Grove - MP3 v3.0
The Grove - MP3 is a 20x40mm super mini Music module based on WT2003S-20SS audio decoder. It supports high-quality MP3 format audio files with a sampling rate of 848KHz and a bit rate of 8320Kbps. In order to expand the storage capacity, we added a TF card slot on the back of the module. TF card adopts DIO interface mode, supports up to 32GB, supports FAT16, FAT32 file system. Now with this little music module, you can carry hundreds and thousands of music in your pocket.
As the name indicates, the Grove - MP3 V3 is the upgraded version of Grove - MP3 V2. Compared with Grove MP3 V2, the V3 added a JST2.0 speaker port, so that you can output the audio via speaker and 3.5mm earphone at the same time.
Feature
- Supports MP3 format audio files
- Sampling rate: 8
48KHz / bit rate: 8320Kbps - Support up to 32GB TF card
- Support speaker and earphone output audio at the same time
- Compatible with 3.3V and 5V platform.
- Support 32-level volume adjustment
| Parameter | Value |
| Supply voltage | 3.3V / 5V |
| Sampling rate | 8 |
| Interface | I2C(Default I2C Address: 0x36) & Non-Changeable |
| Output | Speaker/3.5mm Audio Jack |
| Resolution | Support 32-level volume adjustment |
Hardware Overview
Platforms Supported
Getting Started
Play With Arduino
Materials required
| Seeeduino V4.2 | Base Shield | Grove - MP3 V3 -Music Player |
| Get ONE Now | Get ONE Now | Get ONE Now |
In addition, you can consider our new Seeeduino Lotus M0+, which is equivalent to the combination of Seeeduino V4.2 and Baseshield.
Hardware Connection
Step 1. Connect the Grove - MP3 V3 Music Player to the D2 port of the Base Shield.
Step 2. Plug Grove - Base Shield into Seeeduino.
Step 3 Connect the Seeeduino to PC via a USB cable.
Software
Step 1. Copy your
.mp3music file to the tf card and save them in the root location in the tf card. -
Step 2. Download the Seeed_Serial_MP3 Library from Github.
Refer How to install library to install library for Arduino.
- Step 3. Restart the Arduino IDE. Open WT2003S_Terminal_Player example via the path: File → Examples → Seeed_Serial_MP3_Player → WT2003S_Terminal_Player. You can play
.mp3format music file using this moudle, and use 3.5mm Audio Jack, Speaker via JST2.0 speaker port or even output both in the same time.
The WT2003S_Terminal_Player Example code is as follow:
#include "WT2003S_Player.h"
#ifdef __AVR__
#include <SoftwareSerial.h>
SoftwareSerial SSerial(2, 3); // RX, TX
#define COMSerial SSerial
#define ShowSerial Serial
WT2003S<SoftwareSerial> Mp3Player;
#endif
#define COMSerial Serial1
#define ShowSerial SerialUSB
WT2003S<Uart> Mp3Player;
#endif
#ifdef ARDUINO_ARCH_STM32F4
WT2003S<HardwareSerial> Mp3Player;
#endif
uint8_t vol = 10;
uint32_t spi_flash_songs = 0;
uint32_t sd_songs = 0;
STROAGE workdisk = SD;
struct Play_history {
uint8_t disk;
uint16_t index;
char name[8];
}* SPISong, *SDSong;
void readSongName(struct Play_history* ph, uint32_t num, STROAGE disk) {
Mp3Player.volume(0);
delay(100);
switch (disk) {
case SPIFLASH:
Mp3Player.playSPIFlashSong(0x0001);
break;
case SD:
Mp3Player.playSDRootSong(0x0001);
break;
case UDISK:
Mp3Player.playUDiskRootSong(0x0001);
break;
ShowSerial.println("2...");
for (int i = 0; i < num ; i++) {
delay(300);
ph[i].disk = disk;
ph[i].index = Mp3Player.getTracks();
Mp3Player.getSongName(ph[i].name);
Mp3Player.next();
ShowSerial.println("4...");
Mp3Player.pause_or_play();
Mp3Player.volume(14);
delay(100);
void getAllSong() {
uint8_t diskstatus = Mp3Player.getDiskStatus();
ShowSerial.println(diskstatus);
spi_flash_songs = Mp3Player.getSPIFlashMp3FileNumber();
ShowSerial.print("SPIFlash:");
ShowSerial.println(spi_flash_songs);
if (spi_flash_songs > 0) {
