Grove - OLED Display 0.96 inch
Grove - OLED Display 0.96" module is an OLED monochrome 128×64dot matrix display module with Grove 4pin I2C Interface.Comparing to LCD, OLED screens are more competitive, which has a number of advantages such as high brightness, self-emission, high contrast ratio, slim / thin outline, wide viewing angle, wide temperature range, and low power consumption. It has bigger screen so that it can display more contents than the OLED 96×96.
Version​
Product VersionChangesReleased Date
Grove - OLED Display 0.96 inch V1.1InitialOct 2015
Features​
  • Grove compatible interface
  • Communicate Mode:I2C
  • Low power consumption
  • Display Color: White
  • Wide range of operating temperature:-20℃~70℃
  • I2C Address 0x3C
note
If you want to use multiplue I2C devices, please refer to Software I2C.
warning
Please notice: heavy impact or stress on the OLED will cause the breakdown of screen.
Specifications​
ItemsMinNormMaxUnit
Power Voltage (VCC)3.35.05.5V
Driver IC-SSD1308Z--
Display Color-White--
Dot Matrix-128×64--
Panel Size-26.7(W)×19.26(H)-mm
Active Area-21.74(W)×11.175 (H)-mm
Dot Pitch-0.17(W)×0.175 (H)-mm
Dot Size-0.15(W)×0.15 (H)-mm
Wide range of operating temperature--20~70-℃
Platforms Supported​
ArduinoRaspberry Pi
caution
Getting Started​
note
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Play With Arduino​
Demonstration​
The OLED128*64 uses all the pins of SSD1308 chip, the default original point is on the top left corner. You can also change the original point by adjusting the program and in order to display your desired patterns. For more details, please refer SSD1308_1.0.pdf and LY190-128064.pdf.
Hardware​
  • Step 1. Prepare the below stuffs:
Seeeduino V4Base ShieldGrove - OLED Display 0.96inch
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Plug the Grove OLED Display 128*64 onto the I2C port on Grove Base Shield.
  • Step 3. Plug Grove - Base Shield into Seeeduino.
  • Step 4. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove - OLED Display 0.96 inch to Seeeduino as below.
SeeeduinoGrove - OLED Display 0.96 inch
5VRed
GNDBlack
SDAWhite
SCLYellow
Software​
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_SSD1306_128X64_ALT0_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // SSD1306 and SSD1308Z are compatible
// U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); //Low spped I2C
void setup(void) {
u8g2.begin();
void loop(void) {
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_ncenB08_tr); // choose a suitable font
u8g2.drawStr(0,10,"Hello World!"); // write something to the internal memory
u8g2.sendBuffer(); // transfer internal memory to the display
  • Step 3. We can see "Hello World!" on screen.
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)​
Hardware​
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - OLED Display 0.96 inch
  • Step 2. Plug the Grove Base Hat into Raspberry.
  • Step 3. Connect the OLED display to the I2C port of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
Software​
note
If you are using Raspberry Pi with Raspberrypi OS >= Bullseye, you have to use this command line only with Python3.
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Enter the relevant virtual environment.
source ~/grove_env/env/bin/activate
cd ~/grove_env/grove.py/grove
  • Step 3. Excute below command to run the code.
  • The following is to check the grove_oled_display_128x64.py code.
