Grove - Speaker
The Grove- Speaker is a module which consists of power amplification and voice outputs. The loudness can be adjusted by the on-board potentiometer. With different input frequencies, the loud-speaker generates different tones. Coding the music into arduino, DIY your own music box!
- Volume Adjustable
- Grove Interface
Specifications
| Item | Min | Typical | Max | Unit |
| Working Voltage | 4.0 | 5.0 | 5.5 | VDC |
| Voltage Gain | - | - | 46 | db |
| Band Width | - | - | 20 | KHz |
Platforms Supported
Usage
Play with Arduino
The speaker can emit a variety of sounds like a car horn, doorbell and ignition . The different sounds are based on the frequency of the input signal.
You can supply different frequency signal to this module with Arduino. Arduino generates these signal via PWM or even digital write and delay.Here we are going to show you how to generate these signals using delay(), the speaker sound bass 1~7.
/*macro definition of Speaker pin*/
#define SPEAKER 3
int BassTab[]={1911,1702,1516,1431,1275,1136,1012};//bass 1~7
pinInit();
/*sound bass 1~7*/
for(int note_index=0;note_index<7;note_index++)
sound(note_index);
delay(500);
void pinInit()
pinMode(SPEAKER,OUTPUT);
digitalWrite(SPEAKER,LOW);
void sound(uint8_t note_index)
for(int i=0;i<100;i++)
digitalWrite(SPEAKER,HIGH);
delayMicroseconds(BassTab[note_index]);
Due to the influence of the capacitance, the module can only output the bass signal, and the treble is unable to emit.
Play with Codecraft
Hardware
Step 1. Connect Grove - Speaker to port D3 in a Base Shield
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
If this is your first time using Codecraft, see also Guide for Codecraft using Arduino.
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
When the code finishes uploaded, you will hear the Speaker making a DO to SI sound.
Schematic Online Viewer
- Grove - Speaker Eagle File
- How to generate different tone with MCU
- Grove_-_Speaker_v1.0_brd.pdf
- Grove_-_Speaker_v1.0_sch.pdf
- LM386 Low Voltage Audio Power Amplifier Datasheet
- CodeCraft Code