SPISong = (struct Play_history*)malloc((spi_flash_songs + 1) * sizeof(struct Play_history));
readSongName(SPISong, spi_flash_songs, SPIFLASH);
if (diskstatus && 0x02) { // have SD
sd_songs = Mp3Player.getSDMp3FileNumber();
ShowSerial.print("SD:");
ShowSerial.println(sd_songs);
if (sd_songs > 0) {
SDSong = (struct Play_history*)malloc((sd_songs + 1) * sizeof(struct Play_history));
ShowSerial.println("1...");
readSongName(SDSong, sd_songs, SD);
void printSongs() {
ShowSerial.print("-------------------");
ShowSerial.print("index");
ShowSerial.print("<-------->");
ShowSerial.print("name");
ShowSerial.println();
ShowSerial.println("-------------------spi flash-------------------------------");
for (int i = 0 ; i < spi_flash_songs; i++) {
ShowSerial.print(SPISong[i].index);
ShowSerial.print(SPISong[i].name);
ShowSerial.println("-------------------sd card-------------------------------");
for (int i = 0 ; i < sd_songs; i++) {
ShowSerial.print(SDSong[i].index);
ShowSerial.print(SDSong[i].name);
while (!ShowSerial);
ShowSerial.begin(9600);
COMSerial.begin(9600);
ShowSerial.println("+++++++++++++++++++++++++++++++++++++++++++++++++++++");
Mp3Player.init(COMSerial);
ShowSerial.println("0...");
getAllSong();
printMenu();
printSongs();
if (ShowSerial.available()) {
char cmd = ShowSerial.read();
switch (cmd) {
case '+': {
ShowSerial.print("Volume up: ");
vol = Mp3Player.getVolume();
Mp3Player.volume(++vol);
ShowSerial.print(vol);
break;
case '-': {
ShowSerial.print("Volume down: ");
if (--vol > 31) {
vol = 0;
Mp3Player.volume(vol);
break;
case 't': {
uint8_t status;
ShowSerial.print("status:");
status = Mp3Player.getStatus();
if (status == 0x01) {
ShowSerial.print("playing");
if (status == 0x02) {
ShowSerial.print("stop");
if (status == 0x03) {
ShowSerial.print("pause");
break;
case 'n': {
Mp3Player.next();
break;
case 'p': {
break;
case 'w': {
Mp3Player.playMode(SINGLE_SHOT);
break;
case 'x': {
Mp3Player.playMode(SINGLE_CYCLE);
break;
case 'y': {
Mp3Player.playMode(CYCLE);
break;
case 'z': {
Mp3Player.playMode(RANDOM);
break;
case 'c': {
ShowSerial.print(Mp3Player.copySDtoSPIFlash());
break;
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
ShowSerial.print("play:");
if (workdisk == SD) {
Mp3Player.playSDRootSong(cmd - '0' - 1);
ShowSerial.print(cmd + ": ");
ShowSerial.print(SDSong[cmd - '0'].name);
if (workdisk == SPIFLASH) {
Mp3Player.playSPIFlashSong(cmd - '0' - 1);
ShowSerial.print(SPISong[cmd - '0'].name);
break;
default:
break;
void printMenu(void) {
ShowSerial.println("MP3 Command List:");
ShowSerial.println("-----------------");
ShowSerial.println("'+' or '-' : raise/lower volume");
ShowSerial.println("'1' ~ '9' : select a song");
ShowSerial.println("'n' : next song");
ShowSerial.println("'s' : switch play disk, spi flash");
ShowSerial.println("'p' : play or pause");
ShowSerial.println("'w' : set playmode single no loop");
ShowSerial.println("'x' : set playmode single loop");
ShowSerial.println("'y' : set playmode all loop");
ShowSerial.println("'z' : set playmode random");
ShowSerial.println("'c' : Copy mp3 to SPIFlash");
ShowSerial.println(" (Yes, this really does go by copy order.)");
ShowSerial.println("Any other key to show this menu");
Step 3. Upload the demo. If you do not know how to upload the code, please check How to upload code.
Step 4. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor. Or tap the ++ctrl+shift+m++ key at the same time. Set the baud rate to 9600.
Step 5. The result should look like below. Follow the command list to play music or use other useful features.
Q1# TF card cannot be recognized.
A1: Check the file system of the TF card, make sure it is FAT16 or FAT32 file system.
- [ZIP] Grove - MP3 V3 Schematic
- [PDF] WT2003S Datasheet