less grove_oled_display_128x64.py
import time
from grove.i2c import Bus
_COMMAND_MODE = 0x80
_DATA_MODE = 0x40
_NORMAL_DISPLAY = 0xA6
_DISPLAY_OFF = 0xAE
_DISPLAY_ON = 0xAF
_INVERSE_DISPLAY = 0xA7
_SET_BRIGHTNESS = 0x81
BasicFont = [[0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x00, 0x5F, 0x00, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00],
[0x00, 0x14, 0x7F, 0x14, 0x7F, 0x14, 0x00, 0x00],
[0x00, 0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x00, 0x00],
[0x00, 0x23, 0x13, 0x08, 0x64, 0x62, 0x00, 0x00],
[0x00, 0x36, 0x49, 0x55, 0x22, 0x50, 0x00, 0x00],
[0x00, 0x00, 0x05, 0x03, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x1C, 0x22, 0x41, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x41, 0x22, 0x1C, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x08, 0x2A, 0x1C, 0x2A, 0x08, 0x00, 0x00],
[0x00, 0x08, 0x08, 0x3E, 0x08, 0x08, 0x00, 0x00],
[0x00, 0xA0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x08, 0x08, 0x08, 0x08, 0x08, 0x00, 0x00],
[0x00, 0x60, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x20, 0x10, 0x08, 0x04, 0x02, 0x00, 0x00],
[0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E, 0x00, 0x00],
[0x00, 0x00, 0x42, 0x7F, 0x40, 0x00, 0x00, 0x00],
[0x00, 0x62, 0x51, 0x49, 0x49, 0x46, 0x00, 0x00],
[0x00, 0x22, 0x41, 0x49, 0x49, 0x36, 0x00, 0x00],
[0x00, 0x18, 0x14, 0x12, 0x7F, 0x10, 0x00, 0x00],
[0x00, 0x27, 0x45, 0x45, 0x45, 0x39, 0x00, 0x00],
[0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30, 0x00, 0x00],
[0x00, 0x01, 0x71, 0x09, 0x05, 0x03, 0x00, 0x00],
[0x00, 0x36, 0x49, 0x49, 0x49, 0x36, 0x00, 0x00],
[0x00, 0x06, 0x49, 0x49, 0x29, 0x1E, 0x00, 0x00],
[0x00, 0x00, 0x36, 0x36, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x00, 0xAC, 0x6C, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x08, 0x14, 0x22, 0x41, 0x00, 0x00, 0x00],
[0x00, 0x14, 0x14, 0x14, 0x14, 0x14, 0x00, 0x00],
[0x00, 0x41, 0x22, 0x14, 0x08, 0x00, 0x00, 0x00],
[0x00, 0x02, 0x01, 0x51, 0x09, 0x06, 0x00, 0x00],
[0x00, 0x32, 0x49, 0x79, 0x41, 0x3E, 0x00, 0x00],
[0x00, 0x7E, 0x09, 0x09, 0x09, 0x7E, 0x00, 0x00],
[0x00, 0x7F, 0x49, 0x49, 0x49, 0x36, 0x00, 0x00],
[0x00, 0x3E, 0x41, 0x41, 0x41, 0x22, 0x00, 0x00],
[0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C, 0x00, 0x00],
[0x00, 0x7F, 0x49, 0x49, 0x49, 0x41, 0x00, 0x00],
[0x00, 0x7F, 0x09, 0x09, 0x09, 0x01, 0x00, 0x00],
[0x00, 0x3E, 0x41, 0x41, 0x51, 0x72, 0x00, 0x00],
[0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00, 0x00],
[0x00, 0x41, 0x7F, 0x41, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x20, 0x40, 0x41, 0x3F, 0x01, 0x00, 0x00],
[0x00, 0x7F, 0x08, 0x14, 0x22, 0x41, 0x00, 0x00],
[0x00, 0x7F, 0x40, 0x40, 0x40, 0x40, 0x00, 0x00],
[0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F, 0x00, 0x00],
[0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F, 0x00, 0x00],
[0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E, 0x00, 0x00],
[0x00, 0x7F, 0x09, 0x09, 0x09, 0x06, 0x00, 0x00],
[0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E, 0x00, 0x00],
[0x00, 0x7F, 0x09, 0x19, 0x29, 0x46, 0x00, 0x00],
[0x00, 0x26, 0x49, 0x49, 0x49, 0x32, 0x00, 0x00],
[0x00, 0x01, 0x01, 0x7F, 0x01, 0x01, 0x00, 0x00],
[0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F, 0x00, 0x00],
[0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F, 0x00, 0x00],
[0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F, 0x00, 0x00],
[0x00, 0x63, 0x14, 0x08, 0x14, 0x63, 0x00, 0x00],
[0x00, 0x03, 0x04, 0x78, 0x04, 0x03, 0x00, 0x00],
[0x00, 0x61, 0x51, 0x49, 0x45, 0x43, 0x00, 0x00],
[0x00, 0x7F, 0x41, 0x41, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x00],
[0x00, 0x41, 0x41, 0x7F, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x04, 0x02, 0x01, 0x02, 0x04, 0x00, 0x00],
[0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00],
[0x00, 0x01, 0x02, 0x04, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x20, 0x54, 0x54, 0x54, 0x78, 0x00, 0x00],
[0x00, 0x7F, 0x48, 0x44, 0x44, 0x38, 0x00, 0x00],
