Grove - Red LED
Grove - Red LED is similar to the Grove - LED module which houses an LED light source. In addition, it also has a potentiometer on-board to manage the power requirements of the LED. The PCB of this module has mounting holes which can be mounted on the required surface of your prototype. For example, it can be used as a pilot lamp for indicating power or signal presence.
Version​
Product VersionChangesReleased Date
Grove-LED_v1.3InitialMar 15 2016
Features​
  • Provide an LED light indication for your project
  • Support different color LEDs, the LED is pluged into the LED holder rather than soldered on the board
  • Support brightness control and higher range of input voltages with On-board potentiometer adjustment
Platforms Supported​
ArduinoRaspberry Pi
caution
Getting Started​
Play With Arduino​
Hardware​
  • Step 1. Prepare the below stuffs:
Seeeduino V4.2Base ShieldGrove - Red LED
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Connect Grove-Red LED to port D2 of Grove-Base Shield.
  • Step 3. Plug Grove - Base Shield into Seeeduino.
  • Step 4. Connect Seeeduino to PC through a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove-Red_Led to Seeeduino as below.
SeeeduinoGrove-Red Led
3.3VRed
GNDBlack
Not ConenctedWhite
D2Yellow
Software​
  • Step 1. Copy the code into Arduino IDE and upload.
// initialize digital pin2 as an output.
pinMode(2, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(2, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(2, LOW); // turn the LED off by making the voltage LOW
  • Step 2. We will see the LED on and off.
Play with Codecraft​
Hardware​
Step 1. Connect Grove - Red LED to port D2 of a Base Shield.
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software​
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
note
If this is your first time using Codecraft, see also Guide for Codecraft using Arduino.
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
success
When the code finishes uploaded, you will see the LED blinking.
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)​
Hardware​
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - Red LED
  • Step 2. Plug the Grove Base Hat into Raspberry.
  • Step 3. Connect the Red LED to port 12 of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
note
For step 3 you are able to connect the Red LED to any GPIO Port but make sure you change the command with the corresponding port number.
Software​
note
If you are using Raspberry Pi with Raspberrypi OS >= Bullseye, you have to use this command line only with Python3.
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Download the source file by cloning the grove.py library.
cd ~
  • Step 3. Excute below command to run the code.
cd yourpath/grove.py/grove
python3 grove_led.py 12
If you connect the Red LED to the different port of the Base Hat, instead of excuting python grove_led.py 12, you should run the following command.
python3 grove_led.py portnumber
Following is the grove_led.py code.
from grove.gpio import GPIO
class GroveLed(GPIO):
def __init__(self, pin):
super(GroveLed, self).__init__(pin, GPIO.OUT)
def on(self):
self.write(1)
def off(self):
self.write(0)
Grove = GroveLed
def main():
import sys
import time
if len(sys.argv) < 2:
print('Usage: {} pin'.format(sys.argv[0]))
sys.exit(1)
led = GroveLed(int(sys.argv[1]))
while True:
led.on()
time.sleep(1)
led.off()
time.sleep(1)
if __name__ == '__main__':
main()
success
If everything goes well, you will be able to see the led on and off.
note
For most of the grove modules, you need to add the pin number parameter, as in this example python3 grove_led.py 12, 12 is the chosen GPIO pin and the output from pin 12 will feed the led.
Play With Raspberry Pi (with GrovePi_Plus)​
Hardware​
Raspberry piGrovePi_PlusGrove - Red Led
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove-Red Led to D4 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC through USB cable.
Software​
note
  • Step 2. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
  • Step 3. Excute below commands.
cd ~/GrovePi/Software/Python
python3 grove_led_blink.py
Here is the grove_led_blink.py code.
import time
from grovepi import *
# Connect the Grove LED to digital port D4
led = 4
pinMode(led,"OUTPUT")
time.sleep(1)
print ("This example will blink a Grove LED connected to the GrovePi+ on the port labeled D4. If you're having trouble seeing the LED blink, be sure to check the LED connection and the port number. You may also try reversing the direction of the LED on the sensor.")
print (" ")
print ("Connect the LED to the port labele D4!" )
while True:
try:
#Blink the LED
digitalWrite(led,1) # Send HIGH to switch on LED
print ("LED ON!")
time.sleep(1)
digitalWrite(led,0) # Send LOW to switch off LED
print ("LED OFF!")
time.sleep(1)
except KeyboardInterrupt: # Turn LED off before stopping
digitalWrite(led,0)
break
except IOError: # Print "Error" if communication error encountered
print ("Error")
  • Step 4. We will see the led on and off.
pi@raspberrypi:~/GrovePi/Software/Python $ python3 grove_led_blink.py
LED ON!
LED OFF!
LED ON!
LED OFF!
Resources​
Projects​
Using Grove Button To Control Grove LED: How to connect and use Grove Button to control Grove LED socket kit.
Button and LED Grove modules:
