Grove - Temperature&Humidity Sensor Pro(DHT22)
This is a powerful sister version of our Grove - Temperature&Humidity Sensor Pro. It has more complete and accurate performance than the basic version. The detecting range of this sensor is 5% RH - 99% RH, and -40°C - 80°C. And its accuracy reaches up to 2% RH and 0.5°C. A professional choice for applications that have relatively strict requirements.
SenseCAP S210x series industrial sensors provide an out-of-box experience for environmental sensing. Please refer to the S2101 Wireless Temperature and Humidity Sensor with higher performance and robustness for air quality monitoring. The series includes sensors for soil moisture, air temperature and humidity, light intensity, CO2, EC, and an 8-in-1 weather station. Try the latest SenseCAP S210x for your next successful industrial project.
SenseCAP Industrial Sensor
S2101 Air Temp & Humidity
ItemMinNormMaxUnit
Input voltage (VCC)3.3-6V
I/O Logic Level-based on VCC-V
Measuring Current Supply1-1.5mA
Standby Current Supply40-50uA
Measuring range (Humidity)5%-99%RH
Measuring range (Temperature)-40-80°C
Accuracy (Humidity)--±2%RH
Accuracy (Temperature)--±0.5°C
Resolution (Humidity)--0.1%RH
Resolution (Temperature)--0.1°C
Repeatability (Humidity)--±0.3%RH
Repeatability (Temperature)--±0.2°C
Long-term Stability--±0.5%RH/year
Signal Collecting Period-2-S
Respond Time 1/e(63%)6-20S
Signal pin mode-Digital--
Platforms Supported
ArduinoRaspberry Pi
caution
Getting Started
note
Play With Arduino
Hardware
Materials required
Seeeduino V4.2Base ShieldTemperature&Humidity Sensor Pro
Get One NowGet One NowGet One Now
note
1 Please plug the USB cable gently, otherwise you may damage the port. Please use the USB cable with 4 wires inside, the 2 wires cable can't transfer data. If you are not sure about the wire you have, you can click here to buy
2 Each Grove module comes with a Grove cable when you buy. In case you lose the Grove cable, you can click here to buy
  • Step 1. Connect Grove - Temperature&Humidity Sensor Pro to port D2 of Grove-Base Shield.
  • Step 2. Plug Grove - Base Shield into Seeeduino.
  • Step 3. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove - Temperature and Humidity Sensor Pro to Seeeduino as below.
SeeeduinoTemperature&Humidity Sensor Pro
5VRed
GNDBlack
Not ConenctedWhite
D2Yellow
Software
  • Step 1. Download the Seeed DHT library from Github.
  • Step 2. Refer to How to install library to install library for Arduino.
  • Step 3. Restart the Arduino IDE. Open “ DHTtester” example via the path: File --> Examples --> Grove_Humidity_Temperature_Sensor-master --> DHTtester. Through this demo, we can read the temperature and relative humidity information of the environment.
note
This Grove - Temperature&Humidity Sensor Pro and our another product Grove-Temperature and Humidity Sensor are sharing this library. No matter which product you are using, make sure that you have made the definition line of the sensor of your board into effect and commented out the definition lines of other specs. For example, the sensor we used on Grove - Temperature and Humidity Sensor Pro is DHT 22. So the definition part of the sensor spec should be:
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
  • Step 4. Upload the demo. If you do not know how to upload the code, please check How to upload code.
  • Step 5. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor. Or tap the ++ctrl+shift+m++ key at the same time. if every thing goes well, you will get the result.
The result should be like:
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)
Hardware
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - Temp & Hum Sensor Pro
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Plug the Grove Base Hat into Raspberry.
  • Step 3. Connect the temperature and humidity sensor pro to port 12 of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
note
For step 3 you are able to connect the temperature and humidity sensor pro to any GPIO Port but make sure you change the command with the corresponding port number.
Software
caution
If you are using Raspberry Pi with Raspberrypi OS >= Bullseye, you have to use this command line only with Python3.
One of the steps is to add the necessary DHT library, please make sure it is installed.
