Grove - Variable Color LED
This Grove consists of one 8mm RGB LED. It operates at 5V DC. When SIG pin is logic HIGH, the RGB LED will light up. Perfect for use on Seeeduino digital outputs, or also can be controlled by pulse-width modulation. And it uses three adjustable resistor to change the color of the RGB LED.
- Grove compatible
- Color adjustable
Application Ideas
- Toys
- Decoration
Be gentle while adjusting the R, G and B adjustable resistances in case of over-turning.
Specifications
| Item | Typical | Unit |
| Operate Voltage | 5.0 | VDC |
| Working Current | 20 | mA |
| Variable Resistor | <1 | KΩ |
Platforms Supported
Usage
The three resistances RED, GREEN and BLUE of the module control the R, G and B channels respectively. By adjusting the three adjustable resistances, it can turn out variable color. The thing to notice, however, is that be gentle when turning the adjustable resistances.
The following sketch demonstrates a simple application of controlling its brightness. As the picture on the below indicates, the Variable Color LED is connected to digital port 9 of the Grove - Base Shield. The hardware installation is as follows:
- Copy and paste code below to a new Arduino sketch.
Demo code like:
int ledPin = 9; // LED connected to digital pin 9
// nothing happens in setup
// fade in from min to max in increments of 5 points:
for(int fadeValue = 0?; fadeValue <= 255; fadeValue +=5) {
// sets the value (range from 0 to 255):
analogWrite(ledPin, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(30);
// fade out from max to min in increments of 5 points:
for(int fadeValue = 255?; fadeValue >= 0; fadeValue -=5) {
delay(30);
- Upload the code.Adjust the three adjustable resistances, I am sure you will like it. Have a try!
Schematic Online Viewer
