Grove - OR
This module provides the function of a logical OR gate. It is base on the 74HC1G32GW chip. The 74HC1G32GW is a high-speed Si-gate CMOS device that provides a 2-input OR function. The Grove - OR module therefore has two inputs on the left and one output on the right. The output of this logical OR gate module is HIGH when it gets a HIGH signal on any of the two inputs.
Simple OR gate function with two inputs and a single output
Makes integrating a Logical OR gate in your circuit a breeze
Uses Standard 4-pin Grove Cables to connect to other Grove modules
Usage
- See Grove - OR module typical usage
See also
Grove - AND
Grove - NOT
Availability
This Grove module is available as part of the following Grove Kit Series:
- Grove Mixer Pack V2
Note that this Grove - OR module is sold only as part of the above mentioned packs and is not available stand-alone from the Seeed Studio Bazaar.
Schematic Online Viewer
