Grove - Screw Terminal
Grove - Screw Terminal with four 3.5mm pitch pins rate up to 125V @ 6A. Terminal can accept 30 to 20AWG wire. It is the most common pitch screw terminal. This grove has four ports, including GND, VCC and two other undefined ports. Screw terminals are commonly used to connect a chassis ground, such as on a record player or a surge protector. Most public address systems in buildings also use them for speakers, and sometimes for other outputs and inputs.
Version
| Product Version | Changes | Released Date |
| Grove-Screw Terminal V1.0 | Initial | Oct 2011 |
- 3.5mm standard pitch pin
- High current/voltage adaptable
Platforms Supported
Schematic Online Viewer
[Eagle&PDF]Grove-Screw Terminal.zip
Projects
Family, Friend Or Foe - PIR Arm/disarm Using BLE: It's a BLE-enabled, cloud-connected smartphone app used to control & monitor who/when PIR is armed/disarmed. Uses Slack for notifications.
