Grove - Speaker Plus
Grove Speaker Plus consists of a powerful amplifier driver board and high-quality speaker. The speaker generates different tones with different input frequency, easy to control with PWM signal. You could create distinctive sound effects, play your favourite songs, or build your own music box with easy coding or a large number of existing music code.
Compare to the last version of Grove Speaker, Grove Speaker Plus has a better quality speaker with separated and replaceable speaker design, which enables you to replace with other loudspeakers you like. With the help of the on-board potentiometer, you can easily adjust the output volume. Already tired of fixed speaker with poor sound quality? Want to connect and play your own speaker? Here is your choice.
- Good sound quality speaker with high volume
- Separated and replaceable speaker design
- Sound adjustable function with onboard potentiometer
- Easy to use plug and play interface
Specifications
| Parameters | Values |
| Dimensions | 130mm x90mm x12mm |
| Weight | G.W 12g |
Platforms Supported
Getting Started
Materials Requied
| Seeeduino Lotus | Grove Speaker Plus |
| Get ONE Now | Get ONE Now |
Hardware Connection
Usage
Play with Arduino
The speaker can emit a variety of sounds like a car horn, doorbell and ignition . The different sounds are based on the frequency of the input signal.
You can supply different frequency signal to this module with Arduino. Arduino generates these signal via PWM or even digital write and delay. Here we are going to show you how to generate these signals using delay(), the speaker sound bass 1~7.
| Note | Corresponding frequency | Half cycle |
| 1 | 261.6255653 | 1911.128216 |
| 1.5 | 277.182631 | 1803.864832 |
| 2 | 293.6647679 | 1702.621678 |
| 2.5 | 311.1269837 | 1607.060866 |
| 3 | 329.6275569 | 1516.863471 |
| 4 | 349.2282314 | 1431.728466 |
| 4.5 | 369.9944227 | 1351.371722 |
| 5 | 391.995436 | 1275.525055 |
| 5.5 | 415.3046976 | 1203.935334 |
| 6 | 440 | 1136.363636 |
| 6.5 | 466.1637615 | 1072.584446 |
| 7 | 493.8833013 | 1012.384907 |
Software Code
Step 1. Connect Grove - Speaker Plus to port D3 in a Base Shield and plug the Base Shield to your Seeeduino.
Step 2. Link Seeeduino to your PC via an USB cable.
Step 3. Upload the code below into your Arduino IDE.
/*macro definition of Speaker pin*/
#define SPEAKER 3
int BassTab[]={1911,1702,1516,1431,1275,1136,1012};//bass 1~7
pinInit();
/*sound bass 1~7*/
for(int note_index=0;note_index<7;note_index++)
sound(note_index);
delay(500);
void pinInit()
pinMode(SPEAKER,OUTPUT);
digitalWrite(SPEAKER,LOW);
void sound(uint8_t note_index)
for(int i=0;i<100;i++)
digitalWrite(SPEAKER,HIGH);
delayMicroseconds(BassTab[note_index]);
Note
Due to the influence of the capacitance, the module can only output the bass signal, and the treble is unable to emit.When the code finishes uploaded, you will hear the Speaker making a DO to SI sound.
Schematic Online Viewer