  • Step 2. Enter the relevant virtual environment.
source ~/grove_env/env/bin/activate
cd ~/grove_env/grove.py/grove
  • Step 3. Excute below commands to run the code.
nano ~/grove_env/dht22_demo.py
Copy the following code
import time
import seeed_dht
# for DHT11/DHT22
sensor = seeed_dht.DHT("22", 12)
# for DHT10
# sensor = seeed_dht.DHT("10")
print("DHT11 reading every second, Ctrl+C to quit")
try:
while True:
humi, temp = sensor.read()
print(f"DHT11 Humidity {humi:.1f}% Temperature {temp:.1f}°C")
time.sleep(1)
except KeyboardInterrupt:
print("\nBye")
Save and exit: Ctrl+O → Enter → Ctrl+X
If everything goes well, you will be able to see the following result
pi@raspberrypi:~/Seeed_Python_DHT/examples $ python ~/grove_env/dht22_demo.py
DHT22, humidity 39.2%, temperature 29.1*
DHT22, humidity 39.1%, temperature 29.1*
DHT22, humidity 40.0%, temperature 29.1*
DHT22, humidity 39.9%, temperature 29.1*
DHT22, humidity 40.3%, temperature 29.1*
DHT22, humidity 42.0%, temperature 29.1*
You can quit this program by simply press ++ctrl+c++.
Play With Raspberry Pi (with GrovePi_Plus)
Hardware
Materials required
Raspberry piGrovePi_PlusTemperature&Humidity Sensor Pro
  • Step 1. Plug the GrovePi_Plus into Raspberry.
  • Step 2. Connect Grove - Temperature&Humidity Sensor Pro to D4 port of GrovePi_Plus.
  • Step 3. Connect the Raspberry to PC via USB cable.
Software
If this is the first time you use GrovePi, please do this part step by step. If you are an old friend with GrovePi, you can skip Step1 and Step2.
  • Step 1. Setting Up The Software. In the command line, type the following commands:
caution
If you are using Raspberry Pi with Raspberrypi OS >= Bullseye, you cannot use this command line.
sudo curl -kL dexterindustries.com/update_grovepi | bash
sudo reboot
cd /home/pi/Desktop
git clone https://github.com/DexterInd/GrovePi.git
For more detail about this part, please refer to Setting Software.
note
We firmly suggest you to update the firmware, or for some sensors you may get errors.
  • Step 3. Configure the parameter
caution
cd /home/pi/Desktop/GrovePi/Software/Python/
sudo nano grove_dht_pro.py
note
The Grove - Temperature&Humidity Sensor and the Grove - Temperature&Humidity Sensor pro share the same python code which named grove_dht_pro.py. The only difference is that for the sentence [temp,humidity] = grovepi.dht(sensor,blue). We use the parameterblue for Grove - Temperature&Humidity Sensor while we use white for the Grove - Temperature&Humidity Sensor pro. The default value is blue, so for this sensor you need to change the code.
Change the default parameter [temp,humidity] = grovepi.dht(sensor,blue) into [temp,humidity] = grovepi.dht(sensor,white). Then the code should be like:
import grovepi
import math
# Connect the Grove Temperature & Humidity Sensor Pro to digital port D4
# This example uses the blue colored sensor.
# SIG,NC,VCC,GND
sensor = 4 # The Sensor goes on digital port 4.
# temp_humidity_sensor_type
# Grove Base Kit comes with the blue sensor.
blue = 0 # The Blue colored sensor.
white = 1 # The White colored sensor.
while True:
try:
# The first parameter is the port, the second parameter is the type of sensor.
if math.isnan(temp) == False and math.isnan(humidity) == False:
print("temp = %.02f C humidity =%.02f%%"%(temp, humidity))
except IOError:
print ("Error")
Then tap ++ctrl+x++ to quit nano. Tap ++y++ to save the change.
  • Step 4. Run the following command to get the result.
sudo python3 grove_dht_pro.py
pi@raspberrypi:~/GrovePi/Software/Python $ sudo python3 grove_dht_pro.py
temp = 22.90 C humidity =42.30%
Schematic Online Viewer
Projects
Temperature Humidity Data Logger: This project helps to monitor temperature and humidity values of a particular location along with device battery level.
LinkIt ONE IoT Demo: An IoT demo made by LinkIt ONE.
Automated Snake Enclosure with Camera: Interactive snake enclosure that is temperature and humidity controlled and uses lat-long to mimic natural light cycles, with an online cam.
Foton - The connected lightsaber: Foton is a special lightsaber, which can monitor temperature and humidity of a room, detect movements, and send those data to a smartphone.