[0x00, 0x38, 0x44, 0x44, 0x28, 0x00, 0x00, 0x00],
[0x00, 0x38, 0x44, 0x44, 0x48, 0x7F, 0x00, 0x00],
[0x00, 0x38, 0x54, 0x54, 0x54, 0x18, 0x00, 0x00],
[0x00, 0x08, 0x7E, 0x09, 0x02, 0x00, 0x00, 0x00],
[0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C, 0x00, 0x00],
[0x00, 0x7F, 0x08, 0x04, 0x04, 0x78, 0x00, 0x00],
[0x00, 0x00, 0x7D, 0x00, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x80, 0x84, 0x7D, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x7F, 0x10, 0x28, 0x44, 0x00, 0x00, 0x00],
[0x00, 0x41, 0x7F, 0x40, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x7C, 0x04, 0x18, 0x04, 0x78, 0x00, 0x00],
[0x00, 0x7C, 0x08, 0x04, 0x7C, 0x00, 0x00, 0x00],
[0x00, 0x38, 0x44, 0x44, 0x38, 0x00, 0x00, 0x00],
[0x00, 0xFC, 0x24, 0x24, 0x18, 0x00, 0x00, 0x00],
[0x00, 0x18, 0x24, 0x24, 0xFC, 0x00, 0x00, 0x00],
[0x00, 0x00, 0x7C, 0x08, 0x04, 0x00, 0x00, 0x00],
[0x00, 0x48, 0x54, 0x54, 0x24, 0x00, 0x00, 0x00],
[0x00, 0x04, 0x7F, 0x44, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x3C, 0x40, 0x40, 0x7C, 0x00, 0x00, 0x00],
[0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C, 0x00, 0x00],
[0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C, 0x00, 0x00],
[0x00, 0x44, 0x28, 0x10, 0x28, 0x44, 0x00, 0x00],
[0x00, 0x1C, 0xA0, 0xA0, 0x7C, 0x00, 0x00, 0x00],
[0x00, 0x44, 0x64, 0x54, 0x4C, 0x44, 0x00, 0x00],
[0x00, 0x08, 0x36, 0x41, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x00, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x41, 0x36, 0x08, 0x00, 0x00, 0x00, 0x00],
[0x00, 0x02, 0x01, 0x01, 0x02, 0x01, 0x00, 0x00],
[0x00, 0x02, 0x05, 0x05, 0x02, 0x00, 0x00, 0x00]]
class GroveOledDisplay128x64(object):
HORIZONTAL = 0x00
VERTICAL = 0x01
PAGE = 0x02
def __init__(self, bus=1, address=0x3C):
self.bus = Bus(bus)
self.address = address
self.off()
self.inverse = False
self.mode = self.HORIZONTAL
self.clear()
self.on()
def on(self):
self.send_command(_DISPLAY_ON)
def off(self):
self.send_command(_DISPLAY_OFF)
def send_command(self, command):
self.bus.write_byte_data(self.address, _COMMAND_MODE, command)
def send_data(self, data):
self.bus.write_byte_data(self.address, _DATA_MODE, data)
def send_commands(self, commands):
for c in commands:
self.send_command(c)
def clear(self):
self.off()
for i in range(8):
self.set_cursor(i, 0)
self.puts(' ' * 16)
self.on()
self.set_cursor(0, 0)
@property
def inverse(self):
return self._inverse
@inverse.setter
def inverse(self, enable):
self.send_command(_INVERSE_DISPLAY if enable else _NORMAL_DISPLAY)
self._inverse = enable
@property
def mode(self):
return self._mode
@mode.setter
def mode(self, mode):
self.send_command(0x20)
self.send_command(mode)
self._mode = mode
def set_cursor(self, row, column):
self.send_command(0xB0 + row)
self.send_command(0x00 + (8*column & 0x0F))
self.send_command(0x10 + ((8*column>>4)&0x0F))
def putc(self, c):
C_add = ord(c)
if C_add < 32 or C_add > 127: # Ignore non-printable ASCII characters
c = ' '
C_add = ord(c)
for i in range(0, 8):
self.send_data(BasicFont[C_add-32][i])
def puts(self, text):
for c in text:
self.putc(c)
def show_image(self, image):
from PIL import Image
import numpy as np
im = Image.open(image)
bw = im.convert('1')
pixels = np.array(bw.getdata())
page_size = 128 * 8
for page in range(8):
start = page_size * page
end = start + page_size
for i in range(start, start + 128):
data = np.packbits(pixels[i:end:128][::-1])[0]
self.send_data(data)
def main():
display = GroveOledDisplay128x64()
display.set_cursor(0, 0)
display.puts('hello')
display.set_cursor(1, 4)
display.puts('world')
if __name__ == "__main__":
main()
  • Run this code
python grove_oled_display_128x64.py
It seems nothing happened in terminal, however you can find the most famous sentence in the cyber world if you check your oled.😄
note
If you use the I2C tool to scan the I2C address of the grove module, you may find two or more address. 0x04 is the adrress of the Grove Base Hat for Raspberry Pi.
