Grove - Electromagnet
An electromagnet is a type of magnet in which the magnetic field is produced by electric current. An electric current flowing in a wire creates a magnetic field around the wire, due to Ampere's law(see drawing below). To concentrate the magnetic field, in an electromagnet the wire is wound into a coil with many turns of wire lying side by side. The magnetic field of all the turns of wire passes through the center of the coil, creating a strong magnetic field there. Grove - Electromagnet can suck 1KG weight and hold on. It is easy to use, to learn electromagnet principle.
- Grove shape
- 1KG peak suction
- Low standby current
Specifications
| Item | Value |
| Working Voltage | DC 5V |
| Working Current | 400mA |
| Standby Current | 200uA |
| Load Weight | 1KG |
Platforms Supported
Getting Started
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Play With Arduino
Hardware
- Step 1. Prepare the below stuffs:
| Seeeduino V4.2 | Base Shield | Grove-Electromagnet |
| Get One Now | Get One Now | Get One Now |
- Step 2. Connect Grove-Electromagnet to port D2 of Grove-Base Shield.
- Step 3. Plug Grove - Base Shield into Seeeduino.
- Step 4. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect Grove-Electromagnet to Seeeduino as below.
| Seeeduino | Grove-Ultrasonic Ranger |
| 5V | Red |
| GND | Black |
| Not Conencted | White |
| D2 | Yellow |
Software
- Step 1. Please copy below code to Arduio IDE and upload to arduino. If you do not know how to upload the code, please check how to upload code.
Turns on an Electromagnet on for one second, then off for one second, repeatedly.
This example code is in the public domain.
int Electromagnet = 2;
int LED = 13;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(Electromagnet, OUTPUT);
pinMode(LED, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(Electromagnet, HIGH); // turn the Electromagnet on (HIGH is the voltage level)
digitalWrite(LED, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(Electromagnet, LOW); // turn the Electromagnet off by making the voltage LOW
digitalWrite(LED, LOW); // turn the LED off by making the voltage LOW
- Step 2. Grove-Electromagnet worked.
Play with Codecraft
Hardware
Step 1. Connect Grove - Electromagnet to port D2 of a Base Shield.
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
If this is your first time using Codecraft, see also Guide for Codecraft using Arduino.
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
When the code finishes uploaded, you can try to bring the ironwork close to the electromagnet. The LED on the Arduino 13 pin will be lighted up when the electromagnet is working.
Play With Raspberry Pi
Hardware
| Raspberry pi | GrovePi_Plus | Grove-Electromagnet |
Step 2. Plug the GrovePi_Plus into Raspberry.
Step 3. Connect Grove-Electromagnet to D4 port of GrovePi_Plus.
Step 4. Connect the Raspberry to PC through USB cable.
Software
Step 1. Follow Setting Software to configure the development environment.
Step 2. Follow Updating the Firmware to update the newest firmware of GrovePi.
In this wiki we use the path ~/GrovePi/ instead of /home/pi/Desktop/GrovePi, you need to make sure Step 2 and Step 3 use the same path.
We firmly suggest you to update the firmware, or for some sensors you may get errors.
- Step 3. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
- Step 4. Navigate to the demos' directory:
Here is the grove_electromagnet.py code.
import time
import grovepi
# The electromagnet can hold a 1KG weight
# Connect the Grove Electromagnet to digital port D4
# SIG,NC,VCC,GND
electromagnet = 4
grovepi.pinMode(electromagnet,"OUTPUT")
time.sleep(1)
while True:
try:
# Switch on electromagnet
grovepi.digitalWrite(electromagnet,1)
print "on"
time.sleep(2)
# Switch off electromagnet
grovepi.digitalWrite(electromagnet,0)
print "off"
time.sleep(2)
except KeyboardInterrupt:
break
except IOError:
print "Error"
5.Run the demo.
sudo python grove_electromagnet.py
Schematic Online Viewer
- [Eagle]Grove Electromagnet v1.0 SCH PCB.zip
- [Datasheet]Datasheet ZYE1-P20-15 PDF
- [Codecraft]CDC File
