Grove Base Shield for Photon
Grove interfaced
Connect to massive and low-cost Grove modules
I2C, UART ports integrated
Application ideas
- Compact IoT applications such as smart router.
| Grove ports | 3 digital ports 2 analog ports 2 I2C ports 1 UART port. |
| Dimensions | 53 × 53 mm |
| Weight | 18g |
Hardware Overview
Parts list
| Parts name | Quantity |
| Grove Base Shield for Photon | 1PC |
Getting Started
Note: In this case we show you a general development environmental.
Buzzing
- Refer to here to connect to a device (PC or Mac).
note
- We recommend that you choose node.js v4.2.3 LTS especially for Windows 10 user.
- You may need to one more steps after run command particle setup, that is, connect you device (PC or Mac) to a wi-fi AP whose name contain Photon, especially on Windows 10.
- Use Web IDE for your project. Login with your account and choose your device (click the 2nd last icon on left column).
note
We recommend you choose Web IDE to compile or flashing your code to Photon which is much quicker than using Particle Dev, if your internet connectivity is not so good.
- Connect them like following:
- Now you can copy following code to Web IDE and flash them to Photo by clicking a lighting-like icon (the 1st icon on left column).
note
Copy the code only to the tab named filename.ino.
Buzzing
Use digital pin D4
This example code is in the public domain.
by xiaohe
int led1 = D4; //set D4 as output
pinMode(led1, OUTPUT);
// enable buzzing
digitalWrite(led1, HIGH);
// We'll leave it on for 1 second...
// Then we'll turn it off...
digitalWrite(led1, LOW);
// Wait 1 second...
// And it will repeat!
Schematic Online Viewer