Play With Raspberry Pi (with GrovePi_Plus)​
The python script for BeagleBone Green below also works for Raspberry Pi, But the I2C bus is different. On Raspberry Pi 2/3, the I2C bus is 1. The script with changing bus=2 to bus=1 will work on Pi.
Hardware​
Raspberry piGrovePi_PlusGrove - OLED Display 0.96 inch
Get One NowGet One NowGet One Now
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove - OLED Display 0.96 inch ranger to I2C-2 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC through USB cable.
Software​
  • Step 2. Navigate to the demos' directory:
  • Step 3. To see the code
nano Grove-OLED_Display_0.96inch.py   # "Ctrl+x" to exit #
import time
import smbus2 as smbus
_DATA_MODE = 0x40
_DISPLAY_OFF = 0xAE
_DISPLAY_ON = 0xAF
HORIZONTAL = 0x00
VERTICAL = 0x01
PAGE = 0x02
def __init__(self, bus=2, address=0x3C):
self.bus = smbus.SMBus(bus)
self.off()
self.clear()
self.on()
def on(self):
def off(self):
for c in commands:
def clear(self):
self.off()
for i in range(8):
self.puts(' ' * 16)
self.on()
@property
def inverse(self):
@inverse.setter
@property
def mode(self):
return self._mode
@mode.setter
self._mode = mode
def putc(self, c):
C_add = ord(c)
c = ' '
C_add = ord(c)
for c in text:
self.putc(c)
import numpy as np
page_size = 128 * 8
display = GroveOledDisplay128x64(bus=1)
  • Step 4: Install smbus2 library sudo pip install smbus2
  • Step 5: Run the code. We'll find that the Grove - OLED outputs "Hello World".
sudo python Grove-OLED_Display_0.96inch.py
Play With Beaglebone Green​
To begin editing programs that live on BBG, you can use the Cloud9 IDE and refer Beaglebone Green Wiki.
Here are the steps how to display "Hello World" on OLED.
Hardware​
  • Step 1. Connect Grove - OLED to Grove I2C socket on BBG.
  • Step 2. Connect Seeeduino to PC via a USB cable.
Software​
  • Step 1: Click the "+" in the top-right to create a new file.
  • Step 2: Copy and paste the following code into the new tab
import time
_DATA_MODE = 0x40
_DISPLAY_OFF = 0xAE
_DISPLAY_ON = 0xAF
HORIZONTAL = 0x00
VERTICAL = 0x01
PAGE = 0x02
self.off()
self.clear()
self.on()
def on(self):
def off(self):
for c in commands:
def clear(self):
self.off()
for i in range(8):
self.puts(' ' * 16)
self.on()
@property
def inverse(self):
@inverse.setter
@property
def mode(self):
return self._mode
@mode.setter
self._mode = mode
def putc(self, c):
C_add = ord(c)
c = ' '
C_add = ord(c)
for c in text:
self.putc(c)
import numpy as np
page_size = 128 * 8
display = GroveOledDisplay128x64(bus=2)
  • Step 3: Save the file by clicking the disk icon with with the .py extension.
  • Step 4: Install smbus2 library sudo pip3 install smbus2
sudo python3 Grove-OLED_Display_0.96inch.py
Schematic Online Viewer​
Resources​
