Grove - Formaldehyde sensor
Grove Formaldehyde Sensor can detect formaldehyde around 0~1000 ppb with low cross-sensitivity to alcohol and high stability of 6 years lifetime. Built-in RHT sensor ensures it maintains fine performance under different temperatures and humidity and it transmits data through UART and I2C ports.
Features​
  • Low cross-sensitivity to alcohol
  • Standard formaldehyde measurement range: 0 ~ 1000 ppb
  • Long-term stability and 6 years’ service lifetime
  • Patented electrochemical cell with anti-dry technology
  • I2C/UART interface with lifetime-calibrated output
  • Maintain performance under different temperatures and humidity: compensated via Sensirion RHT sensor
Specification​
ParameterValue/Range
Supply voltage range3.3V or 5V
Measurement range0 to 1,000 ppb
Response time<2 min
Limit of detection<20 ppb
InterfaceI2C / UART
Formaldehyde accuracy±20 ppb or ±20% of measured value, whichever is larger
Platforms Supported​
ArduinoRaspberry
caution
Getting Started​
note
If this is the first time you work with Arduino, we highly recommend you to see Getting Started with Arduino before the start.
Play With Arduino​
Hardware​
  • Step 1. Prepare the below stuffs:
Seeeduino V4.2Base ShieldGrove-Formaldehyde Sensor
Get One NowGet One NowGet One Now
  • Step 2. Set the button on the Grove-Formaldehyde Sensor to the "1" position.
  • Step 3. Plug Grove - Base Shield into Seeeduino and set Grove-Formaldehyde Sensor to I²C port of Grove-Base Shield
  • Step 4. Connect Seeeduino to PC via a USB cable.
note
If you don't have Grove Base Shield, it still can be directly connected Grove-Formaldehyde Sensor to Seeeduino as below.
SeeeduinoGrove-Loudness Sensor
5VRed
GNDBlack
SDAWhite
SCLYellow
Software​
Also you can download the lib directly by searching Sensirion I2C SFA3X in the library manager.
#include <Arduino.h>
#include <SensirionI2CSfa3x.h>
#include <Wire.h>
SensirionI2CSfa3x sfa3x;
while (!Serial) {
delay(100);
Wire.begin();
uint16_t error;
char errorMessage[256];
sfa3x.begin(Wire);
// Start Measurement
error = sfa3x.startContinuousMeasurement();
if (error) {
Serial.print("Error trying to execute startContinuousMeasurement(): ");
Serial.println(errorMessage);
uint16_t error;
int16_t hcho;
int16_t humidity;
int16_t temperature;
error = sfa3x.readMeasuredValues(hcho, humidity, temperature);
if (error) {
Serial.print("Error trying to execute readMeasuredValues(): ");
} else {
Serial.print("Hcho:");
Serial.print(hcho / 5.0);
Serial.print("\t");
Serial.print("Humidity:");
Serial.print(humidity / 100.0);
Serial.print("\t");
Serial.print("Temperature:");
Serial.println(temperature / 200.0);
  • Step 4. In this program, Seeeduino can monitor the formaldehyde gas concentration, air humidity and temperature data in real-time. By opening the 'Serial Monitor', the results should be like:
Play With Raspberry Pi​
Hardware​
Raspberry piGrove Base Hat for Raspberry PiGrove-Formaldehyde Sensor
  • Step 2. Plug the Grove Base Hat for Raspberry Pi into Raspberry Pi.
  • Step 3. Connect Grove-Dust Sensor to I²C port of Grove Base Hat for Raspberry Pi.
  • Step 4. Connect the Raspberry Pi to PC through a USB cable.
Software​
  • Step 1. Follow Setting Software to configure the development environment of Resberry Pi.
  • Step 2. Download the Grove-Formaldehyde Sensor Library and unzip it to the Raspberry Pi.
  • Step 3. Navigate to the demos' directory. The following command can monitor the concentration of formaldehyde, humidity and temperature.
cd ~/raspberry-pi-i2c-sfa3x-master
make
./sfa3x_i2c_example_usage
In this wiki we use the path ~/embedded-sfa3x-main/i2c instead of /home/pi/Desktop/embedded-sfa3x-main/i2c, you need to make sure Step 2 and Step 3 use the same path.
Here is the sfa3x_i2c_example_usage.c code.
#include <stdio.h>  // printf
#include "sensirion_common.h"
#include "sensirion_i2c_hal.h"
#include "sfa3x_i2c.h"
* TO USE CONSOLE OUTPUT (PRINTF) IF NOT PRESENT ON YOUR PLATFORM
//#define printf(...)
int main(void) {
int16_t error = 0;
sensirion_i2c_hal_init();
error = sfa3x_device_reset();
if (error) {
printf("Error resetting device: %i\n", error);
return -1;
uint8_t device_marking[42];
error = sfa3x_get_device_marking(&device_marking[0], sizeof(device_marking));
if (error) {
printf("Error getting device marking: %i\n", error);
return -1;
printf("Device marking: %s\n", device_marking);
error = sfa3x_start_continuous_measurement();
if (error) {
printf("Error executing sfa3x_start_continuous_measurement(): %i\n",
error);
for (;;) {
// Read Measurement
int16_t hcho;
int16_t humidity;
sensirion_i2c_hal_sleep_usec(500000);
error = sfa3x_read_measured_values(&hcho, &humidity, &temperature);
if (error) {
printf("Error executing sfa3x_read_measured_values(): %i\n", error);
} else {
printf("Measurement:\n");
printf(" Formaldehyde concentration: %.1f\n", hcho / 5.0f);
printf(" Relative humidity: %.2f\n", humidity / 100.0f);
printf(" Temperature: %.2f\n", temperature / 200.0f);
error = sfa3x_stop_measurement();
if (error) {
printf("Error executing sfa3x_stop_measurement(): %i\n", error);
return 0;
If everything goes well, the following results can be displayed like:
pi@raspberrypi:~/Downloads/embedded-sfa3x-main/i2c $ ./sfa3x_i2c_example_usage
Device marking: 211117825F073B80
Measurement:
Formaldehyde concentration: 0.0
Relative humidity: 70.19
Temperature: 27.41
You can quit this program by simply press ++ctrl+c++.
Upgradable to Industrial Sensors​
