Grove - Optical Rotary Encoder(TCUT1600X01)
The Grove - Optical Rotary Encoder(TCUT1600X01) is a transmissive sensor that includes an infrared emitter and two phototransistor detectors. Usually, the infrared emitter emits infrared rays, the phototransistor detectors receives the infrared rays, then the phototransistor is turned on, both of the output is High, the on-board LED indicators light up. When there is an obstacle blocking, the phototransistor can not receive the infrared rays, so the phototransistor will be turned off and both of the output will be Low, the on-board LED indicators fade away.
You can use this sensor as a rotary encoder to detect the speed or rotation, and thanks to the two phototransistor detectors, you even can detect the rotation direction.
- Double phototransistor detectors, can determine the direction of rotation
- On-board LED indicators
- Grove Interface
| Item | Value |
| Operating voltage | 3.3V / 5V |
| Operating temperature | -40°C to +105°C |
| Storage temperature Range | -40°C to +125°C |
| Emitter wavelength | 950 nm |
| Gap | 3 mm |
| Interface | Digital |
Applications
- Automotive optical sensors
- Accurate position sensor for encoder
- Sensor for motion, speed, and direction
- Sensor for “turn and push” encoding
Hardware Overview
Pin Map
Schemaitc
Power
The typical voltage of TCUT1600X01 is 5V, so we use the MP3120 current mode step-up converter to provide a stable 5V. The input of MP3120 ranges from 0.8V to 5V, so you can use this module with your Arduino both in 3.3V and 5V.
When the phototransistor detectors receive the infrared signal, the output should be High, and when the obstacle blocks the infrared, the OUT1 and OUIT2 should be Low. However due to the leakage current, it won't be 0V. The leakage voltage varies with the input voltage.
Mechanical Drawing
Directional Detection
Thanks to the two phototransistor detectors, we can detect the moving direction. If the obstacle moves from the left to right, The output states change should be 11 --> 01 --> 00 --> 10; in the same way, if the obstacle moves from the right to left, it should be 11 --> 10 --> 00 -->01.
Platforms Supported
| Arduino | Raspberry Pi |
Getting Started
Play With Arduino
Hardware
Materials required
| Seeeduino V4.2 | Base Shield | Grove - Optical Rotary Encoder |
| Get One Now | Get One Now | Get One Now |
1 Please plug the USB cable gently, otherwise you may damage the port. Please use the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the Grove cable, you can click here to buy.
Step 1. Connect the Grove - Optical Rotary Encoder to the D5 port of the Base Shield.
Step 2. Plug Grove - Base Shield into Seeeduino.
Step 3. Connect Seeeduino to PC via a USB cable.
If we don't have Grove Base Shield, We also can directly connect this module to Seeeduino as below.
| Seeeduino | Grove - Optical Rotary Encoder |
| 5V | Red |
| GND | Black |
| D6 | White |
| D5 | Yellow |
Software
- Step 1. Install the Encoder Library in the Arduino IDE. You can find this library by the following path: Sketch-->Include Library-->Manage Libraries
Then search for the encoder in the pop-up window. Find the Encoder by Paul Stoffregen, choose the Version1.4.1, then click Install.
When the library is installed you will see INSTALLED , click Close then.
Thanks for Paul for his splendid library.
Step 2. Restart the Arduino IDE. Open the example, you can open it in the following three ways:
- Open it directly in the Arduino IDE via the path: File --> Examples --> Encoder --> Basic.
- Open it in your computer by click the Basic.pde which you can find in the xxxx\Arduino\libraries\Encoder\examples\Basic, XXXX is the location you installed the Arduino IDE.
- Or, you can just click the icon
in upper right corner of the code block to copy the following code into a new sketch in the Arduino IDE.
/* Encoder Library - Basic Example
* http://www.pjrc.com/teensy/td_libs_Encoder.html
* This example code is in the public domain.
#include <Encoder.h>
// Change these two numbers to the pins connected to your encoder.
// Best Performance: both pins have interrupt capability
// Good Performance: only the first pin has interrupt capability
// Low Performance: neither pin has interrupt capability
Encoder myEnc(5, 6);
// avoid using pins with LEDs attached
Serial.begin(9600);
Serial.println("Basic Encoder Test:");
long oldPosition = -999;
long newPosition = myEnc.read();
if (newPosition != oldPosition) {
oldPosition = newPosition;
Serial.println(newPosition);
You can change two numbers to the pins connected to your encoder, for the Best Performance: both pins have interrupt capability, so you can change the code line 13 into Encoder myEnc(2, 3);, meanwhile, you should connect this sensor to the D2 of the baseshield.
