Grove - Adjustable PIR Motion Sensor
Grove - Adjustable PIR Motion Sensor is an easy to use Passive Infrared motion sensor, which can detect infrared object motion up to 3 meters. Any infrared object moves in its detecting range, the sensor outputs HIGH on its SIG pin. And you can adjust the SIG HIGH time up to 130s via the potentiometer, moreover, you can adjust the detect range via the other potentiometer.
Version
| Product Version | Changes | Released Date |
| Grove - Adjustable PIR Motion Sensor | Initial | Sep 2018 |
- Built-in filter, high immunity to RFI
- Output time, sensitivity and detect range adjustable
- Low voltage, low power consumption
| Item | Value |
| Operating Voltage | 3.3V / 5V |
| Operating Temperature | -30℃ ~ 70℃ |
| Viewing Angel | Horizontal placement 80° Vertical placement 55° |
| Detction Spectral Response(λ) | 5nm ~ 14nm |
| Detction Distance | 0 ~ 3m |
| High Level On Time | <130s |
| Interface | Digital |
| Size | L: 40mm W: 20mm H: 15mm |
| Weight | 4.5g |
| Package size | L: 140mm W: 90mm H: 15mm |
| Gross Weight | 10g |
Typical applications
- PIR motion detection
- Intruder detection
- Occupancy detection
- Motion sensor lights
- Security system
- Automatic control
Hardware Overview
Pin Out
The Fresnel lens equipped with the module is a plastic piece and is prohibited from approaching high temperatures or open flames.
Schemaitc
Power
The typical voltage of L221D is 3.3V, so we use the XC6206P332MR chip to provide a stable 3.3V. The input of XC6206P33 ranges from 1.8V to 6.0V, so you can use this module with your Arduino both in 3.3V and 5V.
Platforms Supported
Getting Started
Play With Arduino
Hardware
Materials required
| Seeeduino V4.2 | Base Shield | Adjustable PIR Motion Sensor | Grove - Blue LED |
| Get One Now | Get One Now | Get One Now | Get One Now |
1 Please plug the USB cable gently, otherwise you may damage the port. Please use the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the Grove cable, you can click here to buy.
Step 1. Connect the Grove - Adjustable PIR Motion Sensor to port D2 of Grove-Base Shield, connect the Grobe - Blue LED to the D4 port of the Grove-Base Shield.
Step 2. Plug Grove - Base Shield into Seeeduino.
Step 3. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect this module to Seeeduino as below.
| Seeeduino | Grove Cable | Grove - Adjustable PIR Motion Sensor |
| GND | Black | GND |
| 5V or 3.3V | Red | VCC |
| NO connection | White | NC |
| D2 | Yellow | SIG |
| Seeeduino | Grove Cable | Grove - Blue LED |
| GND | Black | GND |
| D4 | Yellow | SIG |
Software
- Step 1. Just click the icon
in upper right corner of the code block to copy the following code into a new sketch in the Arduino IDE.
/*macro definitions of PIR motion sensor pin and LED pin*/
#define PIR_MOTION_SENSOR 2//Use pin 2 to receive the signal from the module
#define LED 4//the Grove - LED is connected to D4 of Arduino
pinsInit();
if(isPeopleDetected())//if it detects the moving people?
turnOnLED();
else
turnOffLED();
void pinsInit()
pinMode(PIR_MOTION_SENSOR, INPUT);
pinMode(LED,OUTPUT);
void turnOnLED()
digitalWrite(LED,HIGH);
void turnOffLED()
digitalWrite(LED,LOW);
/*Function: Detect whether anyone moves in it's detecting range*/
/*Return:-boolean, ture is someone detected.*/
boolean isPeopleDetected()
int sensorValue = digitalRead(PIR_MOTION_SENSOR);
if(sensorValue == HIGH)//if the sensor value is HIGH?
return true;//yes,return ture
else
return false;//no,return false
- Step 2. Upload the demo. If you do not know how to upload the code, please check How to upload code.
If every thing goes well, When someone approaches this sensor or when you approach this sensor with your hand, the LED will light up.
Schematic Online Viewer
