Grove-Single Axis Analog Gyro
The Grove – Signal Axis Analog Gyro is based on an angular velocity sensor (Murata-ENC-03R) that uses the phenomenon of Coriolis force. It can only measure the X-axis angular velocity, which is different from other 3-Axis gyro, but with a higher speed. It can be used for the position control and attitude control like the self-balanced 2WD.
Model: SEN05091P
Feature
Input Voltage: 3.3V/5V
Standard Grove Interface
Light Weight
High Speed
Measure X-axis Angular Velocity
Demonstration
With Arduino
The module detects one-axis rotation with analog signal. High-pass filter and low-pass filter circuit are applied to reduce the temperature drift and suppress the output noise. Before the measurement of the angular velocity, a reference value(the sensor output at Angular Velocity=0) is required. This value is 1.35V in default. But in order to get more accurate reference values, before the measurement,a calibration is necessary. In this calibration, the output voltage when angular velocity =0 been sampled 200 times, and then the average of these data will be treated as the reference value.
1.Connect it to A0 port of Grove - Base Shield, of cause any pin of the analog pins would be OK.
2.Plug the Grove - Base Shield into Arduino/Seeeduino and connect them to PC using a USB cable.
3.Upload the below code.Please click here if you do not know how to upload.
int sensorPin = A0; // select the input pin for the sensor
float reference_Value=0;
int sensorValue = 0; // variable to store the value coming from the sensor
int i;
float sum=0;
pinMode(sensorPin, INPUT);
Serial.begin(9600);
Serial.println("Please do not rotate it before calibrate!");
Serial.println("Get the reference value:");
for(i=0;i<1000;i++)
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
sum += sensorValue;
delay(5);
reference_Value = sum/1000.0;
Serial.println(reference_Value);
Serial.println("Now you can begin your test!");
double angularVelocity;
angularVelocity =((double)(sensorValue-reference_Value)*4930.0)/1023.0/0.67; //get the angular velocity
Serial.print(angularVelocity);
Serial.println("deg/s");
Serial.println(" ");
delay(10);
- Now, it is time to the calibration. Put the sensor on your desk horizontally ,and then press the Reset button on the Seeeduino, and then Open the serial tool:
- As you see the "Now you can begin your test", that means the calibration done. You can use the sensor now. Rotating direction can reference the following picture:
With Raspberry Pi
You should have got a raspberry pi and a grovepi or grovepi+.
You should have completed configuring the development enviroment, otherwise follow here.
Connection
- Plug the sensor to grovepi socket A0 by using a grove cable.
- Navigate to the demos' directory:
- To see the code
nano grovesingleaxisanaloggyro.py # "Ctrl+x" to exit #
import time
import grovepi
#Connect the Grove Single Axis Analog Gyro to analog port A0
#SIG,NC,VCC,GND
sensor = 0
grovepi.pinMode(sensor,"INPUT")
#calibration
print "calibrating..."
sum = 0
errors = 0
for x in range(0, 100):
try:
#Get sensor value
v = grovepi.analogRead(sensor)
sum += v
#time.sleep(.05)
except IOError:
print "Error"
errors += 1
if errors == 100:
print "unable to calibrate"
raise SystemExit
reference_value = sum / (100 - errors)
print "finished calibrating"
print "reference_value =", reference_value
#ready
while True:
try:
#Get sensor value
sensor_value = grovepi.analogRead(sensor)
#Calculate angular velocity (deg/s)
velocity = ((float)(sensor_value - reference_value) * 4930.0) / 1023.0 / 0.67
print "sensor_value =", sensor_value, " velocity =", velocity
time.sleep(.5)
except IOError:
print "Error"
5.Run the demo.
sudo python grovesingleaxisanaloggyro.py
Schematic Online Viewer
Resource
[Eagle] Grove - Signal Axis Analog Gyro Eagle
[PDF] Grove - Signal Axis Analog Gyro Sch
[PDF] Grove - Signal Axis Analog Gyro PCB
[Datasheet] File Signal Axis Analog Gyro datasheet
[Code] Demo code on github
