Grove - 6-Position DIP Switch
The Grove - 6-Position DIP Switch has 6 individual switch positions, which use I2C to transmit date. It works great as a multi-channel control switches.
Version
| Product Version | Changes | Released Date |
| Grove - 6-Position DIP Switch | Initial | Jun 2018 |
- 6 individual switch
- Good heat resistance
- Long operating Life
- Grove compatible
| Item | Value |
| Operating voltage | 3.3V / 5V |
| Interface | I2C |
| Default I2C Address | 0x03 |
| Size | L: 40mm W: 20mm H: 13mm |
| Weight | 5g |
| Package size | L: 140mm W: 90mm H: 10mm |
| Gross Weight | 11g |
Applications
- Multifunction control
Hardware Overview
Pin Map
Platforms Supported
Getting Started
Play With Arduino
Hardware
Materials required
| Seeeduino V4.2 | Base Shield | Grove - 6-Position DIP Switch |
| Get One Now | Get One Now | Get One Now |
1 Please plug the USB cable gently, otherwise you may damage the port. Please use the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the Grove cable, you can click here to buy.
Step 1. Connect the Grove - 6-Position DIP Switch to the I2C port of the Base Shield.
Step 2. Plug Grove - Base Shield into Seeeduino.
Step 3. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect this module to Seeeduino as below.
| Seeeduino | Grove - 6-Position DIP Switch |
| 5V | Red |
| GND | Black |
| SDA | White |
| SCL | Yellow |
Software
Step 1. Download the Grove Multi Switch Library from Github.
Step 2. Refer to How to install library to install library for Arduino.
Step 3. Restart the Arduino IDE. Open example via the path: File --> Examples --> Grove Multi Switch Library --> Grove_Switch_Events.
Or, you can just click the icon
in upper right corner of the code block to copy the following code into a new sketch in the Arduino IDE.
#include "Grove_Multi_Switch.h"
GroveMultiSwitch mswitch[1];
const char* grove_5way_tactile_keys[] = {
"KEY A",
"KEY B",
"KEY C",
"KEY D",
"KEY E",
const char* grove_6pos_dip_switch_keys[] = {
"POS 1",
"POS 2",
"POS 3",
"POS 4",
"POS 5",
"POS 6",
const char** key_names;
int deviceDetect(void) {
if (!mswitch->begin()) {
Serial.println("***** Device probe failed *****");
return -1;
Serial.println("***** Device probe OK *****");
if (PID_VAL(mswitch->getDevID()) == PID_5_WAY_TACTILE_SWITCH) {
Serial.println("Grove 5-Way Tactile Switch Inserted!");
key_names = grove_5way_tactile_keys;
} else if (PID_VAL(mswitch->getDevID()) == PID_6_POS_DIP_SWITCH) {
Serial.println("Grove 6-Position DIP Switch Inserted!");
key_names = grove_6pos_dip_switch_keys;
// enable event detection
mswitch->setEventMode(true);
// report device model
Serial.print("A ");
Serial.print(mswitch->getSwitchCount());
Serial.print(" Button/Switch Device ");
Serial.println(mswitch->getDevVer());
return 0;
Serial.println("Grove Multi Switch");
// Initial device probe
if (deviceDetect() < 0) {
Serial.println("Insert Grove 5-Way Tactile");
Serial.println("or Grove 6-Position DIP Switch");
for (;;);
return;
GroveMultiSwitch::ButtonEvent_t* evt;
delay(1);
evt = mswitch->getEvent();
if (!evt) {
// dynamic device probe
deviceDetect();
return;
if (!(evt->event & GroveMultiSwitch::BTN_EV_HAS_EVENT)) {
#if 0
Serial.print("No event, errno = ");
Serial.println(mswitch->errno);
#endif
return;
for (int i = 0; i < mswitch->getSwitchCount(); i++) {
Serial.print(key_names[i]);
Serial.print(": RAW - ");
Serial.print((evt->button[i] & GroveMultiSwitch::BTN_EV_RAW_STATUS)?
"HIGH ": "LOW ");
"RELEASED ": "PRESSED ");
"OFF ": "ON ");
Serial.println("");
if (evt->button[i] & ~GroveMultiSwitch::BTN_EV_RAW_STATUS) {
Serial.println("");
Serial.print(": EVENT - ");
if (evt->button[i] & GroveMultiSwitch::BTN_EV_SINGLE_CLICK) {
Serial.print("SINGLE-CLICK ");
if (evt->button[i] & GroveMultiSwitch::BTN_EV_DOUBLE_CLICK) {
Serial.print("DOUBLE-CLICK ");
if (evt->button[i] & GroveMultiSwitch::BTN_EV_LONG_PRESS) {
Serial.print("LONG-PRESS ");
if (evt->button[i] & GroveMultiSwitch::BTN_EV_LEVEL_CHANGED) {
Serial.print("LEVEL-CHANGED ");
Serial.println("");
Step 4. Upload the demo. If you do not know how to upload the code, please check How to upload code.
Step 5. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor. Or tap the
ctrl+shift+mkey at the same time. Set the baud rate to 115200.
If every thing goes well, you will get the result. For instance, the default switch is off-High, when you turn the Switch6 to ON, the output will be POS 6: RAW - LOW ON.
Grove Multi Switch
A 6 Button/Switch Device BN-6--0.1
POS 1: RAW - HIGH OFF
POS 2: RAW - HIGH OFF
POS 3: RAW - HIGH OFF
POS 4: RAW - HIGH OFF
POS 5: RAW - HIGH OFF
POS 6: RAW - LOW ON
POS 6: EVENT - LEVEL-CHANGED
POS 1: RAW - LOW ON
POS 6: RAW - LOW ON
Schematic Online Viewer
Project
This is the introduction Video of this product, simple demos, you can have a try.
