-Digit Display to D5 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC through USB cable.
Software
  • Step 2. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
  • Step 3. Excute below commands to monitor the loudness.
cd ~/GrovePi/Software/Python
Here is the grove_4_digit_display.py code.
# NOTE: 4x red 7 segment display with colon and 8 luminance levels, but no decimal points
import time
import grovepi
# Connect the Grove 4 Digit Display to digital port D5
# CLK,DIO,VCC,GND
display = 5
grovepi.pinMode(display,"OUTPUT")
# If you have an analog sensor connect it to A0 so you can monitor it below
sensor = 0
grovepi.pinMode(sensor,"INPUT")
time.sleep(.5)
# 4 Digit Display methods
# grovepi.fourDigit_init(pin)
# grovepi.fourDigit_number(pin,value,leading_zero)
# grovepi.fourDigit_brightness(pin,brightness)
# grovepi.fourDigit_digit(pin,segment,value)
# grovepi.fourDigit_segment(pin,segment,leds)
# grovepi.fourDigit_score(pin,left,right)
# grovepi.fourDigit_monitor(pin,analog,duration)
# grovepi.fourDigit_on(pin)
# grovepi.fourDigit_off(pin)
while True:
try:
print ("Test 1) Initialise")
grovepi.fourDigit_init(display)
time.sleep(.5)
print ("Test 2) Set brightness")
for i in range(0,8):
grovepi.fourDigit_brightness(display,i)
time.sleep(.2)
time.sleep(.3)
# set to lowest brightness level
grovepi.fourDigit_brightness(display,0)
time.sleep(.5)
print ("Test 3) Set number without leading zeros")
leading_zero = 0
grovepi.fourDigit_number(display,1,leading_zero)
time.sleep(.5)
grovepi.fourDigit_number(display,12,leading_zero)
time.sleep(.5)
grovepi.fourDigit_number(display,123,leading_zero)
time.sleep(.5)
grovepi.fourDigit_number(display,1234,leading_zero)
time.sleep(.5)
print ("Test 4) Set number with leading zeros")
leading_zero = 1
grovepi.fourDigit_number(display,5,leading_zero)
time.sleep(.5)
grovepi.fourDigit_number(display,56,leading_zero)
time.sleep(.5)
grovepi.fourDigit_number(display,567,leading_zero)
time.sleep(.5)
grovepi.fourDigit_number(display,5678,leading_zero)
time.sleep(.5)
print ("Test 5) Set individual digit")
grovepi.fourDigit_digit(display,0,2)
grovepi.fourDigit_digit(display,1,6)
grovepi.fourDigit_digit(display,2,9)
grovepi.fourDigit_digit(display,3,15) # 15 = F
time.sleep(.5)
print ("Test 6) Set individual segment")
grovepi.fourDigit_segment(display,0,118) # 118 = H
grovepi.fourDigit_segment(display,1,121) # 121 = E
grovepi.fourDigit_segment(display,2,118) # 118 = H
grovepi.fourDigit_segment(display,3,121) # 121 = E
time.sleep(.5)
grovepi.fourDigit_segment(display,0,57) # 57 = C
grovepi.fourDigit_segment(display,1,63) # 63 = O
grovepi.fourDigit_segment(display,2,63) # 63 = O
grovepi.fourDigit_segment(display,3,56) # 56 = L
time.sleep(.5)
print ("Test 7) Set score")
grovepi.fourDigit_score(display,0,0)
time.sleep(.2)
grovepi.fourDigit_score(display,1,0)
time.sleep(.2)
grovepi.fourDigit_score(display,1,1)
time.sleep(.2)
grovepi.fourDigit_score(display,1,2)
time.sleep(.2)
grovepi.fourDigit_score(display,1,3)
time.sleep(.2)
grovepi.fourDigit_score(display,1,4)
time.sleep(.2)
grovepi.fourDigit_score(display,1,5)
time.sleep(.5)
print ("Test 8) Set time")
grovepi.fourDigit_score(display,12,59)
time.sleep(.5)
print ("Test 9) Monitor analog pin")
seconds = 10
grovepi.fourDigit_monitor(display,sensor,seconds)
time.sleep(.5)
print ("Test 10) Switch all on")
grovepi.fourDigit_on(display)
time.sleep(.5)
print ("Test 11) Switch all off")
grovepi.fourDigit_off(display)
time.sleep(.5)
except KeyboardInterrupt:
break
except IOError:
print ("Error")
  • Step 4. We will see the Grove-4-Digit Display as below.
pi@raspberrypi:~/GrovePi/Software/Python $ python grove_4_digit_display.py
Test 1) Initialise
Test 7) Set score
Test 8) Set time
Play with TI LaunchPad​
Displaying the Numbers (4-Digital-Display)
This example demonstrates how to display some digital numbers using a Grove-4-Digital Display.
* TM1637.cpp
* A library for the 4 digit display
#include "TM1637.h"
#define CLK 39 //pins definitions for TM1637 and can be changed to other ports
#define DIO 38
TM1637 tm1637(CLK,DIO);
tm1637.init();
tm1637.set(BRIGHT_TYPICAL);//BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
int8_t NumTab[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};//0~9,A,b,C,d,E,F
int8_t ListDisp[4];
unsigned char i = 0;
unsigned char count = 0;
delay(150);
while(1)
i = count;
count ++;
if(count == sizeof(NumTab)) count = 0;
for(unsigned char BitSelect = 0;BitSelect < 4;BitSelect ++)
ListDisp[BitSelect] = NumTab[i];
i ++;
if(i == sizeof(NumTab)) i = 0;
tm1637.display(0,ListDisp[0]);
tm1637.display(1,ListDisp[1]);
tm1637.display(2,ListDisp[2]);
tm1637.display(3,ListDisp[3]);
delay(300);
Schematic Online Viewer​
Resources​
Inspired by OVERWATCH, we have made a very cool Wooden Laser Gun toy for fun these day!
The Wooden Laser Gun and the Gun Target are all based on an Arduino board called Seeeduino Lotus. The laser emitter on the Laser Gun is controlled to fire laser pulse to "activate" the Gun Target. And there are 3 light sensors on the Gun Target to detect the laser pulse. It seems very simple right? If you are interested in our project, please make one for yourself or your child! It's worth to spend one day DIY it as a Xmas present.
Projects​
MSP430 Alarm Clock with Grove Modules: Create your own alarm clock using the MSP430F5529 LaunchPad and the SeeedStudio Grove Modules.
Clock - Grove 4-digit Display Using Photon: Your first clock with 4 components, based on Grove and TM1637
