Grove IoT Developer Kit Microsoft Azure Edition
Grove IoT Developer Kit – Microsoft Azure Edition contains an Intel® Edison module, an Intel® Edison for Arduino board, a Grove Base Shield, a set of Grove sensors and actuators with build-in Grove ports for rapid prototyping. Simply plug in the modules and you are ready to create.
Intel® Edison For Arduino
The Intel® Edison compute module is designed for expert makers, entrepreneurs, and some industrial IoT applications, it provides ease-of-development for a range of prototyping projects or commercial ventures when performance matters. With an expansion board interfaces with a wide range of Arduino shields, Intel® Edison for Arduino allows quick and easy prototyping with open source hardware and a software development environment.
A combination of the power Intel® Edison and rich featured Grove System
Fast prototyping for IoT projects
Support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future
It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service.
Has an SD card connector, micro USB or standard sized USB host Type-A connector(via mechanical switch), Micro USB device, 6 analog inputs, and 20 ditial input/output pins, 1x UART, 1x I2C, and 1x ICSP 6-pin header (SPI) Power jack with 7V-15V DC input.
What's included
Inter Edison For Arduino
Intel Edison Compute module
Base Shield V2
Sensors
| Sensor | Wiki |
![]() | Grove - Button(to Wiki) |
![]() | Grove - Sound Sensor(to Wiki) |
![]() | Grove - 3-Axis Digital Accelerometer(±1.5g)[(to Wiki) |
![]() | Grove - Touch Sensor(to Wiki) |
![]() | Grove - Light Sensor v1.2(to Wiki) |
![]() | Grove - Temperature Sensor(to Wiki) |
![]() | Grove - Rotary Angle Sensor(P)(to Wiki) |
![]() | Grove - Piezo Vibration Sensor(to Wiki) |
Actuators
Grove - Green LED
Grove - Blue LED
Gear Stepper Motor with Driver (to Arduino Tutorial)
Getting Started with the Intel® Edison Board
Before we work on any Grove modules, let's firstly get started with Intel® Edison Board, you can follow the detailed instructions on the official site of Intel® Edison to:
Step 1: Assemble Your Board
Install the compute module, attach the legs, and plug in your cables.
Step 2: Choose Your Operating System
| Windows | The Windows 64-bit installer will install your drivers, update your firmware, and let you install your development environment (IDE) | Download 64-bit version |
| OS X | The Mac* OS X* installer will update your firmware, and let you install your development environment (IDE) | Download |
| Linux | The Linux* installer will update your firmware, and let you install your development environment (IDE) | Download |
If you are have a windows 32-bit system or having errors with the installer, Intel also provide manual process to install the drivers or update your firmware:
| Windows | Try Manual Process |
| OS X | Try Manual Process |
| Linux | Try Manual Process |
Step 3: Set Up a Serial Terminal
You'll need a serial terminal connection to your board for flashing the firmware
Step 4: Connect Your Board to the Internet
How can you build an IoT device without the "I"? Let's connect your board to the WiFi network.
Step 5: Try It Out with Arduino IDE
As we've already installed the development environment including Arduino IDE in Step 2 (if not, you can download the latest Arduino IDE here. ) now as your very first practice, let's try to blink an LED on Intel Edison Board with Ardunio IDE.
Getting Started with the Grove System
Connect the Grove - Base Shield to Intel Edison for Arduino via the pin connectors.
Using 26AWG Grove Cable making the following connections:
| Grove Modules | Connected to |
| Temperature&Humidity Sensor | I2C |
| Moisture Sensor | A1 |
| Light Sensor | A2 |
| UV Sensor | A3 |
| PIR Motion Sensor | D7 |
| Encoder | D2 |
| Button | UART(D1) |
| LCD RGB Backlight | I2C |
| Relay | D5 |
| Servo | D6 |
| Buzzer | D4 |
Running Example
- Open the web site: Grove_Indoor_Environment_Demo to download the whole project.
- Click Tools > Serial Port and select the Com # that the Intel Edison is connected to
Click Sketch>Import Library…>Add Library and import the library downloaded at step 1
Click File>Examples> Grove_Indoor_Environment_Demo and select the demo Click upload icon
- Open Serial Monitor, it will print the sensors' information:
- Rotate the Encoder to check the sensor value on the LCD.
- In the "Send TextBox", you can enter the following command to operate the sensors and actuators:
| Example | Description |
| set temp>40, relay=1 | if temperature is higher than 40℃, the relay opens. |
| set temp>40, sleep=1 | if temperature is >40℃, nothing to do. |
| set humi>60, buzzer=1 | if humidity is >60%, the buzzer beeps. |
| set light>600, servo=90 | if light intensity is >600, the servo truns 90°. |
| set uv>80, relay=0 | if UV intensity is >80, the relay closes. |
| set pir=1, buzzer=1 | if people detected, the buzzer beeps. |
| set ms>40, relay=1 | if moisture is >40, the relay opens. |
| set ssid=name, psw=password | set the wifi SSID and Password.you can open a web browser, and go to the IP address displayed on the Serial Monitor or LCD. The default port is 88. he default port is 88. Such as: 192.168.1.101:88 |
Note:
The command should be ended with 'n', so "NewLine" (in the Serial Monitor) should be selected.
A actuator can only be controlled by a sensor. If A sensor wants to control a actuator(has be controlled by B sensor), B sensor should be set sleep.
- WiFi connection. open the Serial Monitor, and set your ssid and password(as below). Check the local IP on the LCD or Serial Monitor. On a device connected on the same network, open a web browser, and go to the IP address above, you can see the sensor value.
Note: When visiting the web server, a port number(88)should be added,such as: 172.20.10.2:88.
Resource
