Grove - Laser PM2.5 Sensor (HM3301)
The Grove - Laser PM2.5 Sensor (HM3301) is a new generation of laser dust detection sensor, which is used for continuous and real-time detection of dust in the air.
Different from the pumping dust detection sensor, the HM-3301 innovatively uses fan blades to drive air, and the air flowing through the detection chamber is used as a test sample to perform real-time and continuous test on dust of different particle sizes in the air.
This module is suitable for dust detectors, intelligent air purifiers, intelligent air conditioners, intelligent ventilation fans, air quality testing, haze meters, environmental monitoring and relative products and applications
- High sensitivity on dust particles of 0.3 μm or greater
- Real-time & continuous detection of dust concentration in the air
- Based on laser light scattering technology, readings are accurate, stable, and consistent
- Low noise
- Ultra-low power consumption
| Item | Value |
| Operating Voltage | 3.3V / 5V |
| Operating temperature | -10~60℃ |
| Operating humidity | 10%~90%RH (non-condensing) |
| Partical size | 3 channels-- 1.0µm, 2.5µm, 10µm |
| Range (PM2.5 standard value) | 1~500µg/ m3 (Effective range) 1000 µg/ m3 (Maximum range) |
| Resolution | Concentration: 1µg/ m3 Counting concentration: 1s/0.1L |
| Stability time | 30 seconds after power-on |
| Interface | I2C |
| I2C address | 0x40 |
Typical applications
- Air purifier / air conditioner
- Air quality testing equipment
- Industrial PM value analysis
- Dust and smoke detection and analysis
- Real-time PM2.5, PM10, TSP detector
- Multichannel particle counter
- Environmental testing equipment
Hardware Overview
Pin Out
Working Principle
The HM-3301 Dust Sensor is based on the advanced Mie scattering theory. When light passes through particles with quantity same as or larger than wavelength of the light, it will produce light scattering. The scattered light is concentrated to a highly sensitive photodiode, which is then amplified and analyzed by a circuit. With specific mathematical model and algorithm, the count concentration and mass concentration of the dust particles is obtained.
The HM-3301 dust sensor is composed of main components such as a fan, an infrared laser source, a condensing mirror, a photosensitive tube, a signal amplifying circuit and a signal sorting circuit.
Platforms Supported
Getting Started
Play With Arduino
Hardware
Materials required
| Seeeduino V4.2 | Base Shield | Grove - Laser PM2.5 Sensor (HM3301) |
| Get One Now | Get One Now | Get One Now |
1 Please plug the USB cable gently, otherwise you may damage the port. Please use the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the Grove cable, you can click here to buy.
Step 1. Connect the Grove - Laser PM2.5 Sensor (HM3301) to port I^2^C of Grove-Base Shield.
Step 2. Plug Grove - Base Shield into Seeeduino.
Step 3. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect this module to Seeeduino as below.
| Seeeduino | Grove Cable | Grove - Laser PM2.5 Sensor (HM3301) |
| GND | Black | GND |
| 5V or 3.3V | Red | VCC |
| SDA | White | SDA |
| SCL | Yellow | SCL |
Software
Step 1. Download the Seeed_PM2_5_sensor_HM3301 Library from Github.
Step 2. Refer to How to install library to install library for Arduino.
Step 3. Restart the Arduino IDE. Open the example, you can open it in the following three ways:
Open it directly in the Arduino IDE via the path: File --> Examples --> PM2.5 sensor --> basic_demo.
Open it in your computer by click the basic_demo.ino which you can find in the folder XXXX\Arduino\libraries\Seeed_PM2_5_sensor_HM3301-master\examples\basic_demo, XXXX is the location you installed the Arduino IDE.
Or, you can just click the icon
in upper right corner of the code block to copy the following code into a new sketch in the Arduino IDE.
#include "Seeed_HM330X.h"
#define SERIAL SerialUSB
#else
#endif
HM330X sensor;
u8 buf[30];
const char *str[]={"sensor num: ","PM1.0 concentration(CF=1,Standard particulate matter,unit:ug/m3): ",
"PM2.5 concentration(CF=1,Standard particulate matter,unit:ug/m3): ",
"PM10 concentration(CF=1,Standard particulate matter,unit:ug/m3): ",
"PM1.0 concentration(Atmospheric environment,unit:ug/m3): ",
"PM2.5 concentration(Atmospheric environment,unit:ug/m3): ",
"PM10 concentration(Atmospheric environment,unit:ug/m3): ",
err_t print_result(const char* str,u16 value)
if(NULL==str)
return ERROR_PARAM;
SERIAL.print(str);
SERIAL.println(value);
return NO_ERROR;
/*parse buf with 29 u8-data*/
err_t parse_result(u8 *data)
u16 value=0;
err_t NO_ERROR;
if(NULL==data)
return ERROR_PARAM;
for(int i=1;i<8;i++)
value = (u16)data[i*2]<<8|data[i*2+1];
print_result(str[i-1],value);
err_t parse_result_value(u8 *data)
if(NULL==data)
return ERROR_PARAM;
for(int i=0;i<28;i++)
SERIAL.print(data[i],HEX);
SERIAL.print(" ");
if((0==(i)%5)||(0==i))
SERIAL.println(" ");
u8 sum=0;
sum+=data[i];
if(sum!=data[28])
SERIAL.println("wrong checkSum!!!!");
return NO_ERROR;
/*30s*/
SERIAL.begin(115200);
delay(100);
SERIAL.println("Serial start");
if(sensor.init())
SERIAL.println("HM330X init failed!!!");
while(1);
if(sensor.read_sensor_value(buf,29))
SERIAL.println("HM330X read result failed!!!");
parse_result_value(buf);
parse_result(buf);
delay(5000);
The library file may be updated. This code may not be applicable to the updated library file, so we recommend that you use the first two methods.
Step 4. Upload the demo. If you do not know how to upload the code, please check How to upload code.
Step 5. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor. Or tap the
ctrl+shift+mkey at the same time. Set the baud rate to 115200.
If every thing goes well, when you open the Serial Monitor it may show as below:
Serial start
0
FF 0 0 0 2D
0 3F 0 45 0
22 0 32 0 3B
0 0 0 0 0
0 0 0 0 0
0 0
sensor num: 0
PM1.0 concentration(CF=1,Standard particulate matter,unit:ug/m3): 45
PM2.5 concentration(CF=1,Standard particulate matter,unit:ug/m3): 63
PM10 concentration(CF=1,Standard particulate matter,unit:ug/m3): 69
PM1.0 concentration(Atmospheric environment,unit:ug/m3): 34
PM2.5 concentration(Atmospheric environment,unit:ug/m3): 50
PM10 concentration(Atmospheric environment,unit:ug/m3): 59
The standard particulate matter mass concentration value refers to the mass concentration value obtained by density conversion of industrial metal particles as equivalent particles, and is suitable for use in industrial production workshops and the like. The concentration of particulate matter in the atmospheric environment is converted by the density of the main pollutants in the air as equivalent particles, and is suitable for ordinary indoor and outdoor atmospheric environments. So you can see that there are two sets of data above.
Schematic Online Viewer
[PDF] Datasheet HM3301
Projects
Atmospheric Pollution Visualization:The air pollution problem attracts more and more attention. This time we tried to monitoring PM2.5 with Wio LTE and new Laser PM2.5 Sensor.
