Grove - Line Finder V1.1
Grove-Line finder is designed for line-following robot. It has an IR emitting LED and an IR sensitive phototransistor. It can output digital signal to a microcontroller so that the robot can follow a black line on white background, or vice versa.
Version
| Product Version | Changes | Released Date |
| Grove-Line Finder V1.0 | Initial | Jan 29 2010 |
| Grove-Line Finder V1.1 | Add test points | Dec 28 2015 |
| Parameter | Value/Range |
| Power supply | 5 |
| Digital output mode | TTL (High when black is detected, Low when white is detected) |
| Connector | 4 pin Buckled Grove interface |
| Dimension | 20mm*20mm |
| ROHS | Yes |
| Photo reflective diode | RS-06WD |
| Comparator | MV358 |
!!!Tip More details about Grove modules please refer to Grove System
Platform Supported
Getting Started
Play With Arduino
Hardware
- Step 1. Prepare the below stuffs:
| Seeeduino V4.2 | Base Shield | Grove - Button |
| Get One Now | Get One Now | Get One Now |
- Step 2. Connect Grove-line finder to port D3 of Grove-Base Shield.
- Step 3. Plug Grove - Base Shield into Seeeduino.
- Step 4. Connect Seeeduino to PC through a USB cable.
If we don't have Grove Base Shield, We also can directly connect Grove-Line finder to Seeeduino as below.
| Seeeduino | Grove-Line finder |
| 5V | Red |
| GND | Black |
| Not Conencted | White |
| D3 | Yellow |
Software
- Step 1. Copy the code into Arduino IDE and upload.
//Name: Line finder digital mode
//Function: detect black line or white line
//Parameter: When digital signal is HIGH, black line
// When digital signal is LOW, white line
int signalPin = 3; // connected to digital pin 3
pinMode(signalPin, INPUT); // initialize the digital pin as an output:
Serial.begin(9600); // initialize serial communications at 9600 bps:
// the loop() method runs over and over again,
// as long as the Arduino has power
if(HIGH == digitalRead(signalPin))
Serial.println("black");
else Serial.println("white"); // display the color
delay(1000); // wait for a second
- Step 2. Open the serial port and we will see "black" when put the sensor on top of black lines and "white" when on white area.
white
white
white
black
black
black
black
black
Play with Codecraft
Hardware
Step 1. Connect a Grove - Line Finder to port D3 of a Base Shield.
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
If this is your first time using Codecraft, see also Guide for Codecraft using Arduino.
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
When the code finishes uploaded, you will see line found or not in Serial Monitor.
Play With Raspberry Pi
Hardware
| Raspberry pi | GrovePi_Plus | Grove - Line Finder |
| Get ONE Now | Get ONE Now | Get ONE Now |
- Step 2. Plug the GrovePi_Plus into Raspberry.
- Step 3. Connect Grove-Line Finder to D7 port of GrovePi_Plus.
- Step 4. Connect the Raspberry to PC through USB cable.
Software
- Step 1. Follow Setting Software to configure the development environment.
- Step 2. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
- Step 3. Excute below commands.
cd ~/GrovePi/Software/Python
python grove_line_finder.py
Here is the grove_line_finder.py code.
import time
import grovepi
# Connect the Grove Line Finder to digital port D7
# SIG,NC,VCC,GND
line_finder = 7
grovepi.pinMode(line_finder,"INPUT")
while True:
try:
# Return HIGH when black line is detected, and LOW when white line is detected
if grovepi.digitalRead(line_finder) == 1:
print ("black line detected")
else:
print ("white line detected")
time.sleep(.5)
except IOError:
print ("Error")
- Step 4. We will see black line detected when the sensor is on top of black line.
pi@raspberrypi:~/GrovePi/Software/Python $ python grove_line_finder.py
black line detected
black line detected
white line detected
white line detected
Grove-Line Finder Schematic V1.0
Grove-Line Finder Schematic V1.1
- [Eagle&PDF] Grove-Line Finder Schematic V1.0
- [Eagle&PDF] Grove-Line Finder Schematic V1.1
- [Datasheet] LMV358.PDF
- [Codecraft] CDC File