Step 4. Upload the demo. If you do not know how to upload the code, please check How to upload code.
Step 5. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor. Or tap the ++ctrl+shift+m++ key at the same time. Set the baud rate to 9600.
If every thing goes well, you will get the result. When you move the obstacle from left to right, the count value will increase by 1; when you move the obstacle from right to left, the count value will be decremented by 1.
Basic Encoder Test:
0
1
2
3
4
3
2
1
0
-1
-2
-3
-4
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)
Hardware
- Step 1. Things used in this project:
| Raspberry pi | Grove Base Hat for RasPi | Grove - Optical Rotary Encoder |
- Step 2. Plug the Grove Base Hat into Raspberry.
- Step 3. Connect the Grove - OLED Display 1.12'' to I2C port of the Base Hat.
- Step 4. Connect the Raspberry Pi to PC through USB cable.
Software
- Step 1. Follow Setting Software to configure the development environment install the grove.py to your raspberry pi.
- Step 2. Excute below commands to run the code.
# virutalenv for Python3
virtualenv -p python3 env
source env/bin/activate
#enter commmand
grove_optical_rotary_encoder
Following is the grove_optical_rotary_encoder.py code.
This is the code for
- Grove - Optical Rotary Encoder(TCUT1600X01) <https://www.seeedstudio.com/Grove-Optical-Rotary-Encoder-TCUT1600X0-p-3142.html>`_
Examples:
.. code-block:: python
from grove.grove_button import GroveButton
import time, sys
# connect to pin 5 (slot D5)
PIN = 5
encoder = GroveOpticalRotaryEncoder(PIN)
# Read the value every second and detect motion
while True:
print("\rPosition: {0} ".format(encoder.position()), file=sys.stderr, end='')
time.sleep(0.001)
from __future__ import print_function
import time, sys, signal, atexit
from grove.gpio import GPIO
__all__ = ["GroveOpticalRotaryEncoder"]
# The UPM version rotaryencoder has bug result in segment fault.
# This pure python version could work well.
class GroveOpticalRotaryEncoder(object):
Grove optical Rotary Encoder(TCUT1600X01) class
Args:
pin(int): the number of gpio/slot your grove device connected.
def __init__(self, pin1, pin2 = None):
pin2 = pin1 + 1 if pin2 is None else pin2
self.__gpio = GPIO(pin1, GPIO.IN)
self.__gpio2 = GPIO(pin2, GPIO.IN)
self.__gpio.on_event = self.__gpio_event
self._pos = 0
# called by GPIO library
def __gpio_event(self, pin, value):
v1 = self.__gpio.read()
if not v1: return
v2 = self.__gpio2.read()
self._pos += 1 if v2 else -1
def position(self, pos = None):
set or get the position counter
Args:
pos(int):
optinal, the position counter to be set.
if not specified, only get the current counter
Returns:
(int): current position counter
if not pos is None:
self._pos = pos
return self._pos
def main():
from grove.helper import SlotHelper
sh = SlotHelper(SlotHelper.GPIO)
pin = sh.argv2pin()
from upm.pyupm_rotaryencoder import RotaryEncoder as GroveOpticalRotaryEncoder
from mraa import getGpioLookup
mraa_pin1 = getGpioLookup("GPIO%02d" % (pin + 0))
mraa_pin2 = getGpioLookup("GPIO%02d" % (pin + 1))
# Instantiate a Grove Rotary Encoder, using signal pins mraa_pin1 & mraa_pin2
myRotaryEncoder = GroveOpticalRotaryEncoder(mraa_pin1, mraa_pin2);
myRotaryEncoder = GroveOpticalRotaryEncoder(pin)
## Exit handlers ##
# This function stops python from printing a stacktrace when you hit control-C
def SIGINTHandler(signum, frame):
raise SystemExit
# This function lets you run code on exit, including functions from myRotaryEncoder
def exitHandler():
print("Exiting")
sys.exit(0)
# Register exit handlers
atexit.register(exitHandler)
signal.signal(signal.SIGINT, SIGINTHandler)
counter = 0
while True:
print("\rPosition: {0} ".format(myRotaryEncoder.position()), file=sys.stderr, end='')
counter += 1
if counter >= 5000:
print("")
counter = 0
time.sleep(0.001)
if __name__ == '__main__':
main()
(env)pi@raspberrypi:~ grove_optical_rotary_encoder
When the command runs successfully, it will print out the value every second and detect motion.
while True:
time.sleep(0.001)
You can quit this program by simply press ctrl+c.
Schematic Online Viewer
[PDF] Datasheet of TCUT1600X01
[PDF] Datasheet of MP3120
Project
This is the introduction Video of this product, simple demos, you can have a try.
